Airfoil Pro
Airfoil Device Types
Airfoil Instance
Adding an Instance
albumArt.png- an image of the currently playing album track if the source supports it (notably, iTunes)machineIcon.png- an icon representing the computer that is running this instance of AirfoilmachineIconAndScreenshot.png- a screenshot from the host computer with the machine icon overlaid (though this functionality seems to be missing in Airfoil versions through v5.1.0 - you just get the same image as the machine icon)sourceIcon.png- an icon representing the selected audio source in Airfoil.
Airfoil instances are actually a group of devices: the instance itself (the first tab), and then multiple speaker devices, one for each speaker device that your instance knows about. We set the name of the Airfoil Instance to the Airfoil name. For each speaker, we name the speaker with this pattern: “Speaker Name (Airfoil Instance Name speaker)” to help you see how the devices relate to each other. We also add a note to each speaker device with a bit more detail about its relationship to its parent Airfoil Instance device.
Warning: due to changes that Apple has made to their API, the Source Status Is Playing trigger will no longer fire. This trigger option will be adjusted in a future release.
States available to Scripts
| State Key | Value Type | Description |
Notes
Speaker
Each Airfoil Instance device has a collection of “Speaker” devices in its group. These are all the various outputs to which Airfoil can direct its source audio. These devices are created automatically when you create your Airfoil Instance and any time a new source gets added to the instance. For instance, if you create an Airfoil Instance and it finds 3 speakers, then at a later time you add a bluetooth speaker to the Mac that Airfoil is running on, the plugin will automatically create a new speaker device for that bluetooth speaker.
volume | number | The volume that the speaker is currently set to. |
Airfoil Actions
Speaker Actions
Connect Speaker
Scripting details
Action id: connect
if airfoilPlugin.isEnabled():
"connect",
deviceId=135305663, # ID of Speaker device
waitUntilDone=True
except Exception as e:
Disconnect Speaker
Scripting details
Action id: disconnect
"disconnect",
waitUntilDone=True
Toggle Speaker
Scripting details
Action id: toggle
"toggle",
waitUntilDone=True
Save Current Speaker States
Scripting details
Example 1 (no groups):
"saveCurrentSpeakerStates",
deviceId=135305663, # ID of Airfoil device
waitUntilDone=True
Example 2 (include groups):
waitUntilDone=True
Restore Saved Speaker States
Scripting details
"restoreSavedSpeakerStates",
waitUntilDone=True
Set Volume
Scripting details
Action id: setVolume
'setVolume',
props={'volume': 50},
waitUntilDone=True
Increase Volume
Scripting details
Action id: increaseVolume
'increaseVolume',
waitUntilDone=True
Example 2 (specifying delta):
'increaseVolume',
props={'volume': 15},
waitUntilDone=True
Decrease Volume
Scripting details
Action id: decreaseVolume
'increaseVolume',
waitUntilDone=True
'decreaseVolume',
waitUntilDone=True
Airfoil Instance Actions
Disconnect All Speakers
Scripting details
'disconnectAllSpeakers',
deviceId=12345678, # ID of Airfoil device
waitUntilDone=True
Change Source
Scripting details
Action id: changeSource
"changeSource",
deviceId=1346588091, # ID of Airfoil device
props=props,
waitUntilDone=True
Save Current Source
Scripting details
Action id: saveCurrentSource
"saveCurrentSource",
waitUntilDone=True
Restore Saved Source
Scripting details
Action id: restoreSavedSource
"restoreSavedSource",
waitUntilDone=True
Toggle Play/Pause
Scripting details
Action id: playPause
'playPause',
waitUntilDone=True
Next Track
Scripting details
Action id: nextTrack
'nextTrack',
waitUntilDone=True
Previous Track
Scripting details
Action id: prevTrack
'prevTrack',
waitUntilDone=True
Airfoil Scripting Actions
getSources
Action id: getSources
'getSources',
deviceId=12345678 # ID of Airfoil device
audioDevices : (list)
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
recentApplications : (list)
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
systemAudio : (list)
Item : (dict)
icon : [SNIP]
