Note most of the code examples below are calling methods on the object self
. In this context, self
is meant to be the Plugin instance as defined inside the plugin.py
file. To execute the sample code outside of Plugin instance methods use the indigo.activePlugin
object instead.
Important: For simplicity some of the samples below specify objects based on name (“office desk lamp”
Plugin task | Plugin that illustrates an approach |
Parsing XML from an IP source | NOAA Weather, WeatherSnoop |
Integrating with native Mac Apps | Airfoil |
Sending RS232 (serial port & network serial port) Commands | EasyDAQ |
Reading RS232 (serial & network serial port) Input | EasyDAQ |
Interacting with an IMAP mail server | iCal Alarm Processor |
Creating custom devices with states | Simple: NOAA Weather, WeatherSnoop - Complex: EasyDAQ, iTunes |
Creating custom actions | Growl, Action Collection |
Creating custom events | Airfoil |
Each of these plugins is installed by default with Indigo 6 - in the /Library/Application Support/Perceptive Automation/Indigo 6/Plugins (Disabled)/
folder. To see the various XML and python source files, just right-click on it in the Finder
and select Show Package Contents
someVal = self.pluginPrefs["somePrefKey"] indigo.server.log("value is " + str(someVal))
.pluginProps
.dev = indigo.devices["den fixture"] newProps = dev.pluginProps newProps["onCycles"] = 5 newProps["moreData1"] = "abc" newProps["moreData2"] = True newProps["moreData3"] = 123.45 dev.replacePluginPropsOnServer(newProps)
dev = indigo.devices["den fixture"] onCycles = dev.pluginProps["onCycles"] indigo.server.log("onCycles is " + str(onCycles))
dev = indigo.devices["den fixture"] newProps = dev.pluginProps newProps["onCycles"] += 1 dev.replacePluginPropsOnServer(newProps) dev = indigo.devices["den fixture"] onCycles = dev.pluginProps["onCycles"] indigo.server.log("onCycles is now " + str(onCycles))
.globalProps
<ConfigUI>
XML node. Every field id
is automatically mapped into the device instance .pluginProps
metadata dictionary (described above) as a unique key.<States>
XML node, and are used to define the transient state information for a device (ex: on/off setting, brightness, temperature, etc.).Device State Changed
options when that plugin device type is selected, and are automatically shown in the Control Page editor when a control is created inspecting that plugin device.heatSetPoint
by 1:dev = indigo.devices["Custom Plugin Thermostat"] dev.updateStateOnServer("heatSetPoint", dev.states["heatSetPoint"] + 1)
deviceStartComm
and deviceStopComm
to start/stop any hardware communication (normally via a new per-device thread):def deviceStartComm(self, dev): self.easydaq.startCommThread(dev) def deviceStopComm(self, dev): self.easydaq.stopCommThread(dev)
deviceStartComm
and deviceStopComm
are automatically managed by the Indigo Server and Indigo Plugin Host. When a plugin first connects all enabled device instances owned by the plugin will receive deviceStartComm
calls. Likewise, deviceStartComm
is called when a new plugin device is created or duplicated. deviceStopComm
is called whenever a plugin is disabled, deleted, or when the plugin is shutting down. Therefore, these two functions should be the primary bottlenecks for starting/stopping device hardware or network connections.
Explain Events.xml. Show example plugin subclasses of functions: triggerStartProcessing, triggerStopProcessing, didTriggerProcessingPropertyChange. Note it works very similarly to devices.
Give examples of using indigo.devices.subscribeToChanges() and plugin subclasses of functions: deviceDeleted, deviceUpdated.
Give examples of using indigo.*.subscribeToChanges() and plugin subclasses of functions: variableCreated, variableDeleted, variableUpdated, triggerCreated, triggerDeleted, triggerUpdated, scheduleCreated, scheduleDeleted, scheduleUpdated, actionGroupCreated, actionGroupDeleted, actionGroupUpdated, controlPageCreated, controlPageDeleted, controlPageUpdated.
