Indigo Overview
| Object | Definition |
Here is the device dialog:
Device Options
Triggers
Device State Changed
Variable Changed
Email Event
Indigo Server Startup
Power Failure
Interface Connection Failure
Z-Wave Command Received
Match Raw Packet
* 0x7D 0x84 0x07 *
INSTEON Command Received
X10/RF Command Received
Plugin Events
Web Server Event
| Field | Description |
| Webhook ID | This is a random code generated by Indigo. It's used to identify which webhook is associated with the event. You can use the code provided or use one of your own. NOTE: if someone has your Reflector URL and the webhook ID, they can cause the event to fire. If you use your own ID, it's best not to make it easily guessable. |
| Webhook Method [POST] | Use POST to indicate that the webhook is sending information to Indigo and not expecting data in return (your call will be |
| POST Processing [JSON] | this type of webhook will accept a POST and interpret the payload as JSON. |
| POST Processing [HTML Form] | this type of webhook will accept a POST with optional form data, which will be converted into a dict of name value pairs and passed through as data. |
| Webhook Method [GET] | this type of webhook will accept a GET and will pass through any query arguments as the data element. GET webhooks do not have settings for processing the associated payload. |
Schedules
Time
Date
Other Options
Actions
Device Actions
Universal Controls
Request Full Status Update- ask the device to reply with all possible status information. This is dependent on the capabilities of the device.Request Energy Update- ask the device to reply with only its energy usage information. This is dependent on the capabilities of the device - many do not support energy monitoring.Reset Energy Usage- ask the device to reset the running total of energy usage. This is dependent on the capabilities of the device - many do not support energy monitoring.
Light/Appliance Controls
All Off- turn off all light and appliance devices. TheDevices:popup lets you selectAll INSTEON/X10,All INSTEON,All X10, or a specific X10 house code.All Lights On- turn on all light devices with the sameDevices:options asAll OffAll Lights Off- turn off all light devices with the sameDevices:options asAll OffTurn On- turn on a specific device with an optional complementaryAuto-off after X minutesactionTurn Off- turn of a specific device with an optional complementaryAuto-on after X minutesactionToggle On/Off- turn on the device if it's off or off if it's onSet Brightness- set the brightness of a lamp device to a specific percentage (from 0-100)Brighten by %- increase the brightness of a lamp device by a specific percentage (from 0-100)Dim by %- increase the brightness of a lamp device by a specific percentage (from 0-100)Match Brightness to Device- set the brightness of any number of dimmer devices to the value of the selected dimmer device - so you can quickly and easily create a very simple scene.Match Brightness to Variable- set the brightness of any number of dimmer devices to the value of the selected variable.Start Brighten- for Insteon and Z-Wave dimmers, start to brighten the load (using the device's specific ramp rate). You can pair this with anEnd Brighten/Dimcommand or you can just allow it to brighten all the way to 100%.Start Dim- for Insteon and Z-Wave dimmers, start to dim the load (using the device's specific ramp rate). You can pair this with anEnd Brighten/Dimcommand or you can just allow it to dim until it's finished. Insteon devices will end up at 0% (off), but some Z-Wave devices may stop at 1% rather than being completely off.End Brighten/Dim- for Insteon and Z-Wave dimmers, end a previously issuedStart BrightenorStart Dimand update the brightness of the device in Indigo at whatever level the dimmer was at when it stopped.Match On State to Device- set the on state of any number of on/off or dimmer devices to the value of the selected device which supports an on state.Match On State to Keypad LED State- set the on state of any number of on/off or dimmer devices to the value of the selected Insteon KeypadLinc button.Match On State to Variable- set the on state of any number of on/off or dimmer devices to the value of the selected variable.Set RGBW Levels- set the RGBW levels for lights that support setting their color.
Sprinkler Controls
Thermostat Controls
Fan Speed Controls
Set Fan Speed- set the speed of the device to a specific levelIncrease Fan Speed- increase the fan speed by some # of units - for instance, on a FanLinc that's currently onLow, increasing the fan speed by 1 will set it toMediumDecrease Fan Speed- decrease the fan speed similarly to the above Increase Fan SpeedTurn Fan On (resume last speed)- this will turn the fan on to its last speed settingTurn Fan Off- turn the fan off completelyToggle Fan On/Off- toggle between on and offCycle Through Fan Speeds- use this action to cycle through the fan speeds in highest to lowest speed order. It's basically an electronic version of pulling a fan's chain.
Virtual Device Controls
Brand Specific Controls
Insteon
Beep Device- ask the device to beep. This function is dependent on the capabilities of the device.Turn On Single KeypadLinc Button- turn on one individual KeypadLinc button.Turn On Single KeypadLinc Button- turn off one individual KeypadLinc button.Set All KeypadLinc Buttons- turn on/off groups of buttons. Why not just have multiple actions using the built-in Turn ON/Turn OFF LED actions? Because each of those requires a lot of INSTEON traffic - and if you need to set several buttons at once this action will do it in one (or two if you want to maintain some buttons) action(s). It's more efficient and easier to configure (one action versus potentially seven actions). Select the action you want to take for each button:Turn On,Turn Off,Leave Alone. The latter option will require that we query the KPL to find the states first so if you select that for any of the buttons the action may execute a bit slower than it would otherwise. Note: using this action, which is sending raw INSTEON commands through the IndigoServer, will cause the KeypadLinc's button states in Indigo to become out of sync. This is because the server doesn't know that you're changing the button states given that it's just a raw command message that it's being asked to send to the PowerLinc. If you need to keep the states in sync then add another action to do a status request to the KeypadLinc (after a short delay to avoid collisions).Set KeypadLinc Auto-Off Button Group- specify what buttons will go off automatically when you press any other button. Useful in conjunction with Toggle Mode below for creating “radio groups”. See the FanLinc and KeypadLinc article for usage examples.Set KeypadLinc Button Toggle Mode- specify whether a button toggles (alternates between ON and OFF when pressed) or whether it sends a single command anytime it's pressed (can send either ON or OFF). Useful in conjunction with Auto-Off groups above for creating “radio groups”. See the FanLinc and KeypadLinc article for usage examples.Set LED Brightness- set the brightness of the LEDs on certain devices. Newer KeypadLincs are supported as well as some SwitchLinc models. Unfortunately there isn't really a way to tell you which devices are supported so you'll just have to try it and see if it works.Set i3 Dimmer/Relay Mode- set the behavior for i3 modules that support both on/off and dimmable loads.Set i3 Dial Off Behavior- set the behavior when an i3 Dial is fully rotated counterclockwise: off or dim to 1%.Set Motion Sensor LED Brightness- set the brightness of the LED that flashes inside the motion sensor when motion is detected. While the brightness value is between 0 and 255, 0 does not mean the LED is completely off - it's just very dim. Note: only revision 2 Motion Sensors with jumper 5 set can be configured.Set Motion Sensor Timeout- set the timeout value between the time the motion sensor stops detecting motion and when it sends the OFF command. The timeout values work like this: 0 is equal to 30 seconds and 255 is equal to 2 hours. Values in between are proportional to those values. Note: only revision 2 Motion Sensors with jumper 5 set can be configured.Set Motion Sensor Day/Night Sensitivity- set the sensitivity for when the motion sensor detects changes from dawn to dusk and vice versa. The sensitivity values work like this: 0 will make the sensor register day all the time and 255 is equal to night all the time. Values in between are proportional to those values. Note: only revision 2 Motion Sensors with jumper 5 set can be configured and Motion Sensor II models will interpret 0 as 3.Set I/O Linc Momentary Mode- set the momentary mode of an I/O Linc to A, B, C, or None (the built-in UI only sets A or None).Set I/O Linc Momentary Duration- set the duration the output will be on before it automatically goes off (if momentary mode is turned on with the above command).Configure SynchroLinc- configure the Trigger Watts, Threshold Watts, and Delay Seconds in a SynchroLinc. Here are the details of those settings:- Trigger Watts (0 to 1800 watts in 0.5 watt steps): the wattage needed before the SynchroLinc broadcasts.
HomeSeer
Set LED Mode- set the mode of the LEDs on the switch. The defaultNormal (load status)behavior is for them to represent the brightness to which the switch is set. You can set the switch toStatus (custom status)which will allow you to individually turn on and off each LED and set its color. You can also set the bottom LED's behavior.Set LED Color and On/Off State- when the switch is inStatusmode, you can use this action to turn on/off and set the color of any of the LEDs.Set LEDs Blinking Behavior- start/stop LEDs from blinking.
Inovelli
Set LED Brightness when Off- this will set how bright the LED is when the device is off (nice for night time to easily locate switch in the dark).Set LED Brightness when On- this will set how bright the LED is when the device is on.Set LED Color- sets the color of the LED.Set Notification- some Inovelli devices allow you to set what they refer to as a notification. This is a combination of color, brightness, effect (pulse, flash, etc), and duration. The net effect is that you can change the behavior of a device's LED temporarily (with or without an automatic timeout) to act as a visual notification. When the notification times out (or is explicitly cleared) it will revert to its previous setting.Clear Notification- clears a previously set notification (does nothing if no notification is active on a device).
Zooz
Set Default Brightness- set the brightness that the dimmer device will come on to. Note this only applies to manual operation - Z-Wave ON commands will always result in the switch returning to its previous brightness.Set LED Brightness- set how bright the LEDs are.Set LED Color- set the color of the LEDs.
Server Actions
Script and File Actions
Execute Script
Open File
Run Shell Script
Log Actions
Write to Log
Email Event Log Data
Enable/Disable/Reload Actions
Get Contents of URL
Run Apple Shortcut
Variable Actions
Modify Variable
Toggle Variable
Set Variable to Variable
Notification Actions
Send Email
Send Indigo Log Email
Z-Wave Actions
Send Raw Z-Wave Command
Inclusion Mode Commands
Start Z-Wave Network Optimize
INSTEON Actions
Execute INSTEON Scene
Send Raw INSTEON Command
Action Options
Managing Multiple Actions
To create a new action group:
- Select
Notes. - Select the action
Control Pages
Control Page Editor
- iPhone/iPod touch
- iPad
Other Editor Features
Page Element Details
Device State
Variable Value
Static Image/Caption
Refreshing Image URL
Server Status Text
Server Status Icon
Client Actions
Server Actions
Show in Browser
Variables
Conditions
- if it's too cold outside
"If dark"
Condition Scripts
In Indigo 2025.1+, you can access the new Event Data dictionary that's passed through the chain to perform custom logic. For instance, you can create a simple condition script that will look at the event data from a Z-Wave Command Received trigger to decide if you want the actions to process or not. This is what the event_data dictionary would look like from a Z-Wave Command Received trigger:
event_data = {
"event-indigo-id": 886317539,
"zwavecmd-node-id": 2,
"zwavecmd-scene-id": 255
return True
return False
The event_data dictionary is automatically made available to your script, so you can just get the Indigo device ID out of that dict and see if it's in the list of device IDs in your condition script. If it is, it will continue processing, if not it will stop processing.
