Indigo Overview
Object Definition
Here is the device dialog:
Device Dialog New Image
Device Dialog Z-Wave Image
Trigger Dialog Image
Email Event Image
Match Raw Packet
* 0x7D 0x84 0x07 *
Field Description
Webhook ID This is a random code generated by Indigo. It's used to identify which webhook is associated with the event. You can use the code provided or use one of your own. NOTE: if someone has your Reflector URL and the webhook ID, they can cause the event to fire. If you use your own ID, it's best not to make it easily guessable.
Webhook Method
[POST]
Use POST to indicate that the webhook is sending information to Indigo and not expecting data in return (your call will be
POST Processing
[JSON]
this type of webhook will accept a POST and interpret the payload as JSON.
POST Processing
[HTML Form]
this type of webhook will accept a POST with optional form data, which will be converted into a dict of name value pairs and passed through as data.
Webhook Method
[GET]
this type of webhook will accept a GET and will pass through any query arguments as the data element. GET webhooks do not have settings for processing the associated payload.
You can find more information on the Webhooks page. You can find more information about using substitutions on the Indigo substitutions page.
Schedule Dialog Image
Action Type Menu Image
Universal Controls
Universal Controls Menu Image
Light/Appliance Controls
Light Controls Menu Image
Sprinkler Controls
Sprinkler Action Image
Thermostat Controls
Fan Speed Controls
I/O Action Image
Virtual Device Controls
Brand Specific Controls
Brand Specific Controls Image
Insteon
HomeSeer
Inovelli
Zooz
Zooz Specific Actions Image
Script and File Actions
Execute Script
Execute Script Action Image
Open File
Open File Action Image
This will open the specified file (full path using *nix slashes (“/”)) using the default application. If it's the path to an application (e.g. “/Applications/TextEdit.app”) then it will launch that app. You can also add command-line options and include Indigo substitutions. Note: file paths that contain spaces will need to have the spaces escaped with a backslash - /some\ path/that\ has/escaped\ spaces/.
Run Shell Script
Run Shell Script Action Image
Log Actions
Log Actions Type Menu Image
Write to Log
This will write the specified text into the event log - optionally with the specified type string. The Text to Log field supports the various Indigo substitutions.
In addition, you can select from three logging levels: Info (normal), Warning, or Error. The log message will be appropriately colored based on the chosen logging level.
Email Event Log Data
Email Log Action Image
Enable/Disable/Reload Actions
Enable Type Menu Image
Reload Plugin Dialog Image
Get Contents of URL
Run Apple Shortcut
The mechanism in Shortcuts to get a dictionary from input is extremely picky about the JSON that it's fed. When checked, the checkbox in this dialog explicitly encodes the input as JSON to make things work better. It defaults to off so existing shortcuts won't be encoded. If you pass an event substitution in the input field like %%e:“some_data[0].value”%%, you will need to tick the Send JSON checkbox before the shortcut will work.
You can also optionally save any return data to a variable.
Modify Variable
Modify Variable Action Image
Instert Event Data into Variable
Click the Edit Action Settings… button and it will open a dialog (shown above). Here you will select the variable and, optionally, the Path string if you want to access specific parts of the event data. More information can be found on the Path Strings page.
Toggle Variable
Toggle Variable Action Image
Set Variable to Variable
Send Email
Send Indigo Log Email
Send Raw Z-Wave Command
Inclusion Mode Commands
Start Z-Wave Network Optimize
Execute INSTEON Scene
Insteon Scene Action Image
Send Raw INSTEON Command
Insteon Raw Action Image
Lower Action Dialog Image
Multiple Actions List Image
To create a new action group:
Action Group Dialog Image
Control Page Editor Image
Page Element Examples Image
  • iPhone/iPod touch
  • iPad
Other Editor Features
Page Element Details
Device State
Variable Value
Static Image/Caption
Refreshing Image URL
Server Status Text
Server Status Icon
Client Actions
Server Actions
Show in Browser
Variable Window Image
Conditions Tab Image
  2. if it's too cold outside
Let's assume that you have a script running that populates Indigo variables with data from a weather station: “rain_total” holds the rain total for the last 24 hours, and “outside_temp” holds the temperature in Fahrenheit. Further, let's say you have a variable, “windows_open”, that's either true or false indicating whether the windows in your house are open or not.
Sprinkler Condition Image
Complex Condition Rule Image
    "If dark"
In Indigo 2025.2+, you can access the new Event Data dictionary that's passed through the chain to perform custom logic. For instance, you can create a simple condition script that will look at the event data from a Z-Wave Command Received trigger to decide if you want the actions to process or not. This is what the event_data dictionary would look like from a Z-Wave Command Received trigger:
event_data = {
  "event-indigo-id": 886317539,
  "zwavecmd-node-id": 2,
  "zwavecmd-scene-id": 255
    return True
return False
The event_data dictionary is automatically made available to your script, so you can just get the Indigo device ID out of that dict and see if it's in the list of device IDs in your condition script. If it is, it will continue processing, if not it will stop processing.
  • /www/perceptive/wiki/data/pages/indigo_2025.2_documentation/overview.txt
