Triggers
Trigger Base Class
Unlike Devices, you can't call create() in the the trigger base class command namespace (indigo.trigger.*). Rather, each subclass has its own create() method that takes the appropriate arguments for that trigger type.
You will also need to implement triggerStopProcessing(self,trigger) so that you can remove disabled/deleted triggers from your watch list. So, the Server isn't really involved at all with the trigger firing (except to execute the trigger when you tell it to) - it only notifies your plugin of events its supposed to be watching for and your plugin does the rest.
globalProps | dictionary | No | an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
sharedProps | dictionary | No | API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use trigger.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so as to not accidentally remove some other plugin's props). |
Commands (indigo.trigger.*)
indigo.trigger.delete(123) |
| Parameters | |||
| Parameters | |||
Enable/Disable Trigger
| Parameters | |||
duration | No | integer | number of seconds before the trigger is switched back to its original state |
Execute Trigger
| Parameters | |||
depDict = indigo.trigger.getDependencies(123) |
| Parameters | |||
| direct parameter | Yes | integer | id or instance of the trigger to get the dependencies for. |
ID : 552463741 (integer)
ID : 296710860 (integer)
| Parameters | |||
| Parameters | |||
# Change a trigger's name: trigger = indigo.triggers[123] trigger.name = "My new name." trigger.replaceOnServer() # Change a trigger's description: trigger = indigo.triggers[123] trigger.description = "My new description." trigger.replaceOnServer()
DeviceStateChangeTrigger
State Change Type Enumeration
| indigo.kStateChange | ||
State Selector Enumeration
| indigo.kStateSelector | |
BinaryOutputsAll | |
HumidityInput | monitor (one of) the humidity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
KeypadButtonLed | |
folder=1234)
| Parameters | |||
EmailReceivedTrigger
emailFrom | string | Yes | if emailFilter is MatchEmailFields, the value to match against the sender’s address |
emailSubject | string | Yes | if emailFilter is MatchEmailFields, the value to match against the subject line |
Email Filter Enumeration
| indigo.kEmailFilter | |
Commands (indigo.emailRcvd.*)
folder=1234)
| Parameters | |||
theTrigger=indigo.emailRcvd.create(name="Emails from [email protected]") theTrigger.emailFilter = indigo.kEmailFilter.MatchEmailFields theTrigger.emailFrom = "[email protected]" theTrigger.replaceOnServer()
InsteonCommandReceivedTrigger
INSTEON Command Enumeration
| indigo.kInsteonCmd | |
folder=1234)
| Parameters | |||
InterfaceFailureTrigger
folder=1234)
| Parameters | |||
InterfaceInitializedTrigger
folder=1234)
| Parameters | |||
PluginEventTrigger
Create a trigger. You can create triggers using this method of any type except for events that are defined by your plugin (that class, PluginEventTrigger, has its own create() method). This method returns a copy of the newly created trigger. Once a trigger of this type is created, the properties can change (via the pluginProps in the Trigger base class), but nothing else can be changed.
folder=1234),
pluginTypeId="myEvent",
| Parameters | |||
pluginId | No | string | the plugin id of the plugin that owns the device you're creating - if it's not present, it defaults to your plugin's id |
PowerFailureTrigger
folder=1234)
| Parameters | |||
ServerStartupTrigger
folder=1234)
| Parameters | |||
X10CommandReceivedTrigger
X10 Command Enumeration
| indigo.kX10Cmd | |
X10 A/V Button Enumeration
| indigo.kX10AvButton | |
| Value | Value |
0 | Left |
1 | Menu |
2 | Mute |
3 | Pause |
4 | PC |
5 | Play |
6 | Power |
7 | Recall |
8 | Record |
9 | Return |
AB | Rewind |
ChannelDown | Right |
ChannelUp | Stop |
Display | Title |
Down | Up |
Enter | VolumeDown |
Exit | VolumeUp |
Forward | |
folder=1234)
| Parameters | |||
VariableValueChangeTrigger
| indigo.kVarChange | |
folder=1234)
| Parameters | |||
