Actions
PropertyTypeDescription
Complementary Delays
Complementary Actions
Action Complement
actionType = ControlLightOrAppliance
deviceAction = TurnOff
deviceAction = TurnOn
deviceAction = Toggle
actionType = DisableSchedule actionType = EnableSchedule
actionType = DisableTrigger actionType = EnableTrigger
actionType = EnableSchedule actionType = DisableSchedule
actionType = EnableTrigger actionType = DisableTrigger
This class represents an action to control a dimmer (light) or relay (appliance) module.
complementDelay integer the number of seconds to delay before issuing the complementary action (0 for no action) - see Complementary Delays for details
deviceAction kDimmerRelayAction this is the command to send to the device
actionValue integer if deviceAction is in [Brighten, Dim, SetBrightness] then this is the value - delta percentage for the first two, absolute percentage for the latter
Dimmer Relay Action Enumeration
indigo.kDimmerRelayAction
Value Description
AllLightsOffturn off all dimmer (light) devices
AllLightsOnturn on all dimmer (light) devices
AllOffturn off all dimmer (light) and relay (appliance) devices
BrightenBybrighten a dimmer (light) device by the amount specified in the deviceValue property
DimBydim a dimmer (light) device by the amount specified in the deviceValue property
SetBrightnessset a dimmer (light) device to the brightness specified in the deviceValue property
Toggletoggle the on/off state of a dimmer (light) or relay (appliance) device
TurnOffturn off a dimmer (light) or relay (appliance) device
TurnOnturn on a dimmer (light) or relay (appliance) device
RequestStatussend a device a status request
complementDelay integer the number of seconds to delay before issuing the complementary action (0 for no action), in this case an DisableScheduleAction - see Complementary Delays for details
index integer if action is TurnOffOutput, TurnOnOutput, the index of the input or output to control
indigo.kIOAction
Value Description
TurnOffOutputturn off the output specified by index
TurnOffAllOutputsturn off all outputs
TurnOnOutputturn on the output specified by index
RequestStatusAllrequest status of all hardware input/outputs
RequestAnalogInputValuesrequest all analog input values from the device
RequestBinaryInputsStatusrequest all binary input statuses
RequestBinaryOutputsStatusrequest all binary output statuses
RequestSensorInputValuesrequest all sensor input values
Variable Action Enumeration
indigo.kVariableAction
Value Description
DecrementValuedecrement the variable value by 1
IncrementValueincrement the variable value by 1
SetValueset the variable to the variableValue property
group integer this is the group number to send command to
indigo.kIOAction
ValueDescription
InstantOffsend the instant (fast) off command to group ignoring ramp rate
InstantOnsend the instant (fast) on command to group ignoring ramp rate
Offsend the off command to group
Onsend the on command to group
zoneDurations list of float list of floats that represent the durations in minutes for each zone to schedule - used when sprinklerAction is runSchedule
zoneIndex integer the zone to turn on - used when sprinklerAction is zoneOn
Sprinkler Action Enumeration
indigo.kSprinklerAction
Value Description
NextZoneset sprinkler to the next zone
PauseSchedulepause a sprinkler schedule
PreviousZoneset sprinkler to the previous zone
ResumeScheduleresume a sprinkler schedule
RunSchedulerun a sprinkler schedule
Stopstop a sprinkler schedule and turn off all zones
ZoneOnturn on a single zone
RequestStatusAllrequest status of all valves
actionMode kFanMode
OR
kHvacMode
if action is SetFanMode, then a kFanMode enumeration
if action is SetHvacMode, then a kHvacMode enumeration
actionValue float if action is Decrease* or Increase*, the amount to increase/decrease the setpoints
if action is Set*, the temperature to set the setpoint to
Thermostat Action Enumeration
indigo.kThermostatAction
Value Description
DecreaseCoolSetpointdecrease setpoint by value
DecreaseHeatSetpointdecrease setpoint by value
IncreaseCoolSetpointincrease setpoint by value
IncreaseHeatSetpointincrease setpoint by value
SetCoolSetpointset the setpoint to value
SetFanModeset the fan mode to mode
SetHeatSetpointset the setpoint to value
SetHvacModeset the hvac mode to mode
RequestStatusAllrequest all current values from the thermostat
RequestModerequest the current mode of the thermostat
RequestEquipmentStaterequest the current operational state of the compressor, furnace, etc.
RequestTemperaturesrequest all current temperatures from the thermostat
RequestHumiditiesrequest all current humidities from the thermostat
RequestDeadbandsrequest the current deadband ranges from the thermostat
RequestSetpointsrequest all current setpoints from the thermostat
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/action_class.txt
