Additionally, make sure you have your Access Point RFs (or other dual-band modules) correctly installed on opposite power legs. If the Access Point RFs or other dual-band devices are improperly installed or missing, then you may not be able to control some of your INSTEON devices. See the instructions included with your Access Point RF pair for installation details.
Managing INSTEON Links
Managing INSTEON Device Links
The primary place that you'll manage links between devices is in the Manage INSTEON Device Links dialog. Select the from Interfaces→INSTEON/X10 Power Line→Manage INSTEON Device Links menu item and the dialog will popup:
- Select the
Interfaces→INSTEON/X10 Power Line→Manage INSTEON Device Linksmenu item. - Select the module's device name to edit in the
Lastly, to have Indigo write all of your link changes to the remote modules, press the Sync Now button to have Indigo immediately write all changed links to the remote modules. Or, press the Close (Sync Later) button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync INSTEON Device Links… from the Interfaces→INSTEON/X10 Power Line menu, and then press the press the Sync Changes Only button.
Defining the Scene
- Choose
Manage INSTEON PowerLinc Links…from theInterfaces→INSTEON/X10 Power Linemenu. - Select a
Lastly, have Indigo write all of your link changes to both the PowerLinc and the remote modules by pressing the Sync Now button to have Indigo immediately write all changed links to the PowerLinc and remote modules. Or, press the Close (Sync Later) button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the PowerLinc and remote modules select Start Sync INSTEON Device Links… from the Interfaces→INSTEON/X10 Power Line menu, and then press the press the Sync Changes Only button.
Executing the Scene
- Select the
Sendpopup item to select which scene command to send:Group Onwill command all the responder modules to their scene-specific brightness using their scene-specific ramp rate duration, if any.Group On to 100% (instant / ignore rate)will set the brightness of dimmable modules to 100% immediately, ignoring any ramp rate duration.Group Offwill turn off all the responder modules using their scene-specific ramp rate duration, if any.Group Off (instant / ignore rate)will turn off all the modules immediately, ignoring any ramp rate duration.
Scenepopup item.
INSTEON Link Syncing
Make sure all devices are properly wired or plugged in. Select Start Sync INSTEON Device Links… from the Interface menu. Press the Sync All Devices button. Watch the Event Log window to see when the synchronization process is complete. The batch synchronization process can be canceled at any time.
Select Stop Sync INSTEON Device Links from the Interface menu. Watch the Event Log window to see when the synchronization process is canceled.
Resetting your PowerLinc
- Release the button
- In Indigo, select the
Sync Linksbutton
Replacing Your PowerLinc
Other INSTEON Features in Indigo (Pro Only)
The Interfaces→INSTEON/X10 Power Line submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI. Note that these are also actions available in the INSTEON Actions submenu.
Send Raw INSTEON Command
Set Motion Sensor Timeout
This action will set the timeout value between the time the motion sensor stops detecting motion and when it sends the OFF command. The timeout values work like this: 0 is equal to 30 seconds and 255 is equal to 2 hours. Values in between are proportional to those values. Note: only revision 2 Motion Sensors with jumper 5 set can be configured.
Set LED Brightness
if insteonPlugin.isEnabled():
actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
