Managing Your Z-Wave® Network
Connecting Z-Wave Interfaces
- Choose the
Configure Z-Wavedialog.
Adding a Z-Wave Device
- Select
Using Encryption
- Select
- Select
Edit…button). - Click the
Syncbutton. - When the
- Select
- When the
Excluding a Z-Wave Device
From time to time, you may find the need to exclude a device from your Z-Wave network. For example:
- you want to factory reset it (resetting doesn't necessarily require a device to be excluded from the network),
- replace a device with a newer device, or
- add a device to your setup that was previously included in another controller.
There are some important points to remember about device exclusion:
- Excluding a device from the controller releases the device from the controller and allows it to be used with another controller.
- If your controller has failed and you want to add your device to a new controller, you can perform the exclusion with your new controller (essentially any controller can exclude a device–even if the device was included with a different controller).
- Just because you've excluded a device from the network, doesn't mean that all the other devices that used to talk to it know it's gone. That's why it's always a good idea to optimize your network after making big changes (adding or removing many devices or changing the location of many devices or the controller).
You can usually preserve your Indigo setup when excluding a device. The Indigo device object and all the things that refer to it are independent of the physical device itself. Simply exclude the first device, include the second one and then point your Indigo device definition to the new device. It will be shown in the Sync using node dropdown as an Available Node ID:
This assumes that you're replacing a device with one that is of a similar type.
To exclude a device:
- Depending on your device, you may need to bring the device into close proximity with the controller. Alternatively, if your controller supports it, you can take your controller to the device.
- Select the
Interfaces→Start Controller Exclusion Mode. - Following your device's instructions, initiate an exclude action (different devices may require different steps).
- If the exclusion has been done successfully, Indigo will automatically exit the exclusion and the device should no longer appear in the Z-Wave device list.
Deleting a Z-Wave Device
- Select
- Click the
Replacing a Z-Wave Controller
If your controller doesn't have a physical inclusion button you must follow this process. You may also use this process even if your controller does have a button (such as the Aeotec Z-Stick) as it's the more “universal” approach:
- Select the
- Finally, select the
Z-Wave Menu Options
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
If a Z-Wave device is no longer available to your network (it failed, etc.) then you can use this menu item to remove it from the interface. You might need to attempt a Define and Sync on the device (and allow it to fail) - just create a new device, try to sync it, when it fails then try to remove it.
Reset Z-Wave Interface
