Indigo Overview
Object Definition
Here is the device dialog:
Match Raw Packet
One option that is available for all Z-Wave devices is the Match Raw Packet option. This allows you to specify a pattern to watch for in all incoming Z-Wave messages. This is a pretty technical option, but allows for a lot of flexibility if you can decipher the incoming messsages. In the Match bytes field you can specify specific hexidecimal bytes in an incoming message, and you can include * (asterisk) to match 0 or more bytes and ? (question mark) to match exactly one byte. For example:
* 0x7D 0x84 0x07 *
Universal Controls
Light/Appliance Controls
Sprinkler Controls
Thermostat Controls
Fan Speed Controls
Virtual Device Controls
Brand Specific Controls
Insteon
HomeSeer
Inovelli
Zooz
Script and File Actions
Execute Script
Open File
Run Shell Script
Log Actions
Write to Log
Email Event Log Data
Enable/Disable/Reload Actions
Get Contents of URL
Run Apple Shortcut
Use this action type to allow Indigo to fire Apple Shortcuts, provided your server is running a version of MacOS that supports the Shortcuts app. The configuration dialog will present a list of all Shortcuts on the server machine as well as an input field to pass optional text to the selected shortcut when it's run.
Modify Variable
Toggle Variable
Click the Edit Action Settings… button and it will open a dialog (shown above). Here you will select the variable and the values that will be toggled. The first 4 options (true/false, on/off, yes/no, enabled/disabled) on the Toggle values menu are self explanatory (although note that values will be converted to lower-case for comparisons). The last option, Custom Values, will allow you to specify the values. We will first try to match the custom variables without converting to lower case (some unicode characters behave oddly when lowercased) and if we don't find a match then we'll convert. Finally, if nothing matches, we'll just set the value to the first value.
Set Variable to Variable
Send Email
Send Indigo Log Email
Send Raw Z-Wave Command
Inclusion Mode Commands
Start Z-Wave Network Optimize
Execute INSTEON Scene
Send Raw INSTEON Command
To create a new action group:
  • iPhone/iPod touch
  • iPad
Other Editor Features
Page Element Details
Device State
Variable Value
Static Image/Caption
Refreshing Image URL
Server Status Text
Server Status Icon
Client Actions
Server Actions
Show in Browser
  2. if it's too cold outside
    "If dark"
  • /www/perceptive/wiki/data/attic/indigo_2024.1_documentation/overview.1734124045.txt.gz
  • Last modified: 2024/12/13 21:07
