Indigo 2025.1 Documentation
Welcome to the Indigo 2025.1 Documentation pages. We've separated the docs into multiple areas, each focusing on some different part of Indigo 2025.1.
  1. Getting StartedStart here!
  4. The Indigo Web Server documentation will help you take advantage of everything the web server has to offer.
  5. The Reflector documentation will help you activate and manage your reflector.
  6. Managing Plugins - the Getting Started guide has a section on managing 3rd party plugins, but we think it's important enough to point out here at the top level of the documentation.
  • Global Property Manager - gives users the ability to add custom properties to any Indigo object.
About Python IOM API v3.x and Indigo 2025.1: with API v3.0 and later, we have switched to Python 3. Plugins and scripts – both embedded and external – run in Python 3 only. The Indigo Plugin Store highlights the legacy plugins that will not work with Indigo 2025.1. See the API release notes for v3.0 for details. See Python Packages for a list of the additional Python packages that are installed with the Indigo 2025.1 installer.
  • The Indigo Object Model v3.7 (release notes) - this is used to build plugins and write scripts to work with Indigo.
    • Plugin Developer's Guide - how to create plugin bundles for easy distribution, plugin UI, APIs, callback hooks, and more.
    • Object Model Reference - the Indigo Object Model (IOM) and how to use it in Python in both plugins and scripts.
    • Scripting Tutorial - dive into scripting Indigo by examples.
    • Server Plugin Tutorial - examples of extending Indigo via plugins.
    • Indigo Plugin SDK includes example plugins with full XML and python source. They are a great place to start when developing new plugins (or when upgrading a plugin to Python 3).
  • Integration APIs - these are used to integrate Indigo control into other systems (i.e. Shortcuts, etc)
    • HTTP API - a new API which replaces the legacy REST API. If you need to convert, check out the REST to HTTP API Conversion Examples page for some examples to get you started.
    • WebSocket API - this API allows more modern integrations by opening persistent connections to Indigo and receive updates to all the major Indigo object types as changes are made. You can also send commands through this WebSocket to control devices. It's extremely fast and should make for some great 3rd party clients and other integrations (our new Indigo Touch for Web UI uses them).
  • Integrations
  • /www/perceptive/wiki/data/pages/indigo_2025.1_documentation/documents.txt
  • Last modified: 2026/02/04 18:45
