%%v:VARID%%
%%d:DEVID:STATEID%%
The STATEID of the device whose ID is DEVID will be substituted. For instance, an iTunes Server device from the iTunes plugin has a state named album
. So, if the ID of your iTunes server device was 123456, then this would insert the album title into the field:
The current album playins is %%d:123456:album%%.
