In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and ealier), the installer moves previously installed control page images and web server plugins to the new install location. Note the folder that contains Web server images, legacy Web plugins, etc. has been renamed from:
to:
Indigo 7.5→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 7.5→Quit Indigo
menu item./Applications
to:
Indigo 7.4→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 7.4→Quit Indigo
to:
Indigo 7.3→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 7.3→Quit Indigo
to:
Indigo 7.2→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 7.2→Quit Indigo
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and ealier), the installer is now smarter and moves previously installed control page images and web server plugins to the new install location. Note the folder that contains Web server images, legacy Web plugins, etc. has been renamed from:
to:
Indigo 7→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 7→Quit Indigo
First, run the Indigo 2022.1 installer. Then look through this list for any final actions.
/Library/Python/2.6/site-packages/
to /Library/Python/2.7/site-packages/
/Library/Application Support/Perceptive Automation/Indigo 6/Scripts/
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/
/Library/Application Support/Perceptive Automation/Indigo 5/Scripts/
/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/
[~your user home folder]/Documents/Indigo User Data/Scripts/
) to the new folder specified above if you modified or added new script or script attachment files.NOTE: Do not replace the new Indigo versions of any file with your Indigo 1.x files. They have been modified to run optimally under the new version of Indigo.
When Indigo first opens an Indigo 7.3 (or earlier) database, it will go through the database and identify items that will need changing and items you should look at to ensure that it will continue to function. The Event Log will contain the necessary information about where you can find those items. You can also select the Help→Show AppleScript Usage in Event Log
menu item and Indigo will show you the list of those items in the Event Log window again.
