Choose the Plugins→SQL Logger→Configure…
menu item, then select SQLite
as the database type.
psql -U postgres
menu item, then select PostgreSQL
By default Indigo will connect to the PostgreSQL server running on the same Mac (127.0.0.1
) using the default PostgreSQL username of postgres
, and will automatically create a new database named indigo_history
. Your PostgreSQL install might also support local connections directly using the host name /var/pgsql_socket/.s.PGSQL.5432
From the SQL Logging configuration dialog (Plugins→SQL Logger→Configure…
menu item), you can choose which information the plugin should store in the database and specify if older data should automatically be pruned:
and
To find the specific device or variable IDs used in the table name, right-click on the device (or variable) inside Indigo and choose the Copy ID
menu item. Note the SQL Logger also writes to the Event Log any time it creates a new table and shows what table name was created for a specific device or variable.
Columns are automatically created for the tables for every state used by that particular device. For example, here is the device history table for a dimmer switch, device_history_9734822
ts | brightnesslevel | onoffstate |
2012-05-16 16:00:32 | 0 | f |
2012-05-16 16:01:44 | 74 | t |
2012-05-16 16:01:44 | 29 | t |
2012-05-16 16:44:46 | 0 | f |
2012-05-16 16:45:03 | 29 | t |
2012-05-16 16:45:35 | 0 | f |
2012-05-16 18:20:09 | 28 | t |
2012-05-16 19:01:57 | 29 | t |
2012-05-16 19:15:12 | 38 | t |
2012-05-16 19:15:13 | 48 | t |
And here is the table created for a temperature humidity sensor, device_history_12452348
ts | temperature | humidity |
2012-05-16 16:00:32 | 73 | 85 |
2012-05-16 16:01:44 | 74 | 85 |
2012-05-16 16:01:44 | 73 | 85 |
2012-05-16 16:44:46 | 72 | 86 |
2012-05-16 16:45:03 | 71 | 87 |
2012-05-16 16:45:35 | 68 | 87 |
2012-05-16 18:20:09 | 65 | 88 |
2012-05-16 19:01:57 | 67 | 87 |
2012-05-16 19:15:12 | 68 | 86 |
2012-05-16 19:15:13 | 69 | 86 |
Variable tables are similarly created – one table per variable. However, they always have the same columns: ts
and value
. Here is an example table tracking a variable for alarmMode:
ts | value |
2012-05-16 16:00:32 | Idle |
2012-05-16 16:01:44 | Arm Home |
2012-05-16 16:01:44 | Idle |
2012-05-16 16:44:46 | Arm Away |
Lastly, a single table is created to track all event log entries, eventlog_history
Note that when selecting the timestamp from a SQLite table you must use the notation datetime(ts,'localtime')
so that the internally stored GMC time is translated to your local time.
The SQL Logger provides a useful event (even if it's not logging anything): Error in Event Log
. This event will fire whenever an error (generated by the Indigo Server, by plugins, or both) appears in the event log. You can perform any actions (like sending an email, etc.).
Indigo Internal Errors
are errors generated by the IndigoServer directly - so errors from INSTEON and X10 devices, errors with the built-in actions/events (sending emails), etc. These do not include errors that plugins generate or errors that are inserted from scripts.
To use the Specific Type
event type, you'll need to use the error type that's shown in the event log window. The error type is the beginning part of an event log line. Each event log entry has a beginning part, then a series of spaces, then the message. The beginning part is the event type. Error event types will always end in the word “Error”. Here are some examples:
Aug 9, 2012 3:38:10 AM My Type Error this is an error from a script NOAA Weather Plus Error Error parsing XML from NOAA for device Weather Forecast: not well-formed (invalid token): line 1, column 111
In the configuration dialog for Error in Event Log
, when you select Specific Type
from the Errors to monitor for:
popup, a text field with the label Event Type
will show. You'll enter the text shown above - so for instance if you want to monitor for the first error, you'd enter “My Type Error” in the text field (notice no spaces/tabs before or after). Then, every time an error of that type is detected by the SQL Logger plugin, it will fire that trigger.
