EasyDAQ Relay Card Plugin
Cards Supported
- USB4PRMxN, USB4PRMx, USB4SRMx (4 relays + 4 DIO channels)
- USB8VI4DIOSR (8 isolated inputs + 4 relays + 4 DIO channels)
- USB8PR2, USB8PR, USB8SR (8 relays)
- USB16PRMxN, NET16PRMx (8 relays + 8 relays/DIO + 8 DIO channels)
- USB24MxS (24 relays)
- USBDIO24 (24 DIO channels)
Adding Cards to Indigo
Next choose the File→New Device…
menu item, select Plugin
from the Type popup control, and EasyDAQ Relay Card
from the Plugin popup control, and choose the correct Model. Press the Edit Device Settings…
button to configure the card:
Controlling Relay and Digital Outputs
The output channels are controlled via Indigo actions. The actions can be inside Triggers, Schedules, Action Groups, or assigned to Control Page controls. From the Action panel inside these dialogs choose Plugin
from the Type popup control, and then choose the Action you want to perform and the target Device:
Some actions have additional options available via the Edit…
button. For example, the Change Multiple Outputs
action allows you to control (turn on, turn off, or toggle) all of the outputs with a single, and very fast, action:
Triggering Actions on a Digital Input Change
Indigo will automatically track all input and output channel states. To trigger an action when a particular channel state changes from OFF to ON (or ON to OFF) choose the File→New Trigger
menu item, and select Device State Changed
from the Type popup control. Next, select the Indigo device representing the EasyDAQ card you want to monitor, and then choose which channel change will cause the trigger:
Preventing Floating Input Problems
Scripting Support
Action specific properties
Turn On Output
Action id: turnOnOutput
Properties for scripting:
channelSel | this is the channel number to turn on, values depend on the type of card you have |
easyDaqPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards") if easyDaqPlugin.isEnabled(): easyDaqPlugin.executeAction("turnOnOutput", deviceId=131523919, props={'channelSel':1})
Turn Off Output
Action id: turnOffOutput
channelSel | this is the channel number to turn off, values depend on the type of card you have |
easyDaqPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards") if easyDaqPlugin.isEnabled(): easyDaqPlugin.executeAction("turnOffOutput", deviceId=131523919, props={'channelSel':1})
Toggle Output
Action id: toggleOutput
channelSel | this is the channel number to toggle, values depend on the type of card you have |
easyDaqPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards") if easyDaqPlugin.isEnabled(): easyDaqPlugin.executeAction("toggle", deviceId=131523919, props={'channelSel':1})
All Outputs On
Action id: allOutputsOn
easyDaqPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards") if easyDaqPlugin.isEnabled(): easyDaqPlugin.executeAction("allOutputsOn" deviceId=131523919)
All Outputs Off
Action id: allOutputsOff
easyDaqPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards") if easyDaqPlugin.isEnabled(): easyDaqPlugin.executeAction("allOutputsOff" deviceId=131523919)
Action id: changeMultiple
channelSel# | this is the command for the channel and must be one of the following: “turnOn”, “turnOff”, “toggle” - note that you should have separate properties for each channel, see example below for details |
easyDaqPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards") if easyDaqPlugin.isEnabled(): easyDaqPlugin.executeAction("changeMultiple", deviceId=131523919, props={'channelSel1':'turnOn', 'channelSel8':'toggle', 'channelSel17':'turnOff'})
Support and Troubleshooting
