Triggers
Unlike Devices, you can't call create() in the the trigger base class command namespace (indigo.trigger.*). Rather, each subclass has its own create() method that takes the appropriate arguments for that trigger type.
You will also need to implement triggerStopProcessing(self,trigger) so that you can remove disabled/deleted triggers from your watch list. So, the Server isn't really involved at all with the trigger firing (except to execute the trigger when you tell it to) - it only notifies your plugin of events its supposed to be watching for and your plugin does the rest.
trigger=indigo.triggers[123]
indigo.trigger.delete(123)
Enable/Disable Trigger
indigo.trigger.enable(123,value=False)
indigo.trigger.enable(123,value=True)
indigo.trigger.enable(123, value=True, duration=360, delay=60)
Execute Trigger
indigo.trigger.getDependencies(123)
direct parameter Yes integer id or instance of the trigger to get the dependencies for.
               ID : 552463741 (integer)
               ID : 296710860 (integer)
# Change a trigger's name:
trigger.name = "My new name."
trigger.replaceOnServer()
State Change Type Enumeration
indigo.kStateChange
AnalogInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BinaryOutput
HvacCoolerIsOn
HvacFanIsOn
HvacFanModeIsAlwaysOn
HvacFanModeIsAuto
HvacHeaterIsOn
HvacOperationModeIsAuto
HvacOperationModeIsCool
HvacOperationModeIsHeat
HvacOperationModeIsOff
OnOffState
Zone
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
AnalogInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BinaryOutput
HvacCoolerIsOn
HvacFanIsOn
HvacFanModeIsAuto
HvacHeaterIsOn
OnOffState
Zone
AnalogInput
AnalogInputsAll
BinaryInput
BinaryInputsAll
BinaryOutput
BinaryOutputsAll
BrightnessLevel
HumidityInput
HumidityInputsAll
HvacCoolerIsOn
HvacFanIsOn
HvacFanMode
HvacFanModeIsAuto
HvacHeaterIsOn
OnOffState
SensorInput
SensorInputsAll
SetpointCool
SetpointHeat
TemperatureInput
TemperatureInputsAll
Zone
State Selector Enumeration
indigo.kStateSelector
Value Description
BinaryOutputsAll
KeypadButtonLedFIXME
    folder=1234)
theTrigger.deviceId = 738
theTrigger.stateValue = 80
theTrigger.replaceOnServer()
Email Filter Enumeration
indigo.kEmailFilter
Value Description
    folder=1234)
INSTEON Command Enumeration
indigo.kInsteonCmd
Value Description
Dimwhen a dim command begins
indigo.kDeviceSourceType
Value Description
    folder=1234)
theTrigger.buttonOrGroup = 1
    folder=1234)
    folder=1234)
Create a trigger. You can create triggers using this method of any type except for events that are defined by your plugin (that class, PluginEventTrigger, has its own create() method). This method returns a copy of the newly created trigger. Once a trigger of this type is created, the properties can change (via the pluginProps in the Trigger base class), but nothing else can be changed.
    folder=1234),
    pluginTypeId="myEvent",
pluginId No string the plugin id of the plugin that owns the device you're creating - if it's not present, it defaults to your plugin's id
    folder=1234)
    folder=1234)
X10 Command Enumeration
indigo.kX10Cmd
Value Description
X10 A/V Button Enumeration
indigo.kX10AvButton
Value Value
0 Left
1 Menu
2 Mute
3 Pause
4 PC
5 Play
6 Power
7 Recall
8 Record
9 Return
AB Rewind
ChannelDown Right
ChannelUp Stop
Display Title
Down Up
Enter VolumeDown
Exit VolumeUp
Forward
    folder=1234)
myTrigger.address = "F7"
myTrigger.replaceOnServer()
indigo.kVarChange
Value Description
    folder=1234)
  • /www/perceptive/wiki/data/pages/indigo_2025.1_documentation/trigger_class.txt
