Python Packages and Indigo
This page describes how Indigo 2024.1.0 works with Python, specifically with respect to packages/libraries.
Indigo 2024.1 shipped with API version 3.4 and is the first version to contain support for Python version 3 (check the API Version Chart to see what version of the API is available in which Indigo versions). With this version of the API, Python 3 is now automatically installed as part of the Indigo installer. For Indigo 2024.1, we are including Python 3.11.6.
The Indigo 2024.1 installer includes the Python installer (including Intel and Apple Silicon support) from https://www.python.org - the official Mac installers for the Python language. As a result, any installs of other versions of Python from that website may cause unexpected results in Indigo and potentially cause it to break. We've taken all precautions we can to try and avoid conflicts, but there is only so much we can do. So please use caution when installing other Python versions to your server machine. If you have any questions about other Python versions, post your questions on our forums.
Installing Additional Python Packages with Indigo 2024.1
As noted above, Indigo 2024.1 ships with Python 3.11 and which contains several modules in addition to Python's standard core modules. The specific modules installed with each version of Python are listed below. However, in some instances, you may need to manually install one or more additional Python packages to support a third-party plugin or your own custom scripts. The manner in which this is done, depends on the Indigo API version that the plugin supports.
Last login: Sun Mar 27 10:20:04 on ttys000 user@my mac ~ % pip3 show requests Name: requests Version: 2.27.1 Summary: Python HTTP for Humans. Home-page: https://requests.readthedocs.io Author: Kenneth Reitz Author-email: [email protected] License: Apache 2.0 Location: /Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages Requires: charset-normalizer, certifi, idna, urllib3 Required-by: user@my mac ~ %
Installing additional Python versions on the Indigo 2024.1 server machine is NOT recommended (see above). Installing additional Python modules should only be done when necessary.
The PYTHONPATH for IPH3 is:
/Library/Application Support/Perceptive Automation/Python3-includes/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages
pip3process. Warning: Indigo will preinstall several packages (listed below) at install time. You should avoid modifying those unless absolutely necessary as other 3rd party plugins may rely on them.
- When a plugin starts up, it'll look for the
Contents/Server Plugin/requirements.txtfile. If it's not there, we'll continue with plugin startup. If it is there, we'll proceed to the next step. - Indigo will check to see if this file exists:
Contents/Packages/pip-install-log-success.txt. If it does exist (meaning that we've already successfully installed requirements before), we will continue plugin startup. If it doesn't exist, we'll proceed to the next step. - We run
pip3with the requirements file and target theContents/Packagedirectory (all libraries and dependencies will be installed there). If it fails, we output an error and log the install attempt to the Event Log window and stop the plugin. If it installs correctly, we write the install log results to theContents/Packages/pip-install-log-success.txtfile so that the next time it starts it won't do it again (see previous step above).
zeroconf==0.130.0 websocket-client==1.7.0
Troubleshooting:
Manual Installation by User
Using pip:
Logging Import Errors
import_errors = []
import zeroconf
except ImportError:
def startup(self):
if len(import_errors):
msg = f"Required Python libraries missing. Run the following command(s) in a Terminal window to install them, then reload the plugin.\n\n"
for i in import_errors:
self.logger.error(msg)
Access to IPH3 Libraries
| plugins | yes |
| embedded scripts | yes |
| linked scripts | yes |
Python Packages for Scripters
- IndigoPluginHost3
- /Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages
- /Library/Application Support/Perceptive Automation/Scripts – any linked scripts you use for Indigo Schedules and Actions using the “Execute Script (Script and File Actions” command should be stored in this folder.
If Something Goes Wrong
Indigo 2024.1 ships with support for the following Python 3 packages in addition to the packages installed with the standard Python framework. Generally, if earlier versions of the listed packages are installed at the location Indigo uses, they will be upgraded to the version numbers below. The >= symbol means the version installed by Indigo may be newer than the version listed, but will not be older. pyserial is also installed but is installed differently than the other packages listed above and should be unmodifiable.
| PIP installed by Indigo PIP Modifiable (but not recommended) |
| Package | Version |
| certifi | 2023.11.17 |
| charset_normalizer | 3.3.2 |
| cryptography | 41.0.7 |
| - cffi | >= 1.16.0 |
| - pycparser | >= 2.21 |
| cycler | 0.12.1 |
| dictdiffer | 0.9.0 |
| future | 0.18.3 |
| httpx | 0.25.2 |
| - anyio | >= 4.1.0 |
| - certifi | >= 2023.11.17 |
| - h11 | >= 0.14.0 |
| - httpcore | >= 1.0.2 |
| - idna | >= 3.6 |
| - sniffio | >= 1.3.0 |
| idna | 3.6 |
| janus | 1.0.0 |
| - typing_extensions | >= 4.8.0 |
| Jinja2 | 3.1.2 |
| kiwisolver | 1.4.5 |
| MarkupSafe | 2.1.3 |
| matplotlib | 3.8.2 |
| - fonttools | >= 4.45.1 |
| - contourpy | >= 1.2.0 |
| numpy | 1.26.2 |
| oauthlib | 3.2.2 |
| Pillow | 10.1.0 |
| pudb | 2023.1 |
| - jedi | >= 0.19.0 |
| - packaging | >= 23.2 |
| - parso | >= 0.8.3 |
| - pygments | >= 2.17.2 |
| - urwid | >= 2.3.4 |
| - urwid-readline | >= 0.13 |
| py-applescript | 1.0.3 |
| pyaes | 1.6.1 |
| pyobjc | 10.0 |
| pyparsing | 3.1.1 |
| python-dateutil | 2.8.2 |
| requests | 2.31.0 |
| requests-oauthlib | 1.3.1 |
| sanic | 23.6.0 |
| - aiofiles | >= 23.2.1 |
| - httptools | >= 0.6.1 |
| - html5tagger | >= 1.3.0 |
| - multidict | >= 6.0.4 |
| - sanic-routing | >= 23.6.0 |
| - sanic-session | >= 0.8.0 |
| - tracerite | >= 1.1.1 |
| - ujson | >= 5.8.0 |
| - uvloop | >= 0.19.0 |
| - websockets | >= 12.0 |
| scipy | 1.11.4 |
| six | 1.16.0 |
| urllib3 | 2.1.0 |
| xmljson | 0.2.1 |
| pyserial | 3.5 |
