Email+
Email Devices and Usage
Sending an Email
In the Actions tab, you can use the Notification Actions→Send Email action to send an email:
The format can be either plain text or HTML (it is your responsibility to ensure that the Message field contains a valid HTML document - we don't attempt to validate it). Variable (%%v:VariableIDHere%%) and device state (%%d:DeviceIDHere:StateIDHere%%) substitutions are available in all fields, and you can specify attachments by entering the full path to a file, each file separated by commas.
Sending Event Log Data
In the Actions tab, you can use the Email+ Actions→Send Indigo Log Email action to send parts of your Event Log lines:
Email Queue Management Menu Items
You can use the Plugins→Email+→Clear All Email Queues to clear out all queued emails from all of your SMTP servers. If your email server is having issues, you may find that you want to clear out all pending emails that the plugin has queued up for your email server.
You can use the Plugins→Email+→Clear Email Queue… to clear out the email queue for a specific SMTP server.
Receiving Emails
IMAP Server
IMAP Mailbox Naming
  • Processed
  • INBOX/Processed
  • INBOX.Processed
POP Server
Incoming Email Events
Broadcast Messages
MessageType: messageReceived
Returns dictionary:
	'messageFrom':  	<text string>,
	'messageTo': 		<text string>,
	'messageSubject': 	<text string>,
	'messageText': 		<text string>
MessageType: messageSent
Returns dictionary:
Tips on IMAP Mailbox Naming
  • Processed
  • INBOX/Processed
  • INBOX.Processed
Scripting Emails
    if plugin.isEnabled():
        plugin.executeAction(
            "sendEmail",
            deviceId=12345678,
            props={
                'emailTo':'foo@bar.com',
                'emailSubject': subject,
                'emailMessage': message
    return
props = {
        "sendEmail",
        deviceId=12345678,
        props=props
indigo_2022.2_documentation/plugins/email.txt · Last modified: 2023/03/03 00:45 by davel17
