Additionally, make sure you have your Access Point RFs (or other dual-band modules) correctly installed on opposite power legs. If the Access Point RFs or other dual-band devices are improperly installed or missing, then you may not be able to control some of your INSTEON devices. See the instructions included with your Access Point RF pair for installation details.
Insteon Device Detail Image
Define Insteon Dialog Image
Start Sync Dialog Image
The primary place that you'll manage links between devices is in the Manage INSTEON Device Links dialog. Select the from Interfaces→INSTEON/X10 Power Line→Manage INSTEON Device Links menu item and the dialog will popup:
Device Links Dialog Image
Device Links Example Image
  1. Select the Interfaces→INSTEON/X10 Power Line→Manage INSTEON Device Links menu item.
Lastly, to have Indigo write all of your link changes to the remote modules, press the Sync Now button to have Indigo immediately write all changed links to the remote modules. Or, press the Close (Sync Later) button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync INSTEON Device Links… from the Interfaces→INSTEON/X10 Power Line menu, and then press the press the Sync Changes Only button.
Manage Powerlinc Scenes Image
Defining the Scene
  1. Choose Manage INSTEON PowerLinc Links… from the Interfaces→INSTEON/X10 Power Line menu.
Lastly, have Indigo write all of your link changes to both the PowerLinc and the remote modules by pressing the Sync Now button to have Indigo immediately write all changed links to the PowerLinc and remote modules. Or, press the Close (Sync Later) button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the PowerLinc and remote modules select Start Sync INSTEON Device Links… from the Interfaces→INSTEON/X10 Power Line menu, and then press the press the Sync Changes Only button.
Executing the Scene
    • Group Off will turn off all the responder modules using their scene-specific ramp rate duration, if any.
    • Group Off (instant / ignore rate) will turn off all the modules immediately, ignoring any ramp rate duration.
Make sure all devices are properly wired or plugged in. Select Start Sync INSTEON Device Links… from the Interface menu. Press the Sync All Devices button. Watch the Event Log window to see when the synchronization process is complete. The batch synchronization process can be canceled at any time.
Select Stop Sync INSTEON Device Links from the Interface menu. Watch the Event Log window to see when the synchronization process is canceled.
  5. Release the button
The Interfaces→INSTEON/X10 Power Line submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI. Note that these are also actions available in the INSTEON Actions submenu.
This action will set the timeout value between the time the motion sensor stops detecting motion and when it sends the OFF command. The timeout values work like this: 0 is equal to 30 seconds and 255 is equal to 2 hours. Values in between are proportional to those values. Note: only revision 2 Motion Sensors with jumper 5 set can be configured.
if insteonPlugin.isEnabled():
    actionProps = dict()
  • /www/perceptive/wiki/data/pages/indigo_6_documentation/managing_insteon_devices.txt
