Integration APIs
NOTE:
Versioning
/v2/- this is the top level version number and will change as necessary
Python vs JavaScript
"key1": "value 1",
"key2": 2
| Python | JSON Equivalent |
| True | true |
| False | false |
| float | Number |
| int | Number |
| None | null |
| dict | Object |
| list | Array |
| tuple | Array |
| str | String |
WebSocket API
There are 7 WebSocket feeds that that are available:
/v2/api/ws/device-feed- WebSocket to do all communication about devices/v2/api/ws/variable-feed- WebSocket to do all communication about variables/v2/api/ws/action-feed- WebSocket to do all communication about action groups/v2/api/ws/schedule-feed- WebSocket to do all communication about schedules/v2/api/ws/trigger-feed- WebSocket to do all communication about triggers/v2/api/ws/page-feed- WebSocket to do all communication about control pages/v2/api/ws/log-feed- WebSocket to do all communication about logs
WebSocket Lifecycle
- Setup:
Authentication
Python Receiver Example
import asyncio import json from websockets import connect API_KEY = 'YOUR_API_KEY' # YOUR API KEY HERE DEVICE_ID = 12345678 # YOUR DEVICE ID HERE HEADERS = {"Authorization": f"Bearer {API_KEY}"} URI = "ws://127.0.0.1:8176/v2/api/ws/device-feed" # wss:// if using the reflector async def receiver(ws): try: print("Starting receiver task") # Ask for a refresh of device with ID 12345678 refresh_message = { "id": "initial-device-refresh", "message": "refresh", "objectType": "indigo.Device", "objectId": DEVICE_ID } await ws.send(json.dumps(refresh_message)) counter = 0 device = {} while counter < 20: # just keep looping waiting for a message to come log_string = "ignoring message" message_json = await ws.recv() message = json.loads(message_json) message_type = message['message'] if message_type == "refresh": # This is the response to the refresh message we sent above. It gets us a full copy of the device. device = message["objectDict"] log_string = f"receiver: device refresh message: '{device.get('name', 'unknown')}'" elif message_type == "patch": # There's been a change, so confirm it's the device we want then log the change if message["objectId"] == device["id"]: log_string = f"'receiver: device patch message: {device.get('name', 'unknown')}' update: \n{message_json}" print(f"receiver: loop count: {counter}") print(f"receiver: {log_string}") counter += 1 except Exception as exc: print(f"Exception:\n{exc}") async def sender(ws, count): try: print("Starting sender task") message = { "id": "initial-device-refresh", "message": "refresh", "objectType": "indigo.Device", "objectId": DEVICE_ID } for count in range(10): print(f"sender: loop count: {count}") msg = json.dumps(message) print(f"sender: sending message: {msg}") await ws.send(json.dumps(msg)) await asyncio.sleep(5) except Exception as exc: print(f"Exception:\n{exc}") async def main(): try: async with connect(URI, extra_headers=HEADERS) as websocket: await asyncio.gather(receiver(websocket), sender(websocket, 10)) except Exception as exc: print(f"Exception:\n{exc}") asyncio.run(main())
JavaScript Example
Device Feed
add device message
"message": "add",
objectDict": {
"address": "3B.04.7A",
"batteryLevel": null,
"blueLevel": null,
"brightness": 100,
"buttonConfiguredCount": 0,
"buttonGroupCount": 1,
"configured": true,
"defaultBrightness": 100,
"deviceTypeId": "",
"displayStateValRaw": 100,
"displayStateValUi": "100",
"enabled": true,
"energyAccumBaseTime": null,
"energyAccumTimeDelta": null,
"energyAccumTotal": null,
"energyCurLevel": null,
"errorState": "",
"folderId": 1552926800,
"globalProps": {
"emptyDict": {}
"greenLevel": null,
"id": 1508839119,
"ledStates": [],
"name": "Insteon Dimmer",
"onBrightensToLast": false,
"onState": true,
"ownerProps": {},
"pluginId": "",
"pluginProps": {},
"redLevel": null,
"remoteDisplay": false,
"sharedProps": {},
"states": {
"brightnessLevel": 100,
"onOffState": true
"subModel": "Plug-In",
"subType": "Plug-In",
"supportsAllOff": true,
"supportsColor": false,
"supportsOnState": true,
"supportsRGB": false,
"supportsWhite": false,
"version": 67,
"whiteLevel": null,
"whiteLevel2": null,
"whiteTemperature": null
update device message
"message": "patch",
"objectId": 1508839119,
"patch": [
"change",
"brightness",
[100, 0]
"change",
"displayStateImageSel",
"change",
"displayStateValRaw",
[100, 0]
"change",
"displayStateValUi",
["100", "0"]
"change",
"lastChanged",
"change",
"lastSuccessfulComm",
"change",
"onState",
[true, false]
"change",
"states.brightnessLevel",
[100, 0]
"change",
"states.onOffState",
[true, false]
device refresh messages
"list": []
"objectDict": {}
delete device message
"message": "delete",
"objectId": 123456789
Device messages to the server
device refresh requests
// Specify the object type
device command messages
"objectId": 123456789,
Variable Feed
"class": "indigo.Variable",
"description": "",
"folderId": 0,
"globalProps": {
"id": 345633244,
"name": "house_status",
"pluginProps": {},
"readOnly": false,
"remoteDisplay": true,
"sharedProps": {},
"value": "home"
add variable message
"message": "add",
update variable message
delete variable message
variable refresh messages
variable command messages
updateValue
"parameters": {
"value": "Some string value"
Action Group Feed
"description": "",
"folderId": 532526508,
"globalProps": {
"speakDelayTime": "5",
"id": 94914463,
"name": "Movie Night",
"pluginProps": {},
"sharedProps": {
add action group message
"message": "add",
update action group message
delete action group message
action group refresh messages
action group command messages
Control Page Feed
This is the WebSocket you'll use for all control page-related communication. You will receive the following messages from the Indigo server during the lifetime of the WebSocket. The control page feed has no command messages you can send to the server; rather, its purpose is to use incoming messages to manage a list of the available control pages which (presumably) the user would select to open that page.
"backgroundImage": "",
"description": "",
"folderId": 0,
"globalProps": {},
"hideTabBar": true,
"id": 963336187,
"name": "Weather Images",
"pluginProps": {},
"sharedProps": {}
add control page message
"message": "add",
update control page message
delete control page message
Indigo Object Folders
"id": 617272302,
"class": "indigo.Folder",
"name": "My Device Folder",
refresh folder server message
Log Feed
The only message you will receive on the log feed will be an add message for every new log entry:
"message": "add",
"objectDict": {
"message": "Stopping plugin \"Web Server 2025.1.0\" (pid 1020)",
"typeStr": "Application",
"typeVal": 0
You can also send messages to the log feed from your websocket client with the following payload:
"messageText": "My log message.", // required
"message": "indigo.server.log", // required
HTTP API
HTTP API Endpoints
/v2/api/indigo.devices- endpoint to get a list of devices/v2/api/indigo.devices/123456789- endpoint to get a specific device instance (See Device Objects below)/v2/api/indigo.variables- endpoint to get a list of variables/v2/api/indigo.variables/123456789- endpoint to specific variable object (See Variable Objects below)/v2/api/indigo.actionGroups- endpoint to get a list of action groups/v2/api/indigo.actionGroups/123456789- endpoint to get a specific action group (See Action Group Objects below)/v2/api/command- endpoint to send Indigo a command (device control, variable update, action execution).
Authentication
Getting Device Objects
Getting All Device Objects
- Replace
- Replace
- Replace
- Replace
- Replace
- Replace
Controlling an Indigo Device
- Replace
- Replace
- Replace
- Replace
- Replace
- Replace
Getting Variable Objects
Getting All Variable Objects
- Replace
- Replace
- Replace
- Replace
- Replace
- Replace
Updating a Variable's Value
- Replace
- Replace
- Replace
Getting Action Group Objects
- Replace
- Replace
- Replace
Executing an Action Group
- Replace
- Replace
- Replace
API Messages
Device Messaging
Device Objects
Example device object
"blueLevel": null,
"brightness": 0,
"configured": true,
"deviceTypeId": "",
"displayStateValRaw": 0,
"displayStateValUi": "0",
"enabled": true,
"errorState": "",
"folder": {
"id": 1552926800,
"name": "Insteon",
"globalProps": {},
"greenLevel": null,
"id": 1508839119,
"ledStates": [],
"onState": false,
"ownerProps": {},
"pluginId": "",
"pluginProps": {},
"redLevel": null,
"sharedProps": {},
"states": {
"brightnessLevel": 0,
"onOffState": false
"version": 67,
"whiteLevel": null,
indigo.device
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"value": True,
indigo.dimmer
"parameters": {
"by": 5,
"delay": 10
"parameters": {
"by": 5,
"delay": 10
"parameters": {
"value": 50,
"delay": 10
indigo.iodevice
"parameters": {
"index": 5,
"value": true
indigo.sensor
"parameters": {
"value": true
indigo.speedcontrol
"parameters": {
"by": 2,
"delay": 5
"parameters": {
"by": 2,
"delay": 5
"parameters": {
"value": 2,
"delay": 5
"parameters": {
"value": 50,
"delay": 5
indigo.sprinkler
"parameters": {
"parameters": {
"index": 2
indigo.thermostat
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"value": 76
"parameters": {
"parameters": {
"value": 76
"parameters": {
Variable Messaging
Variable Objects
"description": "",
"folderId": 0,
"folder": {},
"globalProps": {
"id": 345633244,
"pluginProps": {},
"readOnly": false,
"sharedProps": {},
"value": "home"
"parameters": {
Action Group Messaging
"description": "",
"folder": {
"id": 532526508,
"name": "Mood Scenes",
"globalProps": {
"id": 94914463,
"pluginProps": {},
"sharedProps": {
Schedule Messaging
Schedule Objects
You’ll receive full variable JSON objects which represent an Indigo schedule instance. See the Indigo Object Model docs for schedule details.
"class": "indigo.Schedule",
"absoluteDate": null,
"absoluteDateTime": null,
"absoluteTime": null,
"autoDelete": false,
"configured": true,
"dateType": 0,
"description": "",
"enabled": false,
"folderId": 0,
"globalProps": {},
"id": 12345678,
"name": "My Schedule Name",
"nextExecution": null,
"pluginProps": {},
"randomizeBy": 0,
"sharedProps": {},
"sunDelta": 0,
"suppressLogging": false,
"timeType": 3
Schedule Command Messages
These are the available schedule commands. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests. Custom id values should be strings.
execute indigo.schedule.execute(123456789)
"message": "indigo.schedule.execute",
"objectId": 12345678,
objectId is the id of the schedule.
enable
"message": "indigo.schedule.enable",
"parameters": {"value": false}
Trigger Messaging
Trigger Objects
You’ll receive full variable JSON objects which represent an Indigo trigger instance. See the Indigo Object Model docs for trigger details.
"class": "indigo.Trigger",
"configured": true,
"description": "A trigger description.",
"enabled": true,
"folderId": 12345678,
"globalProps": {
"com.indigodomo.webserver": {
"httpMethod": "GET",
"postProcessing": "JSON",
"webhookId": "8aa4b5140c5c473ea170465239143839"
"emptyDict": {}
"id": 12345678,
"name": "My Trigger Name",
"pluginProps": {},
"sharedProps": {},
Trigger Command Messages
These are the available trigger commands. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests. Custom id values should be strings.
execute indigo.trigger.execute(123456789)
"message": "indigo.trigger.execute",
objectId is the id of the trigger.
enable
"message": "indigo.trigger.enable",
Log Messages
Example Log Message
"typeVal": 0
Log Command Message
import requests
API_KEY = "MY_API_KEY"
message = {
device_list = response.json()
print(device_list)
Plugin Messaging
Plugin Command Messages
restart plugin
"message": "plugin.restart",
"pluginId": "com.some.indigo.plugin" # the plugin's bundle identifier
Execute Plugin Action
"actionId": "some_plugin_action", # the ID of the plugin action found in the plugin's Actions.xml file [string]
"deviceId": 12345678, # the device ID targeted by the plugin action (not all actions will require a device ID). [int]
"props": {"prop1": "foo", "prop2": "bar"}, # required if the plugin action requires props to fire the action [valid JSON]
"waitUntilDone": True # optional [True/False]
Error Messaging
Generic Error Message
"validationErrors": {
Example API Call
"parameters": {
"value": 1234.56
Resulting Error Message
message,objectId,parameters, andvalue
Invalid JSON
Example Invalid JSON Message
"error": "invalid JSON"
Web Server Warnings
| 400 | Bad Request | Indicates that the server cannot or will not process the request due to something that is perceived to be a client error (for example, malformed request syntax, invalid request message framing, or deceptive request routing) |
| 401 | Unauthorized | Indicates that the client request has not been completed because it lacks valid authentication credentials for the requested resource. |
Other Errors and Warnings
