Email+
Email Devices and Usage
Sending an Email
In the Actions tab, you can use the Notification Actions→Send Email action to send an email.
The format can be either plain text or HTML. Variable (%%v:VariableIDHere%%) and device state (%%d:DeviceIDHere:StateIDHere%%) substitutions are available in all fields.
Sending a Plain Text Email
When sending plain text email messages, simply enter the appropriate text in the Message field.
Sending an HTML Email
When sending an HTML email, it's your responsibility to ensure that the Message field contains a valid HTML document - we don't attempt to validate it. The plugin supports both simple and more complex HTML constructions. For example, a simple HTML message might look like this:
<h1>Heading 1</h1>
<br>
<br>
<span>Some plain text.</span>
More complex HTML documents are also supported:
<!DOCTYPE html>
<html lang="en">
<head>
    <title>A Title</title>
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <style>
        body {
          background-color: whitesmoke;
          color: black;
          font-family: Arial, sans-serif;
        .foo {
          border: solid black 1px;
          color: blue;
          font-size: 10pt;
          padding: 3px;
    </style>
</head>
<body>
    <h2>Heading 2</h2>
    <br><br>
    <span class="foo">Some text with some styling applied.</span>
</body>
</html>
There are several good reference sites for using HTML and CSS such as the Mozilla HTML Reference and CSS Reference.
Sending Attachments
Specify attachments by entering the full path to a file with each file separated by commas. For example,
/Library/Application Support/Perceptive Automation/files/some_file.txt,/Library/Application Support/Perceptive Automation/files/another_file.txt
(It's not necessary to escape spaces within the path.)
Sending Event Log Data
In the Actions tab, you can use the Notification Actions→Send Indigo Log Email action to send parts of your Event Log lines:
Email+ Actions
Poll Email Server Actions
1. You can use the Email+ Actions→Poll All Email Servers item to poll all configured SMTP servers to query for new messages.
2. You can use the Email+ Actions→Poll Email Server item to poll a specific SMTP server for new messages.
Email Queue Actions
3. You can use the Email+ Actions→Clear All Email Queues item to clear out all queued emails from all of your SMTP servers. If your email server is having issues, you may find that you want to clear out all pending emails that the plugin has queued up for your email server.
4. You can use the Email+ Actions→Clear Email Queue item to clear out the email queue for a specific SMTP server.
Receiving Emails
IMAP Server
IMAP Mailbox Naming
  • Processed
  • INBOX/Processed
  • INBOX.Processed
POP Server
Incoming Email Events
Broadcast Messages
MessageType: messageReceived
Returns dictionary:
	'messageFrom':  	<text string>,
	'messageTo': 		<text string>,
	'messageSubject': 	<text string>,
	'messageText': 		<text string>
MessageType: messageSent
Returns dictionary:
Tips on IMAP Mailbox Naming
  • Processed
  • INBOX/Processed
  • INBOX.Processed
Scripting Emails
    if plugin.isEnabled():
        plugin.executeAction(
            "sendEmail",
            deviceId=12345678,
            props={
                'emailTo':'foo@bar.com',
                'emailSubject': subject,
                'emailMessage': message
    return
props = {
        "sendEmail",
        deviceId=12345678,
        props=props
indigo_2023.1_documentation/plugins/email.txt · Last modified: 2023/10/14 19:30 by davel17
