To create an Airfoil Instance device, click the New…
button above the devices list. In the resulting Create New Device dialog, select Airfoil Pro as the type and you will see the Add Airfoil Instance… dialog:
- an image of the currently playing album track if the source supports it (notably, iTunes)machineIcon.png
- an icon representing the computer that is running this instance of AirfoilmechineIconAndScreenshot.png
- a screenshot from the host computer with the machine icon overlayed (though this functionality seems to be missing in Airfoil versions through v5.1.0 - you just get the same image as the machine icon)sourceIcon.png
- an icon representing the selected audio source in Airfoil.Leave the field empty if you don't wish for the plugin to store these images.
State Key | Value Type | Description |
If you change the name of your Mac, you'll need to perform the Define and Sync…
again - select the correct Airfoil instance in the sync dialog and Save
. Unfortunately, Airfoil doesn't send out a name change notification so the plugin doesn't know what happened other than the instance it was talking to is now gone.
Warning: you can't use the Delete…
button above the device list without deleting ALL the devices in that Airfoil Instance Group. If you need to delete just a single speaker, select the Plugins→Airfoil Pro→Permanently Delete Speaker
menu item. This will allow you to just delete a single speaker.
volume | number | The volume that the speaker is currently set to. |
The Airfoil plugin provides a variety of actions that allow you to fully manage an Airfoil Instance and Speakers. We'll separate these into Speaker actions and Instance actions. These actions are available on the Type:
menu in the actions edit dialog under Device Actions→Airfoil Pro Controls
submenu.
Action id: connect
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "connect", deviceId=135305663, # ID of Speaker device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: disconnect
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "disconnect", deviceId=135305663, # ID of Speaker device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: toggle
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "toggle", deviceId=135305663, # ID of Speaker device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Example 1 (no groups):
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "saveCurrentSpeakerStates", deviceId=135305663, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Example 2 (include groups):
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: # This time, we'll add the includeAirfoilGroups property that will also store group states result = airfoilPlugin.executeAction( "saveCurrentSpeakerStates", deviceId=135305663, # ID of Airfoil device props={"includeAirfoilGroups": True}, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "restoreSavedSpeakerStates", deviceId=135305663, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: setVolume
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'setVolume', deviceId=135305663, # ID of Speaker device props={'volume': 50}, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: increaseVolume
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'increaseVolume', deviceId=135305663, # ID of Speaker device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Example 2 (specifying delta):
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'increaseVolume', deviceId=135305663, # ID of Speaker device props={'volume': 15}, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: decreaseVolume
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'decreaseVolume', deviceId=135305663, # ID of Speaker device props={'volume': 15}, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'disconnectAllSpeakers', deviceId=12345678, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: changeSource
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: props = {"sourceGroup": "systemAudio", "source": "com.rogueamoeba.source.systemaudio" } result = airfoilPlugin.executeAction( "changeSource", deviceId=1346588091, # ID of Airfoil device props=props, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: saveCurrentSource
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "saveCurrentSource", deviceId=1346588091, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: restoreSavedSource
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "restoreSavedSource", deviceId=1346588091, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: playPause
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'playPause', deviceId=12345678, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: nextTrack
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'nextTrack', deviceId=12345678, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: prevTrack
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'prevTrack', deviceId=12345678, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Action id: getSources
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'showSources', deviceId=12345678 # ID of Airfoil device ) except Exception as e: print(f"Exception occurred: {e}")
Data : (dict) audioDevices : (list) Item : (dict) friendlyName : Apple USB audio device (string) icon : [SNIP] identifier : AppleUSBAudioEngine:Apple Inc.:Apple USB audio device:241000:2,1 (string) Item : (dict) friendlyName : Built-in Microphone (string) icon : [SNIP] identifier : AppleHDAEngineInput:1B,0,1,0:1 (string) Item : (dict) friendlyName : USB audio CODEC (string) icon : [SNIP] identifier : AppleUSBAudioEngine:Burr-Brown from TI:USB audio CODEC:400000:2,1 (string) recentApplications : (list) Item : (dict) friendlyName : iTunes (string) icon : [SNIP] identifier : /Applications/iTunes.app (string) Item : (dict) friendlyName : iMovie (string) icon : [SNIP] identifier : /Applications/iMovie.app (string) systemAudio : (list) Item : (dict) friendlyName : System Audio (string) icon : [SNIP] identifier : com.rogueamoeba.source.systemaudio
