Create the specified action group.
indigo.actionGroup.create(name="My Action Group Name", description="Description of action group", folder=123)
name Yes stringName of the Action Group
description No stringDescription of the Action Group
folder No integerFolder to put the action group into
Display In Remote UI
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/action_group_class.1728216862.txt.gz
  • Last modified: 2024/10/06 12:14
