This page describes how Indigo 2023.1.0 works with Python, specifically with respect to packages/libraries.
Indigo 2023.1 shipped with API version 3.3 (API 3.3 involved internal changes – most developers should use API 3.2) and is the first version to contain support for Python version 3 (check the API Version Chart to see what version of the API is available in which Indigo versions). With this version of the API, Python 2 and Python 3 are now automatically installed as part of the Indigo installer. For Indigo 2023.1, we are including both Python 3.10.2 and Python 2.7.18 (for backwards compatibility - it is an x86 install and will require Rosetta to run on Apple Silicon Macs). The Python 2.7.18 install was specifically added because macOS 12.3 removed its Python install and is a transitional step only. Python 2 and support for APIs < 3.0 will be removed in Indigo 2023.1 later this year.
The Indigo 2023.1 installer includes the Python 3.10.2 installer (includes Intel and Apple Silicon support) from https://www.python.org - the official Mac installers for the Python language. As a result, any installs of other versions of Python from that website may cause unexpected results in Indigo and potentially cause it to break. We've taken all precautions we can to try and avoid conflicts, but there is only so much we can do. So please use caution when installing other Python versions to your server machine. If you have any questions about other Python versions, post your questions on our forums. Indigo 2023.1 no longer includes the Python 2.7.18 installer but it will not remove any previously installed Python 2.
As noted above, Indigo 2023.1 ships with Python 3.10 and which contains several modules in addition to Python's standard core modules. The specific modules installed with each version of Python are listed below. However, in some instances, you may need to manually install one or more additional Python packages to support a third-party plugin or your own custom scripts. The manner in which this is done, depends on the Indigo API version that the plugin supports.
Use pip3 install [package]
commands to install packages:
To see which packages are installed, use the list
command:
Note: Some Python packages – and specifically those that are included in IPH3 as described below – will not appear in the pip3 list
output.
To see more detailed information about an individual package, use the show
command.
Last login: Sun Mar 27 10:20:04 on ttys000 user@my mac ~ % pip3 show requests Name: requests Version: 2.27.1 Summary: Python HTTP for Humans. Home-page: https://requests.readthedocs.io Author: Kenneth Reitz Author-email: me@kennethreitz.org License: Apache 2.0 Location: /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages Requires: charset-normalizer, certifi, idna, urllib3 Required-by: user@my mac ~ %
Particularly helpful in the show
output is the dependencies information – both what the package requires and what requires the package. Note that the dependencies information may not include information about packages that are included with the IPH.
Installing additional Python versions on the Indigo 2023.1 server machine is NOT recommended (see above). Installing additional Python modules should only be done when necessary.
Because the packages included with Indigo should not be modified (to ensure a smoothly running server), plugin developers must include any other desired version within the plugin package. Plugin developers should note that some Python packages will not integrate universally across all installations as they rely on code compiled for specific hardware configurations (for example, Intel vs. Apple silicon). The IPH processes use the following Module Search Paths (Python interpreters use PYTHONPATH
to describe the order of directories to search for installed packages, the first matching package will be used):
The PYTHONPATH
for IPH3 is:
Contents/Server Plugin
(inside the plugin bundle)Contents/Packages
(inside the plugin bundle)/Library/Application Support/Perceptive Automation/Python3-includes
Python#-includes
folders above, and those will be shared across all Indigo Plugins and Scripts.pip3
process. Warning: Indigo will preinstall several packages (listed below) at install time. You should avoid modifying those unless absolutely necessary as other 3rd party plugins may rely on them.
If you are going to instruct users to install packages that support your plugin using pip
, you should probably do one of the following:
which will install the libraries to the specified folder that exists in your plugin bundle. It is strongly recommended that you use the Packages
folder as this may be required in future versions of Indigo.
If your users will need to install multiple packages, it may be easier to specify those in a “requirements.txt” file within your plugin bundle. The following pip command will attempt to install all the packages listed in the file.
pip3 install -r requirements.txt -t /Path/To/Plugin/Contents/Packages/
There are some important implications that result from having some libraries included in the IPH3. Namely, those packages will be available to plugins, Indigo scripts (embedded and linked), the Indigo python shell (from the menu item or by doing indigo-host
in a terminal window), but IPH3 libraries will NOT be available if you start the python interpreter directly (by doing python2 or python3 in a terminal window). Refer to this chart to determine accessibility:
Method | Access to IPH3 Libraries |
plugins | yes |
embedded scripts | yes |
linked scripts | yes |
Indigo python shell using Indigo menu | yes |
If you need a module/package for your plugin, you can install it via pip3
as shown above, which will install it into the Python site-packages
folder. We recommend (but don't require) the following folders be used for custom scripts and modules:
folder. (Indigo versions prior to 2022 should use the /Library/Application Support/Perceptive Automation/Python2-includes
folder).Warning 1: as mentioned above, Indigo will preinstall several packages (listed below) at install time. You should avoid modifying those unless absolutely necessary as other 3rd party plugins may rely on them.
Warning 2: you should use caution when naming your custom scripts to ensure they don't supplant other Python packages. For example, if you install the holidays Python package using pip3 install holidays
, it will be installed in the site-packages folder. If you also have a custom script in the Python3-includes
folder named holidays.py, the IPH will import your script instead of the site-packages version (because the Python3-includes folder is searched before the site-packages folder).
Indigo 2023.1 ships with support for the following Python 3 packages in addition to the packages installed with the standard Python framework. Generally, if earlier versions of the listed packages are installed at the location Indigo uses, they will be upgraded to the version numbers below.
Included inside IPH 3 Unmodifiable | PIP installed by Indigo PIP Modifiable (but not recommended) |
Python Package | Version | Python Package | Version |
py-applescript | 1.0.3 | cycler | 0.11.0 |
certifi | 2021.10.8 | cryptography | 41.0.1 |
charset_normalizer | 2.0.12 | - cffi | 1.15.1 |
python-dateutil | 2.8.2 | - pycparser | 2.21 |
idna | 3.3 | dictdiffer | 0.9.0 |
jedi | 0.18.1 | fonttools | 4.31.2 |
oauthlib | 3.2.0 | future | 0.18.2 |
packaging | 21.3 | httpx | 0.23.3 |
parso | 0.8.3 | - anyio | 3.6.2 |
pudb | 2022.1.0 | - certifi | 2022.12.7 |
pyaes | 1.3.0 | - h11 | 0.14.0 |
pygments | 2.11.2 | - httpcore | 0.16.3 |
pyparsing | 3.0.7 | - idna | 3.4 |
pyserial | 3.5 | - rfc3986 | 1.5.0 |
requests | 2.27.1 | - sniffio | 1.3.0 |
requests-oauthlib | 1.3.1 | janus | 1.0.0 |
urllib3 | 1.26.8 | - typing_extensions | 4.4.0 |
urwid | 2.1.2 | Jinja2 | 3.1.2 |
xmljson | 0.2.1 | kiwisolver | 1.4.0 |
MarkupSafe | 2.1.1 | ||
matplotlib | 3.5.1 | ||
numpy | 1.22.3 | ||
packaging | 21.3 | ||
Pillow | 9.0.1 | ||
pyparsing | 3.0.7 | ||
python-dateutil | 2.8.2 | ||
pyobjc | 8.4.1 | ||
sanic | 22.6.1 | ||
- aiofiles | 22.1.0 | ||
- httptools | 0.5.0 | ||
- multidict | 6.0.4 | ||
- sanic-routing | 22.3.0 | ||
- sanic-session | 0.8.0 | ||
- ujson | 5.7.0 | ||
- uvloop | 0.17.0 | ||
- websockets | 10.4 | ||
scipy | 1.8.0 | ||
six | 1.16.0 |
