Install the FTDI VCP Drivers
Connecting the Interface
- Choose
Indigo 2022.1→Preferences…menu, then make sure theInterfacestab is selected. - Select the
INSTEON/X10 Power Line Interfaceline in the table (you can also get to this dialog by selecting theInterfaces→INSTEON/X10 Power Line→Configure…menu item) - Choose your
- Optionally select the
To add a new Insteon device:
- Press the
New…button at the top of the Home window and selectINSTEONfrom theTypepopup.
Resyncing Links
Replacing a Device
Managing INSTEON Links
Managing INSTEON Device Links
- Select the
Defining the Scene
- Choose
Executing the Scene
- Select the
Scenepopup item.
INSTEON Link Syncing
Resetting your PowerLinc
- Release the button
- In Indigo, select the
Sync Linksbutton
Replacing Your PowerLinc
Execute Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
if insteonPlugin.isEnabled():
actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
Set Siren Alarm Sound
Set Siren LED Mode
Set OutletLinc Load Sense
