Getting Started Guide
Z-Wave
  • Thermostats, and
  • Locks.
INSTEON
X10
Other Devices
The Indigo 2022.2 application can be found here:
  /Applications/Indigo 2022.2.app
  /Library/Application Support/Perceptive Automation/Indigo 2022.2/
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2022.2 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
  /Library/Application Support/Perceptive Automation/Indigo 2022.2/Web Assets/
Lastly, the shared Python modules folder available during script execution has changed from:
to a Python 3 version:
If you have any existing Python modules/libraries in the old folder you should copy them to the new folder and make sure they are Python 3 compatible.
Indigo plugins can now run under Python 3 and we are working with plugin developers to upgrade Python 2.7 based plugins to 3.10. Indigo 2022.2 will continue to allow older (Python 2.7) plugins to run, but you will see a warning in the Event Log and they will be marked with a yellow status icon in the Plugins menu indicating that they won't be compatible with future versions of Indigo. Check the Plugin Store and Plugin user forum for updates to the 3rd party plugins you are using.
  1. Deactivate Indigo on your Mac by selecting the Indigo 2022.2→License Details… menu item and clicking the Deactivate License button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first)
  2. Copy this folder over to the new Mac: /Library/Application Support/Perceptive Automation/Indigo 2022.2/ (if restoring from a backup, you'll need to locate this folder in whatever backup system you use)
  3. Install Indigo 2022.2 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
'/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httptools/parser/parser.cpython-310-darwin.so' (mach-o file, but is an incompatible architecture (have 'x86_64', need 'arm64'))
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2022.2→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Deactivate Sheet Image
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2022.2 menu if the server is still running before you quit the Indigo Mac Client).
  • ~(your user folder)/Library/Preferences/Indigo 2022.2 Client Prefs.indiPref
  • ~(your user folder)/Library/Preferences/Indigo 2022.2 Client Settings.indiPref
To uninstall older versions but leave 2022.2 installed correctly, delete these:
  • Indigo 2021.2:
  • Indigo 2021.1:
  • Indigo 7.5:
  • Indigo 7.4:
  • Indigo 7.3:
  • Indigo 7.2:
  • Indigo 7.0 and 7.1:
    • /Applications/Indigo 7.app
    • /Applications/Indigo 6.app
  1. Double click the Indigo 2022.2 application (/Applications/Indigo 2022.2.app).
  2. If this is the first time to run Indigo 2022.2 on this Mac, then press the Start Local Server… button in the connection status window.
  3. If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the Indigo 2022.2→Start Local Server… menu item.
Start Server Dialog Image
Use the Also allow HTTP Basic authentication (less secure) checkbox to enable HTTP Basic authentication. This setting allows you to insert the username/password in the URL line. Older services may require this, though we recommend against using it.
Login Dialog Image
Firewall Prompt Image
IPH Firewall Prompt Image
Network WiFi Image
Network Wired Image
  2. Double click the Indigo 2022.2 application (inside /Applications/Indigo 2022.2.app) on the remote Mac.
  4. If you are wanting to connect to a different Indigo Server, then select the Indigo 2022.2→Connect to Remote Server… menu item.
  7. Press the Connect button.
Client Connect Dialog Image
 http://192.168.1.23:8176/
Interfaces Menu Image
Interfaces Tab Image
  9. NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the Open With menu item, then select Indigo 2022.2.Open With Menu Item Image
  11. Done!
Plugin Configuration Dialog
Main Plugins Menu
Plugins Menu Image
There is also a yellow version of the green dots - the meaning is the same as the green version except it's indicating that the plugin is using an API version that will be deprecated in an upcoming release. You should check the Plugin Store for an updated version or contact the plugin developer.
  • Green Dot with Black Arrow Image a green dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version - you should install the update before upgrading to the next version of Indigo
  • Green Dot with Red Arrow Image a green dot with a red arrow means the plugin is enabled and there is an update available but it won't work with your version of Indigo
Individual Plugin Submenu
Plugin Enabled Submenu Image
The next section contains:
Other Menus with Plugin Items
Plugin New Device Image
Plugin Events Image
Plugin Actions Image
Plugins Tab Image
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2022.2→Preferences… menu item and clicking the Plugins tab or by selecting the Plugins→Manage Plugins… menu item discussed above.
  2. Switch back to Indigo and shut down the Indigo Server by selecting the Indigo 2022.2→Stop Server menu item in the Mac client (you can leave the client app running).
  3. In the Finder window opened in step 1, you'll see two folders: Plugins and Plugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin.
  4. Switch back to the Indigo 2022.2 Mac client and click on the Start Local Server… button in the Server Connection Status dialog.
Location Services Image
Longitude Latitude Tab Image
  • Choose the Indigo 2022.2→Preferences… menu item, then make sure the Sunset & Sunrise tab is selected.
General Preferences Tab Image
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2022.2→Preferences… menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2022.2→Check for Updates… menu item.
  • /www/perceptive/wiki/data/pages/indigo_2022.2_documentation/getting_started.txt
