Folders
name | string | the name of the folder - no two folders in the same namespace (i.e. indigo.devices ) can have the same name |
Commands (indigo.*.folder.*)
Command Syntax Examples |
Parameters |
Delete the specified folder.
Parameters |
direct parameter | Yes | integer | id or instance of the folder to delete |
Parameters |
direct parameter | Yes | integer | id or instance of the folder to duplicate |
Get ID
Parameters |
direct parameter | Yes | string | name of any folder for the specified object type. |
Parameters |
direct parameter | Yes | integer | id or instance of the folder |
Since folders aren't available in AppleScript (Deprecated in a future version of Indigo 7), we're only providing Python examples here.
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
