Indigo Mac Client
When you double click on the Indigo 2022.1 icon in the Applications folder, you're actually starting the Indigo Mac Client, which will start up the Indigo Server process according to the options selected in the Start Server dialog.
Home Window
The Home Window has 4 areas:
- Outline View
- Item List
- Item Detail
- Status Bar
Outline View
Rename Folder…allows you to rename the folder.Delete Folderwill do just that. If the folder isn't empty, it will show you a sheet with 3 options:Cancel(do nothing),Delete Items(delete the items in the folder along with the folder), orMove Items(move the items to the parent first then delete the folder).Disable/Enable Remote Display(for devices, action groups, and control pages) will show/hide it in remote clients (like Indigo Touch for iOS and Web, the DomoPad 3rd party client for Android, etc).Copy ID (123456789)will copy the unique folder ID for use in Python scripts.
Item List
This menu will:
indigo.devices[91776575] # “Living Room Switch” - Print all the information about a device to the Event Log window. It will look something like this:
address : 3B.04.7A
batteryLevel : None
blueLevel : None
brightness : 0
buttonConfiguredCount : 0
buttonGroupCount : 1
configured : True
defaultBrightness : 100
description : valve
deviceTypeId :
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 810233868
publish-device : true (bool)
sub-type : Valve (string)
voice-name : valve (string)
greenLevel : None
ledStates : []
model : LampLinc (dual-band)
onBrightensToLast : False
onState : False
pluginId :
protocol : Insteon
redLevel : None
remoteDisplay : True
states : States : (dict)
brightnessLevel : 0 (integer)
subModel : Plug-In
subType : Plug-In
supportsAllLightsOnOff : True
supportsAllOff : True
supportsColor : False
supportsRGB : False
supportsStatusRequest : True
supportsWhite : False
version : 67
whiteLevel : None
whiteLevel2 : None
whiteTemperature : None
- Enable/disable the event.
Item Detail
- Copy Python Reference will copy the full reference to that state that you can use in a Python script. It will look something like this:
indigo.devices[1604256801].states["album"] # State "album" of "MightMini iTunes" - Copy State Value will copy the string value of the state to the clipboard so you can paste it somewhere else.
- Copy State ID will copy the ID of the state for use in a Python script.
- Copy Substitution String will copy the appropriately marked up string that you can use in a variety of dialogs to substitute the value of the state at runtime. It will look something like:
%%d:1604256801:album%%
Lights/Appliances
Color Controls Tile Image
Speed Controls
Sprinklers
Thermostats
Generic Output Devices
Triggers and Schedules
Control Pages
Status Bar
Event Log Window
Click the Clear Window button to clear the log entries. Click on Show Event Logs Folder to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 2022.1→Preferences… and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside that period of time.
Variable Window
Menus
Indigo 2022.1 Menu
About Indigo 2022.1- this will show the About window which will show what client and server versions you're running and will show your registration codeStart Local Server…- this will open the Start Server dialogStop Server- this will stop the Indigo ServerConnect to Remote Server…- this option will allow you to connect to a different Indigo server or a server running on another MacClose Connection- this will close the connection to the serverPreferences…- this opens the preferences dialogLicense Details…- this opens the Subscription Status window that will show you the status of your License and it's associated Up-to-Date Subscription:
Check for Updates…- this will have the server your connected to contact us to see if there is an update available
File Menu
New Database…- this will close the current database and create a new one - you'll be prompted for a name and save locationSelect Database…- this will allow you to switch to a different databaseClose Window- this will close the frontmost windowNew Device…- this will switch the Home Window to the devices view and open the new device dialogNew Trigger…- this will switch the Home Window to the triggers view and open the new trigger dialogNew Schedule…- this will switch the Home Window to the schedules view and open the new schedule dialogNew Action Group…- this will switch the Home Window to the action groups view and open the new action group dialog
Edit Menu
View Menu
Interfaces Menu
Plugins Menu
Window Menu
Help Menu
Help for XXXX- this will change slightly based on what window is selected and what's selected in that window - but it will open the default browser to the page in the help documentation for that particular itemHow-To Wiki- this will also change slightly based on what's selected - it will open to the How-To wiki for the selected item (if a device is selected it will go to the wiki for that device, otherwise it will just go to the landing page)Email Log…- this option will email some of your event log data to the specified email address. Particularly useful for technical supportShow AppleScript Usage in Event Log- this option will print a list of AppleScripts that are embedded in actions that you have specified. This will help to identify and replace those scripts.Show Event Logs Folder- this option will switch to the Finder and open the folder that contains the Event Log log files.Show Web Assets Folder- this option will switch to the Finder and open the folder that contains custom images, text files, etc., that you might want to give Indigo (and others) access to through the Indigo Web Server.Indigo Documentation- this will open your browser to the landing page for all Indigo 2022.1 documentationGetting Started Guide- this will open your browser to the Getting Started Guide, the place where everyone new to Indigo should startManaging a Z-Wave Network- opens a browser window to the Managing Your Z-Wave Network document in our Documentation wikiManaging an INSTEON Network- opens a browser window to the Managing Your INSTEON Network document in our Documentation wikiOnline Support Forum- this will open your browser to our support forum - it's very active and is the primary place where you should seek help - we answer questions there very quickly and in fact we have many helpful users that can help as wellCompatible Devices- opens a browser window on our new Compatible Devices list that shows which devices and interfaces have been tested with Indigo and includes devices supported by 3rd party pluginsPlugin Store- this will open your browser to our Plugin Store where you can browse and download hundreds of 3rd party plugins that add functionality to Indigo
