/Library/Frameworks/Python.framework/Versions/3.11/bin/python3
- this is the most explicit way to start up the 3.11 interpreter installed by Indigo./usr/local/bin/python3.11
- this is a symlink to the above option, and has the same downside. In addition, though, since it's a symlink in a more public directory, it could get updated by something else entirely./Library/Frameworks/Python.framework/Versions/Current/bin/python3
- the downside to this option is that if you (for some reason) install an older version, the installer might update that link to point to the older version./usr/local/bin/python3
- this option is created/maintained by the Python installer as well, so it has the same benefits/issues of the last option, but also since it's a symlink it could get munged by some other installer (homebrew/macports).In the same way discussed above (using the right interpreter), you will find the same options for installing Python packages with pip.
/Library/Frameworks/Python.framework/Versions/3.11/bin/pip3
- this is the most explicit way to start up the 3.11 interpreter installed by Indigo./usr/local/bin/pip3.11
- this is a symlink to the above option, and has the same downside. In addition, though, since it's a symlink in a more public directory, it could get updated by something else entirely./Library/Frameworks/Python.framework/Versions/Current/bin/pip3
- the downside to this is that if you (for some reason) install an older version, the installer might update that link to point to the older version./usr/local/bin/pip3
So far, we've only discussed Python installations that are performed from the macOS installers available on python.org (which we use from our installer). Problems can arise when you (or some installer you run) installs a different 3rd party version of Python. The three most common sources of a 3rd party Python install are: homebrew, macports, and Xcode. Each will leave the existing Indigo-installed Pythons alone (so Indigo will continue to work), but they will insert themselves in unexpected ways, like by altering the PATH in your terminal sessions to point to other locations, unexpectedly replacing symlinks, or my installing into locations that are in your PATH variable before /usr/local/bin
(making it very dangerous to just open a terminal window and typing in python or pip3).
They will insert paths into the various .login
, .profile
, .bashrc
files such that their version of Python (and it's executables) are found first when typing any of the Python commands from the shell without a full path. They set the PYTHONPATH (which is a list of file system paths that the Python interpreter looks in to find modules not part of the standard install like those installed by pip3) so that they look in their own site-packages directories
Let's start with the second one first: they will add their own site-packages
directories (i.e. /opt/local/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
) as well as the one from our Python install (/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
) to PYTHONPATH. This will, on the surface, make it seem that they're working OK because they're finding things that may have been installed prior to their installation.
The problem is that when you install further modules using pip3 (the one they installed for you since you didn't specify a full path), those modules will get installed into their site-packages directory rather than the one from our Python install (/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
). So anything new you install won't be accessible from the Python that Indigo installs and uses. But when you test from a shell script, using the python (the one they installed for you since you didn't specify a full path) command, it works. This is because that command isn't using our Python. This duality makes it very confusing to figure out what's going on because it appears to work from a shell but not from Indigo.
