address string No the address for the device
buttonGroupCount integer No the number of groups (or buttons in the case of the RemoteLinc and ControLinc) that the controller supports - currently used only for INSTEON devices - 0 for other devices
description string Yes a description of the device as specified by the user
deviceTypeId string No the typeId specified in the Devices.xml (or it’s documentation) - only used for plugin defined devices
enabled boolean No is the device enabled - set using the indigo.device.enable() method
folderId integer No the unique ID of the folder this device is in (0 if it's not in a folder) - use moveToFolder() method to change
globalProps dictionary No an indigo.Dict() representing all name/value pairs associated with this device - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details
id integer No id or instance of the device, assigned on creation by IndigoServer
lastChanged datetime No the last date/time that the device was changed - populated by IndigoServer
model string No the model name of the device - defined either by Indigo based on type or by the plugin's device definition
name string Yes the unique name of the device - no two devices can have the same name
pluginId string No if protocol is Plugin, the string ID for the plugin
pluginProps dictionary No an indigo.Dict() representing the name/value pairs defined by your plugin for the device - plugin developers should publish this information if you want other plugins/scripts to create devices of this type - see About Plugin Properties below for details - use replacePluginPropsOnServer() method to change
protocol kProtocol No an enumeration specifying the protocol of the device - see protocol enumeration below for possible values
remoteDisplay boolean Yes should this device be displayed in remote clients (IWS, Indigo Touch, etc) - may also be set with indigo.device.displayInRemoteUI()
states dictionary No returns an indigo.Dict() of device states - the key is the state id and the value is the value. Note that enumerated states will have not only the state, but also each option for the state. So, for instance, if I had a state called status and it had 3 options (online, offline, error), then you'd not only have status as a key, but also status.online, status.offline, and status.error as keys in the dictionary. This is so that you can test each state enumeration independently in trigger actions (e.g. status.online is true).
supportsAllLightsOnOff boolean No indicates that this device should react to all lights On and all lights Off commands - always False for plugin defined devices
supportsAllOff boolean No indicates that this device should react to all Off commands - always False for plugin defined devices
supportsStatusRequest boolean No indicates if the device supports querying the status - always False for plugin defined devices
Protocol Enumeration
indigo.kProtocol
Value Description
dev=indigo.devices[123]
dev.replacePluginPropsOnServer({"pollInterval":10,"checkForUpdates":True})
localPropsCopy.update({"pollInterval":10,"checkForUpdates":True})
dev.pluginProps.update({"pollInterval":10,"checkForUpdates":True})
    <State id="playStatus">
    <State id="sep1">
    <State id="playlist">
        <ValueType>String</ValueType>
    <State id="album">
    <State id="artist">
    <State id="track">
    <State id="volume">
    <State id="shuffle">
It's actually pretty simple. When your plugin detects a change in one of the states, you just call the updateStateOnServer(“id”,value=“value”) method. Here are some examples for setting the state based on the above state definitions:
# to update the volume state
someMusicServer.updateStateOnServer("volume", value=50)
# to update the track name
someMusicServer.updateStateOnServer("track", value="Cluster One")
# to update the album name
someMusicServer.updateStateOnServer("album", value="The Division Bell")
# to update the artist name
someMusicServer.updateStateOnServer("artist", value="Pink Floyd")
# to update the playStatus
someMusicServer.updateStateOnServer("playStatus", value="playing")
someMusicServer.updateStateOnServer("shuffle", value=True)
The updateStateOnServer method has 2 optional parameters: decimalPlaces (integer) and triggerEvents (boolean). When updating floating point state values use the decimalPlaces parameter to specify the number of fractional digits to store and display. For example:
someThermmostatDevice.updateStateOnServer("mainTemp" value=76.1234, decimalPlaces=2)
All Off
indigo.device.allOff()
Enumerated Type Description
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices (FIXME you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
    address="F8",
    name="Device Name Here",
    pluginId="com.mycompany.pluginId",
    deviceTypeId="myDeviceTypeId",
    props={"propA":"value","propB":"value"},
    folder=1234)
deviceTypeId Yes string the id of the device type – defined by the plugin or one of the defined X10 devices FIXME link here
indigo.device.delete(123)
indigo.device.duplicate(123, duplicateName="New Name")
Enable/Disable
Status Request
Toggle
indigo.device.toggle(123)
Turn Off
indigo.device.turnOff(123)
Turn On
indigo.device.turnOn(123)
Here’s a side by site comparison of using various device properties in Python and AppleScript:
Python AppleScript
# Creating a device
    name="Office Lamp",
    address="F7",
-- Creating a device
    address:"F7",¬
# Getting a device
-- Getting a device
-- Logging a message if it’s an X10 device
    log "device is an X10 device"
end if
if (myDevice.remoteDisplay):
-- Logging a message if it’s showing in Indigo Touch
end if
-- Folder ID is not available in AppleScript
all off
all lights off "A"
-- AppleScript
ledStates list No this is a list of booleans that represent the state of LEDs on the device. So, to check to see if LED 3 is on you'd check dev.ledStates[2] (Python arrays are 0-based so the first element is element 0). Currently, only KPL devices use this array - however, future devices may use it as well so you should probably check the length first to make sure that the LED you're looking for is actually there. Use the len(dev.ledStates) method to see how many entries there are before you access a specific index.
onState boolean No indicates whether the device is on - set using commands below
All Lights Off
indigo.dimmer.allLightsOff()
All Lights On
indigo.dimmer.allLightsOn()
Brighten
indigo.dimmer.brighten("Office Lamp")
indigo.dimmer.brighten(123)
indigo.dimmer.brighten("Office Lamp", by=50, delay=4)
Dim
indigo.dimmer.dim("Office Lamp")
indigo.dimmer.dim(123)
indigo.dimmer.dim("Office Lamp", by=50, delay=4)
Set Brightness
Set LED State
Set On State
Here’s a side by site comparison of dimmer properties in Python and AppleScript:
Python AppleScript
# Getting a device
-- Getting a device
    (myDevice.onState)):
-- Set a device’s brightness to 75 if it’s currently
end if
-- Brighten a light by 25% after 10 minutes
end if
myDevice.folderId
# OR
analogInputs list of integer No a list of the current analog input values, one per input
binaryInputs list of boolean No a list of the current binary input values, one per input
binaryOutputs list of boolean No a list of the current binary output values, on per output (max 12 total outputs)
sensorInputs list of integer No a list of the current sensor input values, one per input
Set Binary Output
Python AppleScript
		index=1,
		value=False)
-- If binary input 3 is false, set binary output 1
-- to false
	of device "EZIO8SA"
		of device "EZIO8SA"
		"EZIO8SA" to theBinaryOutputs
end if
Some sensor devices, like motion sensors, are treated differently in Indigo. They aren't generally directly controllable and are considered input devices.
They typically send a command of some type when they detect some condition and send another command when they stop detecting it. However, dealing with them in Indigo as if they maintain state is much more useful in many cases. So, Indigo will attempt to maintain a virtual state for each motion sensor if configured that way. Currently, the following devices fall under this category:
  • X10 Motion Sensors
Other sensor types, such as an energy meter (iMeter solo), do maintain some state information (like current load in Watts). Indigo maintains additional virtual states for these types of devices as well though, for example to track the kWh of energy used from a base time stamp.
onState boolean No indicates that the device is currently detecting motion
energyInputCount integer No number of energy (current) monitoring inputs this device supports
energyInputs list of integer No a list of the energy input values in Watts, one per input
accumEnergyTotals list of float No a list of the energy used in kWh since the last base time specified in accumEnergyBaseTimes, one per input
accumEnergyTimeDeltas list of integer No a list of the time delta in seconds since the last base time, one per input
accumEnergyBaseTimes list of datetime No a list of the base times from which to calculate energy totals (accumEnergyTotals), one per input
Set On State
Reset Accumulated Energy Totals
Resets the accumEnergyTotals, accumEnergyTimeDeltas values for all inputs properties and changes the accumEnergyBaseTimes to the server's current datetime.
indigo.sensor.resetAccumEnergyTotals(123)
Because this can't be done in AppleScript, we've just provided an example in Python:
# Log to the Event Log the current kWh total for an energy meter (ID 123):
dev = indigo.devices[123]
indigo.server.log("current kWh total: " + str(dev.accumEnergyTotals[0]))
# Then reset the accumulative totals and log again (should be 0):
indigo.sensor.resetAccumEnergyTotals(dev)
dev.refreshFromServer(waitUntilServerIdle=True)
indigo.server.log("reset kWh total: " + str(dev.accumEnergyTotals[0]))
onState boolean indicates whether the device is on
Set LED State
Python AppleScript
# Toggle the device
-- Toggle the device
toggle device “Office Lamp”
activeZone integer No the number of the active zone, -1 if off (0=zone 1, 1=zone 2, etc)
zoneCount integer No the number of zones available for this sprinkler
zoneNames list of string No list of zone names, starting at zone 1 through zone [zoneCount] - you must include zoneCount strings in the list
zoneMaxDurations list of integer No list of zone durations in minutes, starting at zone 1 through zone [zoneCount] - you must include zoneCount integers in the list
zoneScheduledDurations list of integer No list of currently active zone durations in minutes if a schedule is running (empty list if no schedule is running), starts at zone 1 through zone [zoneCount] - you must include zoneCount integers in the list
Next Zone
Pause Schedule
indigo.sprinkler.pause(123)
Previous Zone
Resume Schedule
indigo.sprinkler.resume(123)
Run Schedule
Run a sprinkler schedule.
schedule Yes list of integer list of integers representing the number of minutes to run for each zone - the list must have [zoneCount] elements, with 0 for any zone that shouldn’t run
Stop Schedule
indigo.sprinkler.stop(123)
Turn On Zone
Turn on a specific zone.
indigo.sprinkler.turnOnZone(123, index=2)
index Yes integer 0-based index of the zone to turn on
Python AppleScript
# run schedule
-- AppleScript doesn't support directly running a schedule, so
-- then execute that.
-- run schedule
        with properties ¬
end if
set zone durations of  ¬
    to [10, 15, 8, 0, 0, 0, 0, 0]
execute group actionGroupName
Thermostats have a wide variety of capabilities that we’ve tried to boil down to some specifics. They can have multiple temperature and humidity sensors, they generally have a fan mode, an HVAC mode (heating, cooling, etc) and associated setpoints. Note:some thermostats don’t support getting the following values: coolIsOn, fanIsOn, and heatIsOn - for those thermostats those properties will always be False.
coolIsOn boolean No is the cooling system (compressor) currently running
coolSetpoint float No current cool setpoint value
fanMode kFanMode No the operating mode for the fan attached to the thermostat
fanIsOn boolean No is the fan currently running
heatIsOn boolean No is the heater currently running
heatSetpoint float No current heat setpoint value
humidities list of float No a list of floating point values representing the current values of all humidity sensors connected to the thermostat
humiditySensorCount integer No number of humidity sensors this thermostat supports
hvacMode kHvacMode No the operating mode for the HVAC system attached to the thermostat
temperatureSensorCount integer No number of temperature sensors this thermostat supports
temperatures list of float No a list of floating point values representing the current values of all temperature sensors connected to the thermostat
Fan Mode Enumeration
indigo.kFanMode
Value Description
HVAC Mode Enumeration
indigo.kHvacMode
Value Description
Decrease Cool Setpoint
value Yes integer number of degrees to decrease the cool setpoint
Decrease Heat Setpoint
value Yes integer number of degrees to decrease the heat setpoint
Increase Cool Setpoint
value Yes integer number of degrees to increase the cool setpoint
Increase Heat Setpoint
value Yes integer number of degrees to increase the heat setpoint
Set Cool Setpoint
Set Fan Mode
Adjust the fan mode.
value Yes kFanMode the absolute temperature of the setpoint
Set Heat Setpoint
Set HVAC Mode
Adjust the HVAC mode.
indigo.thermostat.setHvacMode(123, value=indigo.kHvacMode.HeatCoolOn)
Python AppleScript
# set the heat setpoint to 78
-- increase the cool setpoint by 5 degrees
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/device_class.txt
