Table of Contents
Getting Started Guide
Welcome to Indigo 2022.2!
Z-Wave
  • Thermostats, and
  • Locks.
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
The Indigo 2022.2 application can be found here:
  /Applications/Indigo 2022.2.app
  /Library/Application Support/Perceptive Automation/Indigo 2022.2/
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2022.2 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
  /Library/Application Support/Perceptive Automation/Indigo 2022.2/Web Assets/
Lastly, the shared Python modules folder available during script execution has changed from:
to a Python 3 version:
If you have any existing Python modules/libraries in the old folder you should copy them to the new folder and make sure they are Python 3 compatible.
Indigo plugins can now run under Python 3 and we are working with plugin developers to upgrade Python 2.7 based plugins to 3.10. Indigo 2022.2 will continue to allow older (Python 2.7) plugins to run, but you will see a warning in the Event Log and they will be marked with a yellow status icon in the Plugins menu indicating that they won't be compatible with future versions of Indigo. Check the Plugin Store and Plugin user forum for updates to the 3rd party plugins you are using.
Moving an Indigo Installation to another Mac
  1. Deactivate Indigo on your Mac by selecting the Indigo 2022.2→License Details… menu item and clicking the Deactivate License button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first)
  2. Copy this folder over to the new Mac: /Library/Application Support/Perceptive Automation/Indigo 2022.2/ (if restoring from a backup, you'll need to locate this folder in whatever backup system you use)
  3. Install Indigo 2022.2 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2022.2→License Details… menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2022.2 menu if the server is still running before you quit the Indigo Mac Client).
Uninstalling the Mac Client
  • ~(your user folder)/Library/Preferences/Indigo 2022.2 Client Prefs.indiPref
  • ~(your user folder)/Library/Preferences/Indigo 2022.2 Client Settings.indiPref
To uninstall older versions but leave 2022.2 installed correctly, delete these:
  • Indigo 2021.2:
  • Indigo 2021.1:
  • Indigo 7.5:
  • Indigo 7.4:
  • Indigo 7.3:
  • Indigo 7.2:
  • Indigo 7.0 and 7.1:
    • /Applications/Indigo 7.app
    • /Applications/Indigo 6.app
Starting Indigo Server
  1. Double click the Indigo 2022.2 application (/Applications/Indigo 2022.2.app).
  2. If this is the first time to run Indigo 2022.2 on this Mac, then press the Start Local Server… button in the connection status window.
  3. If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the Indigo 2022.2→Start Local Server… menu item.
Standard startup mode
Use the Also allow HTTP Basic authentication (less secure) checkbox to enable HTTP Basic authentication. This setting allows you to insert the username/password in the URL line. Older services may require this, though we recommend against using it.
Custom single app startup
Starting the Server
Remote Indigo Access
Modifying Firewall Settings
  2. Double click the Indigo 2022.2 application (inside /Applications/Indigo 2022.2.app) on the remote Mac.
  4. If you are wanting to connect to a different Indigo Server, then select the Indigo 2022.2→Connect to Remote Server… menu item.
  7. Press the Connect button.
Indigo Touch, the iPhone and iPod Touch application from Indigo Domotics, allows the user to view and control Devices, activate Action Groups, view Variables, and access custom Control Pages. One of the best features of Indigo Touch is it's ability to automatically detect and configure network connections. If your iPhone (or iPod Touch) is connected to your local wireless LAN, then it should automatically discover your server. In Indigo Touch, tap the Settings button. You should see the name of your Database in the list. Tap on it, and it will connect (it will ask for your username/password if you have one set, but it will remember it going forward so you won't have to type it in again).
 http://192.168.1.23:8176/
Managing Plugins
Installing Plugins
  1. In Safari on your Indigo Server Mac, go to the Plugin Store and navigate to the Plugin you want to install.
  4. When the download is complete, click on the down arrow in the title bar which will show the plugin download.
  8. You will be switched to the Indigo Client app, and you'll a dialog window which asks you if you want to install and enable the plugin
  9. NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the Open With menu item, then select Indigo 2022.2.
  11. Done!
Plugin Menus in Indigo
Main Plugins Menu
  • a gray dot means the plugin is disabled
  • a green dot with no arrows means the plugin is enabled
  • a green dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version
  • a green dot with a red arrow means the plugin is enabled and there is an update available but it won't work with your version of Indigo
There is also a yellow version of the green dots - the meaning is the same as the green version except it's indicating that the plugin is using an API version that will be deprecated in an upcoming release. You should check the Plugin Store for an updated version or contact the plugin developer.
  • a yellow dot with no arrows means the plugin is enabled but needs updating before the next Indigo release
  • a green dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version - you should install the update before upgrading to the next version of Indigo
Individual Plugin Submenu
The next section contains:
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2022.2→Preferences… menu item and clicking the Plugins tab or by selecting the Plugins→Manage Plugins… menu item discussed above.
Uninstalling a Plugin
  2. Switch back to Indigo and shut down the Indigo Server by selecting the Indigo 2022.2→Stop Server menu item in the Mac client (you can leave the client app running).
  3. In the Finder window opened in step 1, you'll see two folders: Plugins and Plugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin.
  4. Switch back to the Indigo 2022.2 Mac client and click on the Start Local Server… button in the Server Connection Status dialog.
  • Choose the Indigo 2022.2→Preferences… menu item, then make sure the Sunset & Sunrise tab is selected.
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2022.2→Preferences… menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2022.2→Check for Updates… menu item.
Where to Go Next
indigo_2022.2_documentation/getting_started.txt · Last modified: 2023/02/23 21:47 by jay
