  key_value_list = [
Protocol Enumeration
indigo.kProtocol
Value Description
State Image Sel Enumeration
API v1.18+ only:
indigo.kStateImageSel
Value Description
None overrides to show no device image icon
Custom overrides to show a plugin defined custom image icon (not yet implemented)
Value Description
replacePluginPropsOnServer(newPropsdict) Yes 1.0 If you need to make a change to your plugin's property dictionary that's stored as part of the device (see About Plugin Properties below) you just use this method to replace the entire dict with a new one. A typical usage will be to get the property dictionary from the device, make changes to the dict, then use this method to store the new dict.
dev=indigo.devices[123]
    <State id="playStatus">
    <State id="sep1">
    <State id="playlist">
        <ValueType>String</ValueType>
    <State id="album">
    <State id="artist">
    <State id="track">
    <State id="volume">
    <State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
All Off
indigo.device.allOff()
Enumerated Type Description
Beep (API v1.11+ only)
indigo.device.beep(123)
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices (FIXME you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
    address='F8',
    name='Device Name Here',
    folder=1234)
deviceTypeId Yes string the id of the device type – defined by the plugin or one of the defined X10 devices FIXME link here
indigo.device.delete(123)
Enable/Disable
Get Group List
               ID : 1280166770 (integer)
               ID : 106487666 (integer)
Ping Device (API v1.16+ only)
if result["Success"]:
Status Request
Toggle
indigo.device.toggle(123)
Turn Off
indigo.device.turnOff(123)
Turn On
indigo.device.turnOn(123)
Unlock (API v2.0+ only)
indigo.device.unlock(123)
Lock (API v2.0+ only)
indigo.device.lock(123)
# Creating a device
    name="Office Lamp",
    address="F7",
# Getting a device
-- Getting a device
if (myDevice.remoteDisplay):
all off
All Lights Off
indigo.dimmer.allLightsOff()
All Lights On
indigo.dimmer.allLightsOn()
Brighten
indigo.dimmer.brighten(123)
Dim
indigo.dimmer.dim(123)
Set Brightness
Set LED State
Set On State
# Getting a device
    (myDevice.onState)):
myDevice.folderId
# OR
Set Binary Output
  • X10 Motion Sensors
Set On State
– none –
Set LED State
# Toggle the device
Decrease Speed Index
Decreases the speed index.
Increase Speed Index
Increases the speed index.
Set Speed Index
Set Speed Level
activeZone integer No 1.0 the 1-based index of the active zone (None=all zones off, 1=zone 1, 2=zone 2, …). Note this property has undergone changes in name (previously called activeZoneIndex) as well as semantics (previously the index being 0-based). As of API v1.12 (Indigo 7.0.3) the property is final and stable.
Next Zone
Pause Schedule
indigo.sprinkler.pause(123)
Previous Zone
Resume Schedule
indigo.sprinkler.resume(123)
Run Schedule
Run a sprinkler schedule.
Stop Schedule
indigo.sprinkler.stop(123)
Set Active Zone
# run schedule
coolIsOn boolean No 1.0 is the cooling system (compressor) currently running - shortcut for dev.states['hvacCoolerIsOn']
heatIsOn boolean No 1.0 is the heater currently running - shortcut for dev.states['hvacHeaterIsOn']
Fan Mode Enumeration
indigo.kFanMode
Value Description
HVAC Mode Enumeration
indigo.kHvacMode
Value Description
Decrease Cool Setpoint
value Yes integer number of degrees to decrease the cool setpoint
Decrease Heat Setpoint
value Yes integer number of degrees to decrease the heat setpoint
Increase Cool Setpoint
value Yes integer number of degrees to increase the cool setpoint
Increase Heat Setpoint
value Yes integer number of degrees to increase the heat setpoint
Set Cool Setpoint
Set Fan Mode
Adjust the fan mode.
value Yes kFanMode the absolute temperature of the setpoint
Set Heat Setpoint
Set HVAC Mode
Adjust the HVAC mode.
# set the heat setpoint to 78
  • /www/perceptive/wiki/data/pages/indigo_7.4_documentation/device_class.txt
