Create the specified action group.
indigo.actionGroup.create("My Action Group Name", "Description of action group", 123)
| Parameters |
| Parameters |
Display In Remote UI
| Parameters |
| Parameters |
duplicateName | No | string | name for the newly action group trigger |
| Parameters |
| Parameters |
