Integration APIs
In Indigo v2022.2, we’ve completely redesigned the Indigo Web Server plugin (commonly referred to as IWS). The first major change is the new Indigo Touch for Web UI. We know you'll love this new UI (particularly given the old UI which was super dated):
This article, however, is about the two new APIs in IWS that developers can use to integrate Indigo with external services:
- WebSocket API – (which the new Indigo Touch Web UI uses, and
Both of these APIs are authenticated with HTTP Digest and API Keys (either as a query string or preferably an Authorization header) depending on how the user configures it in the Start Local Server dialog.
NOTE:
- We’re deprecating HTTP Basic authentication due to its insecure nature.
Versioning
A quick note on versioning: moving forward, all APIs will be versioned under the following scheme:
/v2/- this is the top level version number and will change as necessary
Python vs JavaScript
"key1": "value 1",
"key2": 2
| Python | JSON Equivalent |
| True | true |
| False | false |
| float | Number |
| int | Number |
| None | null |
| dict | Object |
| list | Array |
| tuple | Array |
| str | String |
WebSocket API
%%/v2/api/ws/device-feed%%- WebSocket to do all communication about devices%%/v2/api/ws/variable-feed%%- WebSocket to do all communication about variables%%/v2/api/ws/action-feed%%- WebSocket to do all communication about action groups%%/v2/api/ws/page-feed%%- WebSocket to do all communication about control pages%%/v2/api/ws/log-feed%%- WebSocket to do all communication about logs
WebSocket Lifecycle
- Setup:
Authentication
WebSocket API requests must be authenticated using an API Key. You can manage API Keys in the Authorizations section of your Indigo Account. Using keys instead of your Indigo Server username/password has several advantages: you can, at any time, revoke an API key, and it will immediately cause anything using it to fail. This will not affect anything else using a your username/password or another API key, so your server protections against intrusions are much more granular. Also, if someone does manage to get your API Key, they can control devices, but they cannot modify your database (add/delete devices, etc) - that is reserved for Indigo clients using the username/password.
Note the protocol: wss. WebSockets actually begin their life as HTTP/HTTPS connections, which the WebSocket client then requests the server to upgrade to a WebSocket. In this respect, you can think of WSS as HTTPS (protected) and WS as HTTP (unprotected). When using WSS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be WS and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Be sure not to share your API keys with anyone not authorized to use them — especially in posts to the Indigo user forums.
Python Receiver Example
import asyncio import json from websockets import connect API_KEY = 'YOUR_API_KEY' # YOUR API KEY HERE DEVICE_ID = 12345678 # YOUR DEVICE ID HERE HEADERS = {"Authorization": f"Bearer {API_KEY}"} URI = "ws://127.0.0.1:8176/v2/api/ws/device-feed" # wss:// if using the reflector async def receiver(ws): try: print("Starting receiver task") # Ask for a refresh of device with ID 12345678 refresh_message = { "id": "initial-device-refresh", "message": "refresh", "objectType": "indigo.Device", "objectId": DEVICE_ID } await ws.send(json.dumps(refresh_message)) counter = 0 device = {} while counter < 20: # just keep looping waiting for a message to come log_string = "ignoring message" message_json = await ws.recv() message = json.loads(message_json) message_type = message['message'] if message_type == "refresh": # This is the response to the refresh message we sent above. It gets us a full copy of the device. device = message["objectDict"] log_string = f"receiver: device refresh message: '{device.get('name', 'unknown')}'" elif message_type == "patch": # There's been a change, so confirm it's the device we want then log the change if message["objectId"] == device["id"]: log_string = f"'receiver: device patch message: {device.get('name', 'unknown')}' update: \n{message_json}" print(f"receiver: loop count: {counter}") print(f"receiver: {log_string}") counter += 1 except Exception as exc: print(f"Exception:\n{exc}") async def sender(ws, count): try: print("Starting sender task") message = { "id": "initial-device-refresh", "message": "refresh", "objectType": "indigo.Device", "objectId": DEVICE_ID } for count in range(10): print(f"sender: loop count: {count}") msg = json.dumps(message) print(f"sender: sending message: {msg}") await ws.send(json.dumps(msg)) await asyncio.sleep(5) except Exception as exc: print(f"Exception:\n{exc}") async def main(): try: async with connect(URI, extra_headers=HEADERS) as websocket: await asyncio.gather(receiver(websocket), sender(websocket, 10)) except Exception as exc: print(f"Exception:\n{exc}") asyncio.run(main())
JavaScript Example
Device Feed
%%ws:localhost:8176/v2/api/ws/device-feed%%
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/device-feed%%
add device message
"message": "add",
objectDict": {
"address": "3B.04.7A",
"batteryLevel": null,
"blueLevel": null,
"brightness": 100,
"buttonConfiguredCount": 0,
"buttonGroupCount": 1,
"configured": true,
"defaultBrightness": 100,
"deviceTypeId": "",
"displayStateValRaw": 100,
"displayStateValUi": "100",
"enabled": true,
"energyAccumBaseTime": null,
"energyAccumTimeDelta": null,
"energyAccumTotal": null,
"energyCurLevel": null,
"errorState": "",
"folderId": 1552926800,
"globalProps": {
"emptyDict": {}
"greenLevel": null,
"id": 1508839119,
"ledStates": [],
"name": "Insteon Dimmer",
"onBrightensToLast": false,
"onState": true,
"ownerProps": {},
"pluginId": "",
"pluginProps": {},
"redLevel": null,
"remoteDisplay": false,
"sharedProps": {},
"states": {
"brightnessLevel": 100,
"onOffState": true
"subModel": "Plug-In",
"subType": "Plug-In",
"supportsAllOff": true,
"supportsColor": false,
"supportsOnState": true,
"supportsRGB": false,
"supportsWhite": false,
"version": 67,
"whiteLevel": null,
"whiteLevel2": null,
"whiteTemperature": null
update device message
"message": "patch",
"objectId": 1508839119,
"patch": [
"change",
"brightness",
[100, 0]
"change",
"displayStateImageSel",
"change",
"displayStateValRaw",
[100, 0]
"change",
"displayStateValUi",
["100", "0"]
"change",
"lastChanged",
"change",
"lastSuccessfulComm",
"change",
"onState",
[true, false]
"change",
"states.brightnessLevel",
[100, 0]
"change",
"states.onOffState",
[true, false]
device refresh messages
"id": "optional-user-generated-refresh-device-list-message", // Reserved for future use.
"list": []
"id": "optional-user-generated-refresh-device-message",
"objectDict": {}
delete device message
"message": "delete",
"objectId": 123456789
Device messages to the server
device refresh requests
// Specify the object type
device command messages
"objectId": 123456789,
Variable Feed
%%ws:localhost:8176/v2/api/ws/variable-feed%%
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/variable-feed%%
"class": "indigo.Variable",
"description": "",
"folderId": 0,
"globalProps": {
"id": 345633244,
"name": "house_status",
"pluginProps": {},
"readOnly": false,
"remoteDisplay": true,
"sharedProps": {},
"value": "home"
add variable message
"message": "add",
update variable message
Variable patch objects are created via the dictdiffer python module by comparing the variable dictionary (%%dict(some_variable)%%) for the old variable with the one for the new dictionary as they are received in the %%variable_updated()%% Plugin method call.
delete variable message
variable refresh messages
"id": "optional-user-generated-id", // Reserved for future use.
variable command messages
updateValue
"parameters": {
"value": "Some string value"
Action Group Feed
%%ws:localhost:8176/v2/api/ws/action-feed%%
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/action-feed%%
"description": "",
"folderId": 532526508,
"globalProps": {
"speakDelayTime": "5",
"id": 94914463,
"name": "Movie Night",
"pluginProps": {},
"sharedProps": {
add action group message
"message": "add",
update action group message
Action group patch objects are created via the dictdiffer python module, by comparing the action dictionary (%%dict(some_action_group)%%) for the old action with the one for the new dictionary as they are received in the %%action_group_updated()%% Plugin method call.
delete action group message
action group refresh messages
action group command messages
Control Page Feed
%%ws:localhost:8176/v2/api/ws/page-feed%%
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/page-feed%%
"backgroundImage": "",
"description": "",
"folderId": 0,
"globalProps": {},
"hideTabBar": true,
"id": 963336187,
"name": "Weather Images",
"pluginProps": {},
"sharedProps": {}
add control page message
"message": "add",
update control page message
delete control page message
Indigo Object Folders
"id": 617272302,
"class": "indigo.Folder",
"name": "My Device Folder",
refresh folder server message
"id": "optional-user-generated-id", // This is just a pass through from the refresh request
Log Feed
"message": "add",
"objectDict": {
"message": "Stopping plugin \"Web Server 2022.2.0\" (pid 1020)",
"typeStr": "Application",
"typeVal": 0
HTTP API
HTTP API Endpoints
%%/v2/api/indigo.devices%%- endpoint to get a list of devices%%/v2/api/indigo.devices/123456789%%- endpoint to get a specific device instance (See Device Objects below)%%/v2/api/indigo.variables%%- endpoint to get a list of variables%%/v2/api/indigo.variables/123456789%%- endpoint to specific variable object (See Variable Objects below)%%/v2/api/indigo.actionGroups%%- endpoint to get a list of action groups%%/v2/api/indigo.actionGroups/123456789%%- endpoint to get a specific action group (See Action Group Objects below)%%/v2/api/command%%- endpoint to send Indigo a command (device control, variable update, action execution).
Authentication
When using HTTPS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be HTTP and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Be sure not to share your API keys with anyone not authorized to use them — especially in posts to the user forums.
Getting Device Objects
Getting All Device Objects
- Replace
- Replace
- Replace
- Replace
- Replace
- Replace
Controlling an Indigo Device
- Replace
# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" DEVICEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ "id": "optional-user-generated-id", "message": "indigo.device.toggle", "objectId": DEVICEID }).encode("utf8") req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/command", data=message) req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: reply = json.load(request) print(reply)
- Replace
// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const DEVICEID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // The message to send to the Indigo Server const message = JSON.stringify({ "id": "optional-user-generated-id", "message": "indigo.device.toggle", "objectId": DEVICEID }) // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: "/v2/api/command", method: "POST", headers: { Authorization: `Bearer ${APIKEY}`, "Content-Length": message.length } } // Get the device JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const deviceInstance = JSON.parse(result); console.log(deviceInstance); }) }) req.write(message) req.end()
- Replace
- Replace
# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" DEVICEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ "id": "optional-user-generated-id", "message": "indigo.dimmer.setBrightness", "objectId": DEVICEID, "parameters": { "value": 50, "delay": 10 } }).encode("utf8") req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/command", data=message) req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: reply = json.load(request) print(reply)
- Replace
// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const DEVICEID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // The message to send to the Indigo Server const message = JSON.stringify({ "id": "optional-user-generated-id", "message": "indigo.dimmer.setBrightness", "objectId": DEVICEID, "parameters": { "value": 50, "delay": 10 } }) // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: "/v2/api/command", method: "POST", headers: { Authorization: `Bearer ${APIKEY}`, "Content-Length": message.length } } // Get the device JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const deviceInstance = JSON.parse(result); console.log(deviceInstance); }) }) req.write(message) req.end()
- Replace
Getting Variable Objects
Getting All Variable Objects
- Replace
- Replace
- Replace
- Replace
- Replace
- Replace
Updating a Variable's Value
- Replace
# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" VARIABLEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ "id": "optional-user-generated-id", "message": "indigo.variable.updateValue", "objectId": VARIABLEID, "parameters": { "value": "Some string value" } }).encode("utf8") req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/command", data=message) req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: reply = json.load(request) print(reply)
- Replace
// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const VARIABLEID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // The message to send to the Indigo Server const message = JSON.stringify({ "id": "optional-user-generated-id", "message": "indigo.variable.updateValue", "objectId": VARIABLEID, "parameters": { "value": "Some string value" } }) // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: "/v2/api/command", method: "POST", headers: { Authorization: `Bearer ${APIKEY}`, "Content-Length": message.length } } // Get the variable JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const VariableInstance = JSON.parse(result); console.log(VariableInstance); }) }) req.write(message) req.end()
- Replace
Getting Action Group Objects
- Replace
- Replace
- Replace
Executing an Action Group
- Replace
# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" ACTIONGROUPID = 123456789 # The message to send to the Indigo Server message = json.dumps({ "id": "optional-user-generated-id", "message": "indigo.actionGroup.execute", "objectId": ACTIONGROUPID }).encode("utf8") req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/command", data=message) req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: reply = json.load(request) print(reply)
- Replace
// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const ACTIONGROUPID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // The message to send to the Indigo Server const message = JSON.stringify({ "id": "optional-user-generated-id", "message": "indigo.actionGroup.execute", "objectId": ACTIONGROUPID }) // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: "/v2/api/command", method: "POST", headers: { Authorization: `Bearer ${APIKEY}`, "Content-Length": message.length } } // Get the action group JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const actionGroupInstance = JSON.parse(result); console.log(actionGroupInstance); }) }) req.write(message) req.end()
- Replace
API Messages
Device Messaging
Device Objects
Example device object
"blueLevel": null,
"brightness": 0,
"configured": true,
"deviceTypeId": "",
"displayStateValRaw": 0,
"displayStateValUi": "0",
"enabled": true,
"errorState": "",
"folder": {
"id": 1552926800,
"name": "Insteon",
"globalProps": {},
"greenLevel": null,
"id": 1508839119,
"ledStates": [],
"onState": false,
"ownerProps": {},
"pluginId": "",
"pluginProps": {},
"redLevel": null,
"sharedProps": {},
"states": {
"brightnessLevel": 0,
"onOffState": false
"version": 67,
"whiteLevel": null,
Note:The folder element is only available in the HTTP API. Folders are handled differently in the WebSocket API.
The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests.
indigo.device
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"value": True,
indigo.dimmer
"parameters": {
"by": 5,
"delay": 10
"parameters": {
"by": 5,
"delay": 10
"parameters": {
"value": 50,
"delay": 10
indigo.iodevice
"parameters": {
"index": 5,
"value": true
indigo.sensor
"parameters": {
"value": true
indigo.speedcontrol
"parameters": {
"by": 2,
"delay": 5
"parameters": {
"by": 2,
"delay": 5
"parameters": {
"value": 2,
"delay": 5
set speed level indigo.speedcontrol.setSpeedLevel(123456789, index=2, value=True)
"parameters": {
"value": 50,
"delay": 5
indigo.sprinkler
"parameters": {
"schedule": [10,15,8, 0, 0, 0, 0, 0]
"parameters": {
"index": 2
indigo.thermostat
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"value": 76
"parameters": {
"parameters": {
"value": 76
"parameters": {
Variable Messaging
Variable Objects
"description": "",
"folderId": 0,
"folder": {},
"globalProps": {
"id": 345633244,
"pluginProps": {},
"readOnly": false,
"sharedProps": {},
"value": "home"
The only action that can currently be performed on a variable is to update the value. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests.
"parameters": {
Action Group Messaging
"description": "",
"folder": {
"id": 532526508,
"name": "Mood Scenes",
"globalProps": {
"id": 94914463,
"pluginProps": {},
"sharedProps": {
There is only a single action group command, and that's to execute it. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests.
Log Messages
Example Log Message
"typeVal": 0
Error Messaging
Generic Error Message
"validationErrors": {
Example API Call
"parameters": {
"value": 1234.56
Resulting Error Message
%%message%%,%%objectId%%,%%parameters%%, and%%value%%
Invalid JSON
Example Invalid JSON Message
"error": "invalid JSON"
