Send Scene Decrease
indigo.insteon.sendSceneDecrease(11)
indigo.insteon.sendSceneDecrease(11, repeatCount=5)
indigo.insteon.sendSceneDecrease(11, suppressLogging=True)
indigo.insteon.sendSceneDecrease(11, updateStatesOnly=True)
indigo.insteon.sendSceneDecrease("working in office scene")
repeatCount No integer a value from 1-32 for the number of times to repeat the decrease (default is 1)
suppressLogging No boolean True if if entries in the event log should be suppressed (default is False)
Send Scene Increase
indigo.insteon.sendSceneIncrease(11)
indigo.insteon.sendSceneIncrease(11, repeatCount=5)
indigo.insteon.sendSceneIncrease(11, suppressLogging=True)
indigo.insteon.sendSceneIncrease("working in office scene")
repeatCount No integer a value from 1-32 for the number of times to repeat the increase (default is 1)
Send Scene ON
sendCleanUps No boolean True if if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might effect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True)
Send Scene OFF
Send Scene Fast ON
Send Scene Fast OFF
Send Scene Start Change
This command will tell the specified PowerLinc scene to begin increasing/decreasing in value. It will continue to ramp each device in the scene until either the corresponding Send Scene Stop Change command is called or until the devices are at 100% for increase ramping or 0% for decrease ramping.
indigo.insteon.sendSceneIncrease(11, increase=True)
increase Yes boolean True if you want to ramp up, False if you want to ramp down
This command will tell the specified PowerLinc scene to stop any ramping activity started by a Send Scene Start Change command.
Send Status Request
direct parameter Yes string the target INSTEON address as a hexidecimal string.
waitUntilAck No boolean true if the caller wants to wait for the result. (default is True)
Send Raw
cmdBytes Yes list a list of 2 integer bytes that represent the command to be sent.
waitUntilAck No boolean True if the caller wants to wait for the result. (default is True)
waitForStandardReply No boolean True if the caller wants to wait for a follow-up direct standard reply. (default is False)
waitForExtendedReply No boolean True if the caller wants to wait for a follow-up direct extended reply. (default is False)
Send Raw Extended
if reply.cmdSuccess:
	indigo.server.log("     backlight brightness: %d" % (reply.replyBytes[10],))
	indigo.server.log("     button states bitmap: 0x%02X" % (reply.replyBytes[12],))
setKeypadLedBrightness = [
	0x2E, 0x00,
	0x00,			# unused
	0x07,			# change LED backlight brightness
	0x11,			# brightness between 0x11 and 0x7F
cmdBytes Yes list a list of 2 to 16 integer bytes that represent the command to be sent.
calcCrc No boolean automatically calculate 8 bit CRC byte for message (used by i2CS firmware). (default is True)
calc16bitCrc No boolean automatically calculate 16 bit CRC byte for message (used by specific modules). (default is False)
Send PowerLinc SET Button Press Message
Subscribe to Events
Use the lower-level subscribeToIncoming() and subscribeToOutgoing() methods in the indigo.insteon command space to see commands regardless of their effect on device state.
Low Level Commands
    def startup(self):
        self.logger.debug("startup called -- subscribing to all INSTEON commands")
    def insteonCommandReceived(self, cmd):
        self.logger.debug(f"insteonCommandReceived: \n{str(cmd)}")
    def insteonCommandSent(self, cmd):
        self.logger.debug(f"insteonCommandSent: \n{str(cmd)}")
indigo_2023.1_documentation/insteon_specific_commands.txt · Last modified: 2023/09/05 19:47 (external edit)
