Indigo 2022.1 Documentation
Welcome to the Indigo 2022.1 Documentation pages. We've separated the docs into multiple areas, each focusing on some different part of Indigo 2022.1.
Indigo User Documents
Other Help Pages
Indigo Plugin Documents
- Email+ - allows users to integrate with email services.
- NOAA Weather - makes weather data from the U.S. National Oceanic and Atmospheric Administration available for use in Indigo.
The iTunes (Music) plugin has been removed from this release since it no longer works with the Music app.
Indigo How-To Wiki
Technical Documents
About API v3.0: with API v3.0 and later, we have switched to Python 3. Older versions of the API use Python 2, and – for this release only – Python 2 will continue to work with this release (M1 Macs will require Rosetta as it is Intel-only). Plugins specifying API 2.x or earlier will be run with Python 2 (and will stop working in the next release of Indigo) and scripts – both embedded and external – will run in Python 3 only. See the API release notes for v3.0 for details. See Python Packages for a list of the additional Python packages that are installed with the Indigo 2022.1 installer.
- Indigo 2022.1 Scripting Tutorial - dive into scripting Indigo by examples.
- Indigo 2022.1 Server Plugin Tutorial - examples of extending Indigo via plugins.
- The Indigo Plugin SDK (available here) includes example plugins with full XML and python source. They are a great place to start when developing new plugins (or when upgrading a plugin to Python 3).
- Indigo 2022.1 Plugin Developer's Guide - how to create plugin bundles for easy distribution, plugin UI, APIs, callback hooks, and more.
- Indigo 2022.1 Object Model Reference - the Indigo Object Model (IOM) and how to use it in Python.
