Indigo 7.3 Documentation
Welcome to the Indigo 7.3 Documentation pages. We've separated the docs into three areas, each focusing on some different part of Indigo 7.3.
Indigo User Documents
Other Help Pages
Indigo Plugin Documents
- Growl - adds the ability to alert you of special events via the Growl library. Growl 2.1, 2.2, and 3.0 are supported.
- iCal Alarm Processor - a plugin that will monitor an IMAP email account for iCal alarm email messages and do some post-processing for you.
- iTunes - makes iTunes information available for use in Indigo and allows you to control iTunes.
- NOAA Weather - makes weather data from the National Oceanic and Atmospheric Administration available for use in Indigo.
Deprecated Plugins
With Indigo 7, we no longer ship the following plugins.
- Airfoil - this plugin was replaced by the Airfoil Pro plugin listed above, so you'll need to create Airfoil devices and update your old Airfoil actions to use the new plugin. If you need to use the old plugin, you can get it on our Github repo.
- DIRECTV DVR Control - this plugin, which allows Indigo to control some DIRECTV set-top boxes, is now in our Github repo to allow community improvements.
- Vera Bridge - this plugin, which integrates with the Vera controller, is no longer needed since Indigo now supports Z-Wave locks directly. It is still available in our Github repo.
- WeatherSnoop - the WeatherSnoop development team has taken over management of this plugin. Indigo 7.1.2 is the last version that will install the plugin automatically. Beginning with 7.3.0, you'll need to get the plugin from the Plugin Store.
Indigo How-To Wiki
Technical Documents
We provide several powerful yet easy to use ways to extend Indigo. We support a Python-based API that allows 3rd parties to integrate devices, events, and actions natively into Indigo without sacrificing speed and stability of the core server. We also support a legacy AppleScript API (which will be deprecated in Indigo 7.4 and later) that allows you to integrate with other Mac applications. This section provides links to all the documentation needed to develop scripts and plugins for Indigo.
- Indigo 7 Scripting Tutorial - dive into scripting Indigo by examples.
- Indigo 7 Server Plugin Tutorial - examples of extending Indigo via plugins.
- Indigo 7 Plugin Developer's Guide - how to create plugin bundles for easy distribution, plugin UI, APIs, callback hooks, and more.
- Indigo 7 Object Model Reference - the Indigo Object Model (IOM) and how to use it in Python.
- Indigo AppleScript Dictionary - this is a text version of the AppleScript dictionary found in Script Editor. Warning: AppleScripts that target the Indigo Server using this dictionary will stop working in Indigo v7.4 and above.
