Indigo Overview
Object Definition
Here is the device dialog:
Device Dialog New Image
Device Dialog Z-Wave Image
Trigger Dialog Image
Email Event Image
Match Raw Packet
* 0x7D 0x84 0x07 *
Field Description
Webhook ID This is a random code generated by Indigo. It's used to identify which webhook is associated with the event. You can use the code provided or use one of your own. NOTE: if someone has your Reflector URL and the webhook ID, they can cause the event to fire. If you use your own ID, it's best not to make it easily guessable.
Webhook Method [POST]
Webhook Method [GET]
Processing [JSON]
Processing [HTML Form]
Schedule Dialog Image
Action Type Menu Image
Universal Controls
Universal Controls Menu Image
Light/Appliance Controls
Light Controls Menu Image
Sprinkler Controls
Sprinkler Action Image
Thermostat Controls
Fan Speed Controls
I/O Action Image
Virtual Device Controls
Brand Specific Controls
Brand Specific Controls Image
Insteon
HomeSeer
Inovelli
Zooz
Zooz Specific Actions Image
Script and File Actions
Execute Script
Execute Script Action Image
Open File
Open File Action Image
Run Shell Script
Run Shell Script Action Image
Log Actions
Log Actions Type Menu Image
Write to Log
Write to Log Action Image
Email Event Log Data
Email Log Action Image
Enable/Disable/Reload Actions
Enable Type Menu Image
Reload Plugin Dialog Image
Get Contents of URL
Run Apple Shortcut
Run Shortcut Action Image
Modify Variable
Modify Variable Action Image
Toggle Variable
Toggle Variable Action Image
Set Variable to Variable
Send Email
Send Indigo Log Email
Send Raw Z-Wave Command
Inclusion Mode Commands
Start Z-Wave Network Optimize
Execute INSTEON Scene
Insteon Scene Action Image
Send Raw INSTEON Command
Insteon Raw Action Image
Lower Action Dialog Image
Multiple Actions List Image
To create a new action group:
Action Group Dialog Image
Control Page Editor Image
Page Element Examples Image
  • iPhone/iPod touch
  • iPad
Other Editor Features
Page Element Details
Device State
Variable Value
Static Image/Caption
Refreshing Image URL
Server Status Text
Server Status Icon
Client Actions
Server Actions
Show in Browser
Variable Window Image
Conditions Tab Image
  2. if it's too cold outside
Sprinkler Condition Image
Complex Condition Rule Image
    "If dark"
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/overview.1761087822.txt.gz
  • Last modified: 2025/10/21 23:03
