Indigo Overview
| Object | Definition |
Devices in Indigo are “things” that Indigo can interact with. Not only can Indigo interact with Z-Wave®, INSTEON, and X10 devices but Indigo Pro also supports devices provided by third party plugins. This greatly expands the kind of devices that can be defined in Indigo.
Here is the device dialog:
The first thing that you need to select is the Type. All versions of Indigo include support for the following device types: Z-Wave, INSTEON, and X10 (click on the types for details of how to manage devices of that type). Indigo Pro will also add a Virtual Devices interface type and will show the following plugins that provide device types (these plugins ship with Indigo 6 Pro):
Device Options
Triggers
Device State Changed
Variable Changed
Email Received (Pro only feature)
Indigo Server Startup
Power Failure
Interface Connection Failure
INSTEON Command Received
Z-Wave Command Received
Use the Type Z-Wave Command Received to trigger an action when Z-Wave commands are sent from a device, like a scene controller or motion sensor, and then received by the Z-Wave interface. Each device type will have different options based on it's capability
X10/RF Command Received
Plugin Events (Pro Only)
Plugins may define events as well - these will be listed below the X10/RF Command Received event in the Type popup. By default, Indigo Pro includes two plugins that provide events: Airfoil and SQL Logger - click on their links for a description of the events they supply.
Schedules
Time
Date
Other Options
Actions
Device Actions
The Device Actions category has 7 subcategories. Plugins can also add a submenu to this category for the actions they define that work directly on devices. By default, Indigo ships with the iTunes and Timers and Pesters plugins, which add subcategories to this menu (Pro only). You may have other menus as well if you've installed 3rd party plugins.
Universal Controls
Request Full Status Update- ask the device to reply with all possible status information. This is dependent on the capabilities of the device.Request Energy Update- ask the device to reply with only it's energy usage information. This is dependent on the capabilities of the device - many do not support energy monitoring.Reset Energy Usage- ask the device to reset the running total of energy usage. This is dependent on the capabilities of the device - many do not support energy monitoring.Turn On Keypad Button- turn on the specified button' light on the device. Only applies to devices which have separate buttons that indicate state with a light.Turn Off Keypad Button- turn off the specified button'light on the device. Only applies to devices which have separate buttons that indicate state with a light.Beep Device- ask the device to beep. This function is dependent on the capabilities of the device.
Light/Appliance Controls
All Off- turn off all light and appliance devices. TheDevices:popup lets you selectAll INSTEON/X10,All INSTEON,All X10, or a specific X10 house code.All Lights On- turn on all light devices with the sameDevices:options asAll OffAll Lights Off- turn off all light devices with the sameDevices:options asAll OffTurn On- turn on a specific device with an optional complementaryAuto-off after X minutesactionTurn Off- turn of a specific device with an optional complementaryAuto-on after X minutesactionToggle On/Off- turn on the device if it's off or off if it's onSet Brightness- set the brightness of a lamp device to a specific percentage (from 0-100)Brighten by %- increase the brightness of a lamp device by a specific percentage (from 0-100)Dim by %- increase the brightness of a lamp device by a specific percentage (from 0-100)Match Brightness (Pro Only)- set the brightness of any number of dimmer devices to the value of the selected dimmer device - so you can quickly and easily create a very simple scene.
Sprinkler Controls (Pro Only)
Run Schedule- selecting this action will show you the zone table (shown above) that will allow you to set the duration for each zone and optionally multiply those durations by the selected variable. This last option is useful if you change durations based on time of year - you can change the variable value but keep the existing schedule and it'll adjust the duration as appropriate.
Pause Schedule- this action will pause the current schedule (if for instance you're walking to your car and don't want to get wet)Resume Schedule- this action will resume a previously paused schedule (once you're in your car)Stop (all zones off & clear schedule)- this action will completely stop the scheduleActivate Previous Zone- this action will cause the schedule to back up one zoneActivate Next Zone- this action will cause the schedule to jump to the next zoneTurn on Specific Zone- this action will turn on a specific zone for the maximum run time specified in the sprinkler's definition and will turn off after it's done
Thermostat Controls (Pro Only)
Set Heat Setpoint- set the heat setpoint to an absolute temperatureIncrease Heat Setpoint- increase the heat setpoint by some number of degreesDecrease Heat Setpoint- decrease the heat setpoint by some number of degreesSet Cool Setpoint- set the cool setpoint to an absolute temperatureIncrease Cool Setpoint- increase the cool setpoint by some number of degreesDecrease Cool Setpoint- decrease the cool setpoint by some number of degreesSet Mode- set the mode of the thermostat to one of the following:All Off- set the HVAC unit so that both heat and cool setpoints are ignored - the unit will not come on at allHeat On- activate the HVAC unit so that only the heat setpoint is usedCool On- activate the HVAC unit so that only the cool setpoint is usedHeat/Cool On- activate the HVAC unit so that both heat and cool setpoints are usedRun Heat Program- tell the thermostat to run the heat program that is programmed directly into the thermostat (see the thermostat documentation for details)Run Cool Program- tell the thermostat to run the cool program that is programmed directly into the thermostat (see the thermostat documentation for details)Run Heat/Cool Program- tell the thermostat to run the heat/cool program that is programmed directly into the thermostat (see the thermostat documentation for details)Fan Auto On- turn the fan on (so it'll continuously run)Fan Always On- set the fan so that it only runs as needed)
Get All Status- get all information from the thermostatGet Current Mode- get the current modeGet Ambient Temperature- update the temperatureGet Ambient Humidity- get the humidityGet Setpoints- get the setpointsCycle Through Thermostat Modes- this will allow you to easily cycle through thermostat modes in this order: Off, Cool, Heat, Auto. Especially useful in conjunction with the “Thermostat Mode+.png” image on a control page - just add this as a server action and you have a simple control for adjusting the thermostat mode - each time you tap/click the image, the thermostat selected will cycle to the next mode just like pressing the Mode button on the thermostat itself (if it has one).Toggle Thermostat Fan Mode (Pro Only)- like the action above, this method will toggle between the two fan modes: Fan On (always on) and Fan Auto (automatic). Again, useful with the “Thermostat Fan Mode+.png” image file.
v1 INSTEON thermostat adaptors didn't broadcast out changes to update it's internal state representations for the thermostats - which is why there are so many options to get status. Indigo 6 catches the v2 thermostat update broadcasts so the need to manually get updates should be reduced.
Fan Speed Controls
Set Fan Speed- set the speed of the device to a specific levelIncrease Fan Speed- increase the fan speed by some # of units - for instance, on a FanLinc that's currently onLow, increasing the fan speed by 1 will set it toMediumDecrease Fan Speed- decrease the fan speed similarly to the above Increase Fan SpeedTurn Fan On (resume last speed)- this will turn the fan on to it's last speed settingTurn Fan Off- turn the fan off completelyToggle Fan On/Off- toggle between on and offCycle Through Speed Control (FanLinc) States- use this action to cycle through the fan speeds in this order: High, Medium, Low, Off. It's basically an electronic version of pulling the fan's chain.
Input / Output Device Controls (Pro Only)
Virtual Device Controls (Pro Only)
Server Actions
The Server Actions category has three actions and three subcategories.
Execute Action Group
Remove all delayed actions- this will remove all delayed actions regardless of delay typeRemove for device- remove any delays for the selected deviceRemove for trigger- remove any delays from the selected triggerRemove for schedule- remove any delays from the selected schedule
Reset Interface Connections
This action will attempt to reset all built-in hardware interfaces. There are no options.
Script and File Actions
Execute Script (Pro Only)
The Execute Script action allows you to execute either a Python or AppleScript as an embedded script or stored in a script file. In general, you should use embedded scripts for scripts that are short and very quick to execute.
Embedded Python scripts will be limited to 10 seconds of execution time - if they run longer than that they will be killed. If you have a Python script that is a long running script you should save it in a separate file and execute it from the file by selecting the File radio button then selecting the file. Python scripts executed from files are executed in their own process and are therefore much less likely to adversely effect the server process if they don't work as expected.
Embedded AppleScripts must run on the server's main execution thread so if it delays, can hang on external events like network access, or otherwise does a lot of processing, then everything else in the server will be put on hold until the script is finished. Therefore, you definitely should keep embedded AppleScripts very simple. As with Python scripts, long running AppleScripts should be stored in a separate AppleScript file (created with Script Editor) and executed that way - external AppleScript files execute in their own process and are therefore much less likely to adversely effect the server process if they don't work as expected.
Open File (Pro Only)
Run Shell Script (Pro Only)
This will run the specified script file optionally with the output being inserted into the specified variable. The script must be marked executable and a valid shebang (#!/path/to/shell) must be specified at the top of the script. Note - this won't work for AppleScripts - you should use the built-in Execute Script action and select the script file that way. Also, if you're running a Python script you'll probably just want to use the Execute Script action since script files run from this plugin won't have access to the IOM (import indigo, which is Python-only).
Log Actions (Pro Only)
Write to Log (Pro Only)
Email Event Log Data (Pro Only)
Enable/Disable Actions
Enable Device
Enable Trigger
Enable Schedule
Disable Device
Disable Trigger
Disable Schedule
Variable Actions
There are three actions that are specific to variables.
Modify Variable
Insert Device State into Variable (Pro Only)
Insert Timestamp into Variable (Pro Only)
Toggle Variable (Pro Only)
Set Variable to Variable (Pro Only)
Notification Actions
In the standard install of Indigo, there are two actions: Send Email and Growl Notify (Pro Only). Plugins (also Pro Only) are allowed to add menu items to this category so there may be more options if you've installed some 3rd party plugins.
Send Email
Growl Notify (Pro only)
INSTEON Actions
Execute INSTEON Scene
Scene On- send the ON command to every device in the group - if the device has an adjustable ramp rate and/or brightness value, those are honoredScene Instant On (to 100%)- send the ON command to every device in the group - but ignore ramp rates and default brightness values (everything comes on full immediately)Scene Off- send the OFF command to every device in the group - if the device has an adjustable ramp rate it will be honoredScene Instant Off- send the OFF command to every device in the group - ignore ramp rates (everything goes off immediately)
Finally, if you need to add, modify, or delete a device from the scene, click on the Modify Scene… button. See the Indigo and INSTEON Link Management page for more details.
Set LED Brightness (Pro only)
Turn On/Off KeypadLinc Buttons (Pro only)
Set KeypadLinc Auto-Off Button Group (Pro only)
Set KeypadLinc Button Toggle Mode (Pro only)
Set Motion Sensor LED Brightness (Pro only)
Set Motion Sensor Timeout (Pro only)
This action will set the timeout value between the time the motion sensor stops detecting motion and when it sends the OFF command. The timeout values work like this: 0 is equal to 30 seconds and 255 is equal to 2 hours. Values in between are proportional to those values. Note: only revision 2 Motion Sensors with jumper 5 set can be configured.
Set Motion Sensor Day/Night Sensitivity (Pro only)
Set I/O Linc Momentary Mode (Pro only)
Configure SynchroLinc (Pro only)
Send Raw INSTEON Command (Pro only)
Action Options
Managing Multiple Actions
To create a new action group:
- Select
Notes. - Select the action
Control Pages
Control pages are graphical pages that you use to control Indigo, either through a web browser or Indigo Touch. Indigo Lite and Pro have built-in control pages available on the web (Indigo Touch has built-in base functionality that matches them). Indigo Pro also allows you to design custom graphical pages - from the background image and/or color to the placement of text labels, control images, and what actions clicking/tapping on those images performs.
Control Page Editor (Pro Only)
This is where you set global information about the page itself. The Page Name: and Description: fields are pretty self-explanatory. Check the Hide Tab Bar at bottom of Indigo Touch when shown to have the bottom navigation bar hidden when this page is viewed in Indigo Touch. You can use a Background image: by selecting it from the popup, such as a floorplan or other image. You can add your own image by creating a PNG file and adding it to the backgrounds folder (to open that folder in the Finder just click the Show Folder button - and if you add an image while Indigo is running, click the Refresh button to have it added to the popup). Note: some versions of Indigo 6 don't like spaces in the background image name so just replace spaces with another character such as an underscore.
- iPhone/iPod touch
- iPad
Other Editor Features
Page Element Details
Device State
Variable Value
Static Image/Caption
Refreshing Image URL
Server Status Text
Server Status Icon
Client Actions
- Popup UI Controls - this will cause the client to pop up a dialog with the controls appropriate for the device or variable selected (it doesn't do anything for other page element types)
- Link to Control Page - this will cause the client to display the selected control page so it's useful to navigate between control pages. The
Open in new windowcheckbox really only effects viewing pages in a browser, not Indigo Touch - Link to URL - this will cause the client to open the provided URL in a browser window (a new browser window if the
Open in new windowcheckbox is checked).In Indigo Touch, it will cause Mobile Safari to open and show the page specified by the URL.
Server Actions
Variables
Variables are used to hold information that can help your home automation logic. For instance, Indigo ships with an AppleScript which stores weather information in variables. You can use that information to display on control pages, as part of your conditional logic (see Conditions below), or as a trigger for some other action.
Conditions
- if it's too cold outside
"If dark"
