  key_value_list = [
	"allowOnStateChange": false,
	"protocol": "ZWave",
	"configured": true,
	"states": {
		"onOffState": true,
		"batteryLevel.ui": "100%",
		"batteryLevel": 100
	"subType": "",
	"globalProps": {
			"zwConfigVals": {},
			"zwShowWakeIntervalUI": true,
			"zwModelId": 0,
			"zwClassIds": [
				4,
				7,
				1
			"zwShowDumpDevToLog": false,
			"zwLibType": 3,
			"SupportsBatteryLevel": true,
			"zwProtoVersMajor": 4,
			"zwEndpointDevTypeMap": {},
			"userWakeInterval": 60,
			"indigoObjVersion": 10,
			"version": "5.01",
			"zwClassCmdMap": {
				"c134": 1,
				"c90": 1,
				"c133": 1,
				"c132": 2,
				"c89": 1,
				"c94": 1,
				"c128": 1,
				"c122": 1,
				"c115": 1,
				"c114": 1,
				"c113": 1,
				"c32": 1
			"SupportsOnState": true,
			"zwShowMainUI": true,
			"zwAppVersMinor": 1,
			"userPollInterval": 0,
			"zwDevSubIndex": 0,
			"zwEncryptClassCmdMap": {},
			"address": 17,
			"zwEndpointClassMap": {},
			"zwModelDefnVers": 0,
			"zwManufactureId": 0,
			"SupportsSensorValue": false,
			"zwAssociationsMap": {
				"g1": [
					1
			"zwShowPollingUI": false,
			"zwWakeInterval": 60,
			"zwClassCmdBase": 0,
			"zwAppVersMajor": 5,
			"zwProtoVersMinor": 5,
			"zwNodeNeighbors": [
				1,
				15,
				16
			"userPollingEnabled": true
	"pluginProps": {},
	"buttonGroupCount": 0,
	"id": 854505717,
	"supportsAllOff": false,
	"errorState": "",
	"remoteDisplay": true,
	"energyAccumBaseTime": null,
	"displayStateValUi": "on",
	"subModel": "",
	"version": "5.01",
	"energyAccumTimeDelta": null,
	"batteryLevel": 100,
	"supportsSensorValue": false,
	"ownerProps": {
		"zwConfigVals": {},
		"zwModelId": 0,
		"zwClassIds": [
			4,
			7,
			1
		"zwLibType": 3,
		"version": "5.01",
		"zwClassCmdMap": {
			"c134": 1,
			"c90": 1,
			"c133": 1,
			"c132": 2,
			"c89": 1,
			"c94": 1,
			"c128": 1,
			"c122": 1,
			"c115": 1,
			"c114": 1,
			"c113": 1,
			"c32": 1
		"zwDevSubIndex": 0,
		"address": 17,
			"g1": [
				1
			1,
			15,
			16
	"description": "",
	"onState": true,
	"energyAccumTotal": null,
	"address": "17",
	"sharedProps": {},
	"folderId": 1145028206,
	"supportsOnState": true,
	"sensorValue": null,
	"energyCurLevel": null,
	"enabled": true,
	"displayStateValRaw": true,
address string No* 1.0 the address for the device. *Plugin developers can change this value for their plugin's devices.
configured boolean No 1.0 true if the device has been fully configured - if it's a plugin device, use this to make sure that the device's config dialog has been run at least once.
sharedProps dictionary No 2.3 an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use dev.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you don't accidentally remove some other plugin's props).
version boolean No* 1.0 indicates the device's version as appropriate. *Plugin developers can change this value for their plugin's devices.
Protocol Enumeration
indigo.kProtocol
Value Description
State Image Sel Enumeration
API v1.18+ only:
indigo.kStateImageSel
Value Description
Closed overrides to show a generic sensor off icon (grey circle)
DoorSensorClosed overrides to show a door sensor closed icon (grey circle)
DoorSensorOpened overrides to show a door sensor opened icon (green circle)
Locked overrides to show a green lock icon
Opened overrides to show a generic sensor off icon (green circle)
Unlocked overrides to show a red lock icon
WindowSensorClosed overrides to show a window sensor closed icon (grey circle)
WindowSensorOpened overrides to show a window sensor opened icon (green circle)
Value Description
replaceOnServer() No 1.0 Because you can't directly modify a device's properties on the server, you have to get a local instance of the device and modify the writable properties as necessary. You then call this method and the device will be updated on the server and changes will be sent out to all connected clients. A few examples appear below this table.
replacePluginPropsOnServer(newPropsdict) Yes 1.0 If you need to make a change to your plugin's property dictionary that's stored as part of the device (see About Plugin Properties below) you just use this method to replace the entire dict with a new one. A typical usage will be to get the property dictionary from the device, make changes to the dict, then use this method to store the new dict. A few examples appear below this table.
dev.replaceOnServer()
dev.name = "My New Name"
# Set Enabled/Disabled state
# Set Remote Display Flag
new_props = dev.pluginProps
new_props['address'] = "abc"
new_props['version'] = "123"  # Indigo UI Firmware field
dev=indigo.devices[123]
    <State id="playStatus">
    <State id="sep1">
    <State id="playlist">
        <ValueType>String</ValueType>
    <State id="album">
    <State id="artist">
    <State id="track">
    <State id="volume">
    <State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
All Off
indigo.device.allOff()
Enumerated Type Description
Beep
indigo.device.beep(123)
    address='F8',
    name='Device Name Here',
    folder=1234)
deviceTypeId Yes string the id of the device type – defined by the plugin or one of the defined X10 devices.
indigo.device.delete(123)
Enable/Disable
indigo.device.getDependencies(123)
               ID : 1280166770 (integer)
               ID : 106487666 (integer)
Get Group List
indigo.device.getGroupList(123)  # returns an indigo.List of all devices grouped with dev
See also indigo.device.groupWithDevice() and indigo.device.ungroupDevice().
Group With Device
To group two or more devices together, use the indigo.device.groupWithDevice() command. The parameters are the Indigo Device object IDs of the devices to be grouped.
indigo.device.groupWithDevice(dev, someOtherDev)  # group dev with another device
For example, if you want to group devices 123 and 456, you would use indigo.device.groupWithDevice(123, 456). There is no message printed to the events log if the devices grouped together successfully. If you want to add device 789 to the group, you would use indigo.device.groupWithDevice(456, 789). This is a great way to bring together different devices that have a common thread, but bear in mind that it's best not to try to group too many devices together.
See also indigo.device.ungroupDevice() and indigo.device.getGroupList().
Ping Device
if result["Success"]:
Status Request
Toggle
indigo.device.toggle(123)
Turn Off
indigo.device.turnOff(123)
Turn On
indigo.device.turnOn(123)
Ungroup With Device
  indigo.device.ungroupDevice(dev)  # ungroup dev
See also indigo.device.groupWithDevice() and indigo.device.getGroupList().
Unlock
indigo.device.unlock(123)
Lock
indigo.device.lock(123)
# Creating a device
    name="Office Lamp",
    address="F7",
# Getting a device
# Getting a device
if (myDevice.remoteDisplay):
all off
All Lights Off
indigo.dimmer.allLightsOff()
All Lights On
indigo.dimmer.allLightsOn()
Brighten
indigo.dimmer.brighten(123)
Dim
indigo.dimmer.dim(123)
Set Brightness
Set LED State
Set Color Levels
               redLevel,
               greenLevel,
               blueLevel,
               whiteLevel,
               whiteLevel2,
               whiteTemperature,
               delay,
               suppressLogging,
               updateStatesOnly
redLevel No integer 0 - 100
greenLevel No integer 0 - 100
blueLevel No integer 0 - 100
whiteLevel No integer 0 - 100
whiteLevel2 No integer 0 - 100
whiteTemperature No integer 1200 - 15000
delay No integer Defaults to 0.
suppressLogging No boolean Defaults to False
updateStatesOnly No boolean is an argument that exists on several device instance APIs that has Indigo update its device state/UI but does not have the corresponding action sent out to physical module. The use cases for this are pretty few, but sometimes you just want the internal state to update and can skip the actual command to the module. Defaults to False
# RGB value / 255 * 100
redLevel = 128
Set On State
# Getting a device
    (myDevice.onState)):
myDevice.folderId
# OR
Set Binary Output
		index=1,
		value=False)
  • X10 Motion Sensors
Set On State
– none –
Set LED State
# Toggle the device
Decrease Speed Index
Decreases the speed index.
Increase Speed Index
Increases the speed index.
Set Speed Index
Set Speed Level
activeZone integer No 1.0 the 1-based index of the active zone (None=all zones off, 1=zone 1, 2=zone 2, …). Note this property has undergone changes in name (previously called activeZoneIndex) as well as semantics (previously the index being 0-based).
Next Zone
Pause Schedule
indigo.sprinkler.pause(123)
Previous Zone
Resume Schedule
indigo.sprinkler.resume(123)
Run Schedule
Run a sprinkler schedule.
Stop Schedule
indigo.sprinkler.stop(123)
Set Active Zone
# run schedule
Plugin Capabilities
Property Type Writeable Description
NumTemperatureInputs Integer Yes should range between 1 and 3
NumHumidityInputs Integer Yes should range between 0 and 3
SupportsHeatSetpoint Boolean Yes True or False
SupportsCoolSetpoint Boolean Yes True or False
SupportsHvacOperationMode Boolean Yes True or False
SupportsHvacFanMode Boolean Yes True or False
ShowCoolHeatEquipmentStateUI Boolean Yes True or False
Attribute Read-Only
dev.hvacMode Yes
dev.fanMode Yes
dev.coolSetpoint Yes
dev.heatSetpoint Yes
dev.temperatureSensorCount Yes
dev.temperatures Yes
dev.humiditySensorCount Yes
dev.humidities Yes
dev.coolIsOn Yes
dev.heatIsOn Yes
dev.fanIsOn Yes
dev.dehumidifierIsOn Yes
dev.humidifierIsOn Yes
dev.supportsHvacFanMode Yes
dev.supportsHvacOperationMode Yes
dev.supportsCoolSetpoint Yes
dev.supportsHeatSetpoint Yes
Fan Mode Enumeration
indigo.kFanMode
Value Description
HVAC Mode Enumeration
indigo.kHvacMode
Value Description
Decrease Cool Setpoint
delta No integer Number of degrees to decrease the cool setpoint. If unspecified, the change will be equal to one degree.
Decrease Heat Setpoint
delta No integer Number of degrees to decrease the heat setpoint. If unspecified, the change will be equal to one degree.
Increase Cool Setpoint
delta No integer Number of degrees to increase the cool setpoint. If unspecified, the change will be equal to one degree.
Increase Heat Setpoint
delta No integer Number of degrees to increase the heat setpoint. If unspecified, the change will be equal to one degree.
Set Cool Setpoint
Set Fan Mode
Adjust the fan mode.
value Yes kFanMode the operating mode for the fan
Set Heat Setpoint
Set HVAC Mode
Adjust the HVAC mode.
# set the heat setpoint to 78
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/device_class.1773181614.txt.gz
  • Last modified: 2026/03/10 22:26
