The Indigo Reflector Service
About Reflectors
Reflectors provide:
- Hassle free setup:
Activating your Reflector
- Choose the
Allow remote accesscheckbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet. - Turn on the
Enable secure internet access via Indigo Reflectorcheckbox. - Press the
Activate Reflectorbutton.
Indigo 2023.1→Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Preferences/ - In the resulting Finder window, delete the folder named
Bandwidth Limits
Troubleshooting
- failed to create reflector connection: reflector not active - try the steps above to reset your reflector's activation
- reflector connection test failed: local server unreachable - check this forum post for the likely causes.
- Unable to authenticate with IndigoDomo.com (server might be down temporarily for maintenance) - you may be able to resolve the issue by:
- shuting down the Indigo Server,
- deleting the registration file located at
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Preferences/Indigo Registration.indiPref, - restarting the Indigo Server, and
- when prompted, enter your Indigo Account information.
