| Parameters |
Display In Remote UI
| Parameters |
| Parameters |
| Parameters |
| event_data | No | dict | a dictionary instance that will get passed to all actions in the action group for processing |
A note on event_data - Indigo will automatically add a source key to your dictionary to represent where the action execution came from:
However, if you include a source key in your event_data, we will not overwrite it, we'll just pass through whatever your value is.
| Parameters |
