Plugin Testing Guide
Once you've developed a functioning plugin, it's a good idea to add automated methods to test your code before publishing plugins and plugin updates. “Unit testing” is considered a best practice, and Python provides built-in tools to help facilitate it. There are many ways to formulate unit tests, and this guide demonstrates one way to do it. The approach described below has advantages within the Indigo plugin framework because it allows direct access to the IOM (Indigo Object Model). It is extremely important to become familiar with the IOM and Indigo plugin development before attempting to tackle this guide.
Python Unit Testing
Unit Testing Indigo Plugins
Testing Elements
- The
python-dotenvlibrary - used for creating and managing Python environment variables. - An IDE that supports unit testing - while not required, having an IDE that supports unit testing can be very helpful.
Testing Structure
Environment Variables
While optional, it is a good idea to create an environment variable framework that allows you to create and make references to elements of your development environment. Once you have installed python-dotenv, create a .ENV file at the Server Plugin level of your plugin (or another location that Indigo's environment path will search). It is a plain text file. The advantage of using an environment file is that it is a great place to store references that are unique to your system and – for shared development – each developer can have their own individual environment. IMPORTANT! Remember to add the .ENV file to your .gitignore list.
.ENV file
Folder Structure
While optional, it's probably best to organize your test files and keep them separate from your main plugin files. For the purposes of this guide, we will store them in a Tests subfolder of the Server Plugin folder. For example,
../Server Plugin
|_ Tests
|_ __init__.py
|_ test_my_plugin.py
|_ ...
Of course, you can put them anywhere your plugin can see them. Depending on your development environment, you may also want to add the Tests folder to your .gitignore file to reduce the footprint of your published plugin.
Main Plugin
You'll need to add a few things to your plugin to support this testing approach.
if result[0] is True:
Test File Structure
This is where the bulk of your testing code will reside. You could add your tests directly to your plugin but, as mentioned above, it offers a way to segregate your testing code from your published plugin to reduce its footprint by adding them to your .gitignore file. There is, of course, wide latitude (and debate) on how to structure tests and this guide tries to evade all that and provide a simple example just to get you started.
Test File Structure
The test_my_plugin.py file contains your testing code. If you're familiar with unit testing (which you should be if you're this deep in the guide), the structure of these tests can be as complex as you like. A simple example:
import dotenv
import indigo # noqa
import logging
import os
from unittest import TestCase
dotenv.load_dotenv()
test_case = TestCase()
class TestPlugin(TestCase):
def __init__(self):
super().__init__()
@staticmethod
return True, None
return False, error
Running Your Tests
except Exception as error:
indigo.server.log(f"{error}")
Action Group Unit Test - Run My Tests My Indigo Plugin Execute Action tests passed. My Indigo Plugin Device creation tests passed. My Indigo Plugin JSON parse tests passed. ...
Even More Tests
- testing the structure of supporting files (like a constants file), or
- using Indigo's integrations API for remote plugin testing.
These approaches are a bit more “traditional”, can often be run directly inside an IDE, and are beyond the scope of this guide.
