Inside that directory are the versions that either we have installed (2.7, 3.10 etc.) or which might have been installed by you if you downloaded a Python installer from python.org. Which ones are present is based on the Indigo release you're using. Since Indigo 2022.1, Indigo has been using Python 3.10. In all versions of Indigo 2022, we also install Python 2.7 to enable backwards compatibility for old plugins. Note: This will no longer happen starting with 2023.1: while we will not remove any previously installed Python 2.7, we will no longer install or use it in any way.
  1. /Library/Frameworks/Python.framework/Versions/3.10/bin/python3 - this is the most explicit way to start up the 3.10 interpreter installed by Indigo. The downside is that when we (eventually) upgrade to Python 3.11, using this specific path (in, perhaps, a shebang at the top of a Python script) will then point to the wrong version.
  2. /usr/local/bin/python3.10 - this is a symlink to the above option, and has the same downside. In addition, though, since it's a symlink in a more public directory, it could get updated by something else entirely.
  3. /Library/Frameworks/Python.framework/Versions/Current/bin/python3 - this option will overcome option 1's downside because the Python 3.11 installer will change the Current component (which is a symlink) to point to the 3.11 install. The downside to this is that if you (for some reason) install an older version, the installer might update that link to point to the older version.
  4. /usr/local/bin/python3 - this option is created/maintained by the Python installer as well, so it has the same benefits/issues of the last option, but also since it's a symlink it could get munged by some other installer (homebrew/macports).
  1. /Library/Frameworks/Python.framework/Versions/3.10/bin/pip3 - this is the most explicit way to start up the 3.10 interpreter installed by Indigo. The downside is that when we (eventually) upgrade to Python 3.11, using this specific path (in, perhaps, a shebang at the top of a Python script) will then point to the wrong version.
  2. /usr/local/bin/pip3.10 - this is a symlink to the above option, and has the same downside. In addition, though, since it's a symlink in a more public directory, it could get updated by something else entirely.
  3. /Library/Frameworks/Python.framework/Versions/Current/bin/pip3 - this option will overcome option 1's downside because the Python 3.11 installer will change the Current component (which is a symlink) to point to the 3.11 install. The downside to this is that if you (for some reason) install an older version, the installer might update that link to point to the older version.
  4. /usr/local/bin/pip3 - this option is created/maintained by the Python installer as well, so it has the same benefits/issues of the last option, but also since it's a symlink it could get munged by some other installer (homebrew/macports).
Xcode
homebrew & macports
They will insert paths into the various .login, .profile, .bashrc files such that their version of Python (and it's executables) are found first when typing any of the Python commands from the shell without a full path. They set the PYTHONPATH (which is a list of file system paths that the Python interpreter looks in to find modules not part of the standard install like those installed by pip3) so that they look in their own site-packages directories
  • /www/perceptive/wiki/data/pages/indigo_2022.2_documentation/python_version_conflicts.txt
