  1. Choose Indigo 2023.2→Preferences… menu, then make sure the Interfaces tab is selected.
To add a new Insteon device:
  2. Press the New… button at the top of the Home window and select INSTEON from the Type popup.
This is how you initially add an INSTEON device to Indigo. The directions on this dialog are quite self-explanatory. When you click the Start button you'll see the checkboxes turn green when each step is complete, and the Close button will enable when the process is complete. The sync process can take a few minutes to complete. Lamp and appliance devices normally take less than a minute, but KeypadLincs and ControLincs can take a few minutes because of the additional link information needed for all of the buttons.
Defining the Scene
Executing the Scene
    • Group On will command all of the responder modules to their scene-specific brightness using their scene-specific ramp rate duration, if any.
  5. Release the button
Execute Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
if insteonPlugin.isEnabled():
    actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
Set Siren Alarm Sound
Set Siren LED Mode
Set OutletLinc Load Sense
  • /www/perceptive/wiki/data/pages/indigo_2023.2_documentation/managing_insteon_devices.txt
