Airfoil Pro
Airfoil Device Types
Airfoil Instance
Adding an Instance
To create an Airfoil Instance device, click the New…
button above the devices list. In the resulting Create New Device dialog, select Airfoil Pro as the type and you will see the Add Airfoil Instance… dialog:
- an image of the currently playing album track if the source supports it (notably, iTunes)machineIcon.png
- an icon representing the computer that is running this instance of AirfoilmechineIconAndScreenshot.png
- a screenshot from the host computer with the machine icon overlayed (though this functionality seems to be missing in Airfoil versions through v5.1.0 - you just get the same image as the machine icon)sourceIcon.png
- an icon representing the selected audio source in Airfoil.
States available to Scripts
State Key | Value Type | Description |
Notes
If you change the name of your Mac, you'll need to perform the Define and Sync…
again - select the correct Airfoil instance in the sync dialog and Save
. Unfortunately, Airfoil doesn't send out a name change notification so the plugin doesn't know what happened other than the instance it was talking to is now gone.
Speaker
Warning: you can't use the Delete…
button above the device list without deleting ALL the devices in that Airfoil Instance Group. If you need to delete just a single speaker, select the Plugins→Airfoil Pro→Permanently Delete Speaker
menu item. This will allow you to just delete a single speaker.
volume | number | The volume that the speaker is currently set to. |
Airfoil Actions
The Airfoil plugin provides a variety of actions that allow you to fully manage an Airfoil Instance and Speakers. We'll separate these into Speaker actions and Instance actions. These actions are available on the Type:
menu in the actions edit dialog under Device Actions→Airfoil Pro Controls
submenu.
Speaker Actions
Connect Speaker
Scripting details
Action id: connect
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "connect", deviceId=135305663, # ID of Speaker device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Disconnect Speaker
Scripting details
Action id: disconnect
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "disconnect", deviceId=135305663, # ID of Speaker device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Toggle Speaker
Scripting details
Action id: toggle
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "toggle", deviceId=135305663, # ID of Speaker device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Save Current Speaker States
Scripting details
Example 1 (no groups):
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "saveCurrentSpeakerStates", deviceId=135305663, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Example 2 (include groups):
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: # This time, we'll add the includeAirfoilGroups property that will also store group states result = airfoilPlugin.executeAction( "saveCurrentSpeakerStates", deviceId=135305663, # ID of Airfoil device props={"includeAirfoilGroups": True}, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Restore Saved Speaker States
Scripting details
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "restoreSavedSpeakerStates", deviceId=135305663, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Set Volume
Scripting details
Action id: setVolume
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'setVolume', deviceId=135305663, # ID of Speaker device props={'volume': 50}, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Increase Volume
Scripting details
Action id: increaseVolume
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'increaseVolume', deviceId=135305663, # ID of Speaker device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Example 2 (specifying delta):
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'increaseVolume', deviceId=135305663, # ID of Speaker device props={'volume': 15}, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Decrease Volume
Scripting details
Action id: decreaseVolume
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'decreaseVolume', deviceId=135305663, # ID of Speaker device props={'volume': 15}, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Airfoil Instance Actions
Disconnect All Speakers
Scripting details
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'disconnectAllSpeakers', deviceId=12345678, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Change Source
Scripting details
Action id: changeSource
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: props = {"sourceGroup": "systemAudio", "source": "com.rogueamoeba.source.systemaudio" } result = airfoilPlugin.executeAction( "changeSource", deviceId=1346588091, # ID of Airfoil device props=props, waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Save Current Source
Scripting details
Action id: saveCurrentSource
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "saveCurrentSource", deviceId=1346588091, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Restore Saved Source
Scripting details
Action id: restoreSavedSource
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( "restoreSavedSource", deviceId=1346588091, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Toggle Play/Pause
Scripting details
Action id: playPause
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'playPause', deviceId=12345678, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Next Track
Scripting details
Action id: nextTrack
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'nextTrack', deviceId=12345678, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Previous Track
Scripting details
Action id: prevTrack
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'prevTrack', deviceId=12345678, # ID of Airfoil device waitUntilDone=True ) except Exception as e: print(f"Exception occurred: {e}")
Airfoil Scripting Actions
getSources
Action id: getSources
plugin_id = "com.perceptiveautomation.indigoplugin.airfoilpro" # Get a plugin object given the plugin id: airfoil_plugin = indigo.server.getPlugin(plugin_id) if airfoilPlugin.isEnabled(): try: result = airfoilPlugin.executeAction( 'showSources', deviceId=12345678 # ID of Airfoil device ) except Exception as e: print(f"Exception occurred: {e}")
Data : (dict) audioDevices : (list) Item : (dict) friendlyName : Apple USB audio device (string) icon : [SNIP] identifier : AppleUSBAudioEngine:Apple Inc.:Apple USB audio device:241000:2,1 (string) Item : (dict) friendlyName : Built-in Microphone (string) icon : [SNIP] identifier : AppleHDAEngineInput:1B,0,1,0:1 (string) Item : (dict) friendlyName : USB audio CODEC (string) icon : [SNIP] identifier : AppleUSBAudioEngine:Burr-Brown from TI:USB audio CODEC:400000:2,1 (string) recentApplications : (list) Item : (dict) friendlyName : iTunes (string) icon : [SNIP] identifier : /Applications/iTunes.app (string) Item : (dict) friendlyName : iMovie (string) icon : [SNIP] identifier : /Applications/iMovie.app (string) systemAudio : (list) Item : (dict) friendlyName : System Audio (string) icon : [SNIP] identifier : com.rogueamoeba.source.systemaudio
