Email+
SMTP Server Image
Sending an Email
In the Actions tab, you can use the Notification Actions→Send Email action to send an email:
SMTP Send Email Image
The format can be either plain text or HTML (it is your responsibility to ensure that the Message field contains a valid HTML document - we don't attempt to validate it). Variable (%%v:VariableIDHere%%) and device state (%%d:DeviceIDHere:StateIDHere%%) substitutions are available in all fields, and you can specify attachments by entering the full path to a file, each file separated by commas.
Sending Event Log Data
In the Actions tab, you can use the Notification Actions→Send Indigo Log Email action to send parts of your Event Log lines:
SMTP Send Log Image
Email+ Actions
Poll Email Server Actions
1. You can use the Email+ Actions→Poll All Email Servers item to poll all configured SMTP servers to query for new messages.
2. You can use the Email+ Actions→Poll Email Server item to poll a specific SMTP server for new messages.
Email Queue Actions
3. You can use the Email+ Actions→Clear All Email Queues item to clear out all queued emails from all of your SMTP servers. If your email server is having issues, you may find that you want to clear out all pending emails that the plugin has queued up for your email server.
4. You can use the Email+ Actions→Clear Email Queue item to clear out the email queue for a specific SMTP server.
IMAP Server
IMAP Server Image
IMAP Mailbox Naming
  • Processed
  • INBOX/Processed
  • INBOX.Processed
POP Server
POP Server Image
Email Event List Image
MessageType: messageReceived
Returns dictionary:
	'messageFrom':  	<text string>,
	'messageTo': 		<text string>,
	'messageSubject': 	<text string>,
	'messageText': 		<text string>
MessageType: messageSent
Returns dictionary:
  • Processed
  • INBOX/Processed
  • INBOX.Processed
    if plugin.isEnabled():
        plugin.executeAction(
            "sendEmail",
            deviceId=12345678,
            props={
                'emailTo':'[email protected]',
                'emailSubject': subject,
                'emailMessage': message
    return
props = {
        "sendEmail",
        deviceId=12345678,
        props=props
  • /www/perceptive/wiki/data/pages/indigo_2022.2_documentation/plugins/email.txt
