Managing Your Z-Wave® Network
Connecting Z-Wave Interfaces
- Choose the
Configure Z-Wavedialog.
Adding a Z-Wave Device
- Select
Using Encryption
- Select
- Select
Edit…button). - Click the
Syncbutton. - When the
- Select
- When the
Deleting a Z-Wave Device
- Select
- Click the
Replacing a Z-Wave Controller
If your controller doesn't have a physical inclusion button you must follow this process. You may also use this process even if your controller does have a button (such as the Aeotec Z-Stick) as it's the more “universal” approach:
- Select the
- Finally, select the
Z-Wave Menu Options
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
If a Z-Wave device is no longer available to your network (it failed, etc.) then you can use this menu item to remove it from the interface. You might need to attempt a Define and Sync on the device (and allow it to fail) - just create a new device, try to sync it, when it fails then try to remove it.
Reset Z-Wave Interface
