The NOAA Weather Plugin allows you to create Weather Station devices. To create a new one, switch to the device view and click the New…
button. This will bring up the device edit dialog. Select Plugin
from the Type:
popup. Select NOAA Weather
from the Plugin:
popup, and select Weather Station
from the Model:
button and you'll see the Weather Station Config UI. Enter the NOAA station id in the text box at the top. You can click on the “Find NOAA Stations” to have a browser window open to the NOAA webpage where you can start your search.
Current Condition
- The current condition in a word or twoCurrent Condition Icon
- The current condition icon - Indigo ships with “NOAA Condition+.png” and it's children, one for each condition that's returned in this field. So, in the control page editor, select this state and “NOAA Condition+.png” and you'll have a nice conditions icon (images provided by NOAA).Dew Point °C
- Dew point in CelsiusDew Point °F
- Dew point in FahrenheitDew Point String
- Dew point in a human-readable stringHeat Index °C
- Heat index in CelsiusHeat Index °F
- Heat index in FahrenheitHeat Index String
- Heat index in a human-readable stringHumidity
- The relative humidityLatitude
- LatitudeLocation
- Location in human-readable formLongitude
- LongitudeObservation Date/Time
- The last time NOAA updated the data. This field is in YYYY-MM-DD HH:MM:SS
so it can be parsed by other software if needed.Pressure (inches)
- Pressure in inchesPressure (mbar)
- Pressure in millibarsQuality Codes
- For scripters to account for the relative quality of the various weather observations (JSON). This state is only available in Indigo 2022.1 and later. See below for what the codes mean. Temperature °C
- Temperature in CelsiusTemperature °F
- Temperature in FahrenheitTemperature String
- Temperature in a human-readable string (i.e. “98.0 F (36.7 C)”) - this is the state shown in the “State” column for a Weather Station deviceTime Zone
- The timezone as it applies to the observed location. This state is only available in Indigo 2022.1 and later.Visibility
- Visibility in milesWind Degrees
- Wind direction in degreesWind Direction
- Wind direction description in something close to human-readable formWind Knots
- Wind speed in knotsWind MPH
- Wind speed in miles per hourWind String
- A description of the wind in human-readable form
Beginning with Indigo 2022.1, the NOAA Weather plugin includes a new state qualityCodes
. This state includes information (from NOAA) on the perceived quality of select data elements. An example qualityCodes
state value is:
MADIS QC Information - Surface QC Data Descriptor Values | |
No QC available | |
Z | Preliminary, no QC |
Automated QC checks | |
C | Coarse pass, passed level 1 |
S | Screened, passed levels 1 and 2 |
V | Verified, passed levels 1, 2, and 3 (BEST) |
X | Rejected/erroneous, failed level 1 |
Q | Questioned, passed level 1, failed 2 or 3, where: |
Quality Levels | |
level 1 = validity | |
level 2 = internal consistency, temporal consistency, statistical spatial consistency checks | |
level 3 = spatial consistency check |
import json dev = indigo.devices[12345678] codes = dev.states['qualityCodes'] quality_codes = json.loads(codes) temp_quality = quality_codes['temperature'] if temp_quality in ("X", "Q"): indigo.server.log("don't trust") else: indigo.server.log("trust")
