address | string | No | the address for the device |
batteryLevel | integer | No | battery level for the device - None if the device doesn't support battery operation - shortcut for dev.states['batteryLevel'] |
buttonGroupCount | integer | No | the number of groups (or buttons in the case of the RemoteLinc and ControLinc) that the controller supports - currently used only for INSTEON devices - 0 for other devices |
configured | boolean | No | true if the device has been fully configured - if it's a plugin device use this to make sure that the device's config dialog has been run at least once. |
description | string | Yes | a description of the device as specified by the user |
deviceTypeId | string | No | the typeId specified in the Devices.xml (or it’s documentation) - only used for plugin defined devices |
displayStateId | string | No | API v1.15+ only: main display stateId key which can be used as a key into states[] property below |
displayStateValRaw | boolean integer string or none | No | API v1.15+ only: raw value of main display state (ex: 72.0) |
displayStateValUi | string | No | API v1.15+ only: UI value (string) of main display state (ex: '72.0°F' ) |
displayStateImageSel | kStateImageSel | No | API v1.18+ only: an enumeration specifying which state image icon is shown in Indigo Touch and Indigo client UI - see state image sel enumeration below for possible values |
enabled | boolean | No | is the device enabled - set using the indigo.device.enable() method |
energyCurLevel | float | No | API v1.11+ only: current Wattage energy being used by the device (None if not supported) |
energyAccumTotal | float | No | API v1.11+ only: current accumulated energy used since last base time specified in energyAccumBaseTime (None if not supported) |
energyAccumBaseTime | datetime | No | API v1.11+ only: the base time from which to calculate the energy total (energyAccumTotal) (None if not supported) |
energyAccumTimeDelta | integer | No | API v1.11+ only: the time delta in seconds since the last base time (None if not supported) |
folderId | integer | No | the unique ID of the folder this device is in (0 if it's not in a folder) - use moveToFolder() method to change |
globalProps | dictionary | No | an indigo.Dict() representing all name/value pairs associated with this device - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
id | integer | No | id or instance of the device, assigned on creation by IndigoServer |
lastChanged | datetime | No | the last date/time that the device was changed - populated by IndigoServer |
model | string | No | the model name of the device - defined either by Indigo based on type or by the plugin's device definition |
name | string | Yes | the unique name of the device - no two devices can have the same name |
ownerProps | dictionary | No | API v1.20+ only: an indigo.Dict() representing the name/value pairs defined by the plugin that created the device - this is a shortcut into the owner plugin's globalProps data |
pluginId | string | No | if protocol is Plugin, the string ID for the plugin |
pluginProps | dictionary | No | an indigo.Dict() representing the name/value pairs defined by your plugin for the device - plugin developers should publish this information if you want other plugins/scripts to create devices of this type - see About Plugin Properties below for details - use replacePluginPropsOnServer() method to change |
protocol | kProtocol | No | an enumeration specifying the kProtocol of the device - see protocol enumeration below for possible values |
remoteDisplay | boolean | Yes | should this device be displayed in remote clients (IWS, Indigo Touch, etc) - may also be set with indigo.device.displayInRemoteUI() |
states | dictionary | No | returns an indigo.Dict() of device states - the key is the state id and the value is the value. Note that enumerated states will have not only the state, but also each option for the state. So, for instance, if I had a state called status and it had 3 options (online, offline, error), then you'd not only have status as a key, but also status.online, status.offline, and status.error as keys in the dictionary. This is so that you can test each state enumeration independently in trigger actions (e.g. status.online is true). |
supportsAllLightsOnOff | boolean | No | indicates that this device should react to all lights On and all lights Off commands - always False for plugin defined devices |
supportsAllOff | boolean | No | indicates that this device should react to all Off commands - always False for plugin defined devices |
supportsStatusRequest | boolean | No | indicates if the device supports querying the status - always False for plugin defined devices |
Protocol Enumeration
| indigo.kProtocol |
Value | Description |
State Image Sel Enumeration
API v1.18+ only: note Indigo Touch and Indigo client UI do not currently have icons for every image selector listed below.
| indigo.kStateImageSel |
HumidifierOn | overrides to show a humidity sensor on icon |
DehumidifierOn | overrides to show a dehumidifier icon |
| Method | Restricted | API Version | Description |
dev=indigo.devices[123]
<State id="playStatus">
<State id="sep1">
<State id="playlist">
<ValueType>String</ValueType>
<State id="album">
<State id="artist">
<State id="track">
<State id="volume">
<State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Commands (indigo.device.*)
All Off
indigo.device.allOff()
| Parameters |
indigo.kAllDeviceSel |
Beep (API v1.11+ only)
indigo.device.beep(123)
| Parameters |
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices (
you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
address='F8',
name='Device Name Here',
folder=1234)
| Parameters |
indigo.device.delete(123)
| Parameters |
| Parameters |
Enable/Disable
| Parameters |
Get Group List
| Parameters |
| Parameters |
ID : 1280166770 (integer)
ID : 106487666 (integer)
| Parameters |
Ping Device (API v1.16+ only)
if result["Success"]:
| Parameters |
| Parameters |
| Parameters |
| Parameters |
Status Request
| Parameters |
Toggle
indigo.device.toggle(123)
| Parameters |
Turn Off
indigo.device.turnOff(123)
| Parameters |
Turn On
indigo.device.turnOn(123)
| Parameters |
Here’s a side by site comparison of using various device properties in Python and AppleScript:
| Python | AppleScript |
# Creating a device
name="Office Lamp",
address="F7",
| -- Creating a device
address:"F7",¬
# Getting a device
| -- Getting a device
| -- Logging a message if it’s an X10 device
log "device is an X10 device"
end if
if (myDevice.remoteDisplay):
| -- Logging a message if it’s showing in Indigo Touch
end if
| -- Folder ID is not available in AppleScript
| -- Turning off all devices (dimmer and relay)
all off
all lights off "A"
-- AppleScript
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
| Parameters |
All Lights On
indigo.dimmer.allLightsOn()
| Parameters |
Brighten
indigo.dimmer.brighten(123)
| Parameters |
Dim
indigo.dimmer.dim(123)
| Parameters |
Set Brightness
| Parameters |
Set LED State
| Parameters |
Set On State
Here’s a side by site comparison of dimmer properties in Python and AppleScript:
# Getting a device
| -- Getting a device
(myDevice.onState)):
| -- Set a device’s brightness to 75 if it’s currently
end if
| -- Brighten a light by 25% after 10 minutes
end if
myDevice.folderId
# OR
Commands (indigo.iodevice.*)
Set Binary Output
| Parameters |
index=1,
value=False)
| -- If binary input 3 is false, set binary output 1
-- to false
of device "EZIO8SA"
of device "EZIO8SA"
"EZIO8SA" to theBinaryOutputs
end if
allowOnStateChange | boolean | No | API v1.6+ only: True if UI controls should be shown or enabled to change the onState |
allowSensorValueChange | boolean | No | API v1.6+ only: True if UI controls should be shown or enabled to change the sensorValue |
onState | boolean | No | indicates that the device is currently in a triggered or ON state (None if sensor doesn't support ON/OFF) |
sensorValue | integer or float | No | API v1.6+ only: the numerical value of a sensor, such as temperature (None if sensor doesn't support sensor values) |
Commands (indigo.sensor.*)
Set On State
| Parameters |
Commands (indigo.relay.*)
Set LED State
| Parameters |
# Toggle the device
| -- Toggle the device
toggle device “Office Lamp”
speedLevel | boolean | No | indicates the level the device is set to (0-100) - shortcut to dev.states['speedLevel'] |
speedIndex.ui | boolean | n/a | a more user friendly name for the current index (e.g. high, medium, low, off) |
speedLevel | boolean | speedLevel | indicates the level the device is set to (0-100) - use dev.speedLevel property as a shortcut |
Decrease Speed Index
Decreases the speed index.
| Parameters |
Increase Speed Index
Increases the speed index.
| Parameters |
Set Speed Index
| Parameters |
Set Speed Level
| Parameters |
activeZone | integer | No | 1.0 | the 1-based index of the active zone (None=all zones off, 1=zone 1, 2=zone 2, …). Note this property has undergone changes in name (previously called activeZoneIndex) as well as semantics (previously the index being 0-based). As of API v1.12 (Indigo 6.0.3) the property is final and stable. |
zoneEnableList | list of string | No | 1.13 | API v1.13+ only: list of booleans, starting at zone 1 through zone [zoneCount], that specify if a given zone is enabled (has a maximum zone duration > 0). |
zoneMaxDurations | list of reals | No | 1.0 | list of zone durations in minutes, starting at zone 1 through zone [zoneCount]. You must include zoneCount integers in the list. |
zoneScheduledDurations | list of reals | No | 1.0 | list of currently active zone durations in minutes if a schedule is running (empty list if no schedule is running), starts at zone 1 through zone [zoneCount] |
pausedScheduleZone | integer | No | 1.16 | API v1.16+ only: the 1-based index of the paused sprinkler zone index (None=schedule not paused, 1=zone 1 paused, 2=zone 2 paused, …). |
pausedScheduleRemainingZoneDuration | real | No | 1.16 | API v1.16+ only: the paused sprinkler zone duration in minutes (None if schedule not paused) |
Commands (indigo.sprinkler.*)
Next Zone
| Parameters |
Pause Schedule
indigo.sprinkler.pause(123)
| Parameters |
Previous Zone
| Parameters |
Resume Schedule
indigo.sprinkler.resume(123)
| Parameters |
Run Schedule
Run a sprinkler schedule.
| Parameters |
Stop Schedule
indigo.sprinkler.stop(123)
| Parameters |
Set Active Zone
| Parameters |
# run schedule
| -- AppleScript doesn't support directly running a schedule, so
-- then execute that.
-- run schedule
with properties ¬
end if
set zone durations of ¬
to [10, 15, 8, 0, 0, 0, 0, 0]
execute group actionGroupName
Fan Mode Enumeration
indigo.kFanMode |
HVAC Mode Enumeration
indigo.kHvacMode |
Decrease Cool Setpoint
| Parameters |
Decrease Heat Setpoint
| Parameters |
Increase Cool Setpoint
| Parameters |
Increase Heat Setpoint
| Parameters |
Set Cool Setpoint
| Parameters |
Set Fan Mode
Adjust the fan mode.
| Parameters |
Set Heat Setpoint
| Parameters |
Set HVAC Mode
Adjust the HVAC mode.
| Parameters |
# set the heat setpoint to 78
| -- increase the cool setpoint by 5 degrees
