Actions
In the IOM, all actions are derived from a common Action base class. This base contains all the shared components of actions. Unlike the other major classes, however, there isn't a command namespace for Actions. Why is that, you say? Because Actions don't exist outside of the object that contains them (Triggers, Schedules, Action Groups, etc.). So, when manipulating actions, you always work directly on the object, then assign that object to one of the container objects. Don't worry, we'll walk you through it.
Action Base Class
The Action class is a base class that provides the common functionality to its subclasses (to follow). You may specify a new Action
class in your list of actions for a trigger, schedule, or action group, but the action type will be None
- that is, it will delay and speak any text set in the object, but other than that it will do nothing. Most of the time you'll be using one of the subclasses so that you get the specific functionality you're looking for.
delayAmount | integer | number of seconds to delay before executing the actions (0 for none) |
replaceExisting | boolean | if true then any existing delayed action is replaced by this one |
textToSpeak | string | this is the text to speak when the action is executed |
Complementary Delays
Complementary Actions |
Action | Complement |
DeviceAction
kDeviceAction.TurnOff
kDeviceAction.TurnOn
kDeviceAction.Toggle
kDeviceAction.Lock
kDeviceAction.Unlock | DeviceAction
kDeviceAction.Lock |
DisableScheduleAction | EnableScheduleAction |
DisableTriggerAction | EnableTriggerAction |
EnableScheduleAction | DisableScheduleAction |
EnableTriggerAction | DisableTriggerAction |
DeviceAction (API v2.0+ only)
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action) - see Complemetary Delays for details |
deviceId | integer | the id of the device |
deviceAction | kDeviceAction | this is the command to send to the device |
actionValue | integer or dict | if deviceAction is in [Brighten, Dim, SetBrightness] then this is an integer value |
Device Action Enumeration
indigo.kDeviceAction |
Value | Description |
AllLightsOff | turn off all dimmer (light) devices |
AllLightsOn | turn on all dimmer (light) devices |
AllOff | turn off all dimmer (light) and relay (appliance) devices |
BrightenBy | brighten a dimmer (light) device by the amount specified in the actionValue integer property |
DimBy | dim a dimmer (light) device by the amount specified in the actionValue integer property |
SetBrightness | set a dimmer (light) device to the brightness specified in the actionValue integer property |
SetColorLevels | set the color (RGB) and white levels to the values specified in the actionValue dict property |
Toggle | toggle the on/off state of a dimmer (light) or relay (appliance) device |
TurnOff | turn off a dimmer (light) or relay (appliance) device |
TurnOn | turn on a dimmer (light) or relay (appliance) device |
Lock | lock a deadbolt or door device |
Unlock | unlock a deadbolt or door device |
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action), in this case an EnableScheduleAction - see Complementary Delays for details |
scheduleId | integer | the id of the schedule to disable |
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action), in this case an EnableTriggerAction - see Complementary Delays for details |
triggerId | integer | the id of the trigger to disable |
EmailAction
emailBody | string | the body of the email to send |
emailSubject | string | the subject of the email to send |
emailTo | string | the (semicolon separated) list of email addresses |
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action), in this case an DisableScheduleAction - see Complementary Delays for details |
scheduleId | integer | the id of the schedule to enable |
EnableTriggerEventAction
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action), in this case an DisableTriggerAction - see Complementary Delays for details |
eventId | integer | the id of the event to enable |
ExecuteGroupAction
groupId | integer | the id of the action group to execute |
ExecuteScriptAction
scriptCode | string | this is the source code of the script to execute |
deviceId | integer | this is the ID of the I/O device |
action | kIOAction | this I/O action to execute |
index | integer | if action is TurnOffOutput , TurnOnOutput , the index of the input or output to control |
indigo.kIOAction |
TurnOffOutput | turn off the output specified by index |
TurnOffAllOutputs | turn off all outputs |
TurnOnOutput | turn on the output specified by index |
RequestStatusAll | request status of all hardware input/outputs |
RequestAnalogInputValues | request all analog input values from the device |
RequestBinaryInputsStatus | request all binary input statuses |
RequestBinaryOutputsStatus | request all binary output statuses |
RequestSensorInputValues | request all sensor input values |
ModifyVariableAction
variableId | integer | the id of the variable |
variableAction | kVariableAction | the type of variable action to execute |
variableValue | string | the new variable value |
Variable Action Enumeration
indigo.kVariableAction | |
DecrementValue | decrement the variable value by 1 |
IncrementValue | increment the variable value by 1 |
SetValue | set the variable to the variableValue property |
PluginAction
pluginTypeId | string | the id specified in the Actions.xml (or it’s documentation) |
props | dictionary | an indigo.Dict() defining this action's parameters |
SendInsteonGroupCommandAction
command | kInstnGroupCommand | this is the group command to send |
group | integer | this is the group number to send command to |
indigo.kIOAction | |
InstantOff | send the instant (fast) off command to group ignoring ramp rate |
InstantOn | send the instant (fast) on command to group ignoring ramp rate |
Off | send the off command to group |
On | send the on command to group |
SprinklerAction
deviceId | integer | the id of the sprinkler device |
multiplierVarId | integer | API v1.20+ only: optional elem ID for the variable multiplier (None if no multiplier is specified) |
sprinklerAction | kSprinklerAction | this sprinkler action to execute |
zoneDurations | list of float | list of floats that represent the durations in minutes for each zone to schedule - used when sprinklerAction is RunNewSchedule |
zoneIndex | integer | the zone to turn on as a 1-based index – used when sprinklerAction is ZoneOn |
Sprinkler Action Enumeration
indigo.kSprinklerAction |
RunNewSchedule | run a new sprinkler schedule |
RunPreviousSchedule | run the last executed sprinkler schedule |
PauseSchedule | pause the current sprinkler schedule |
ResumeSchedule | resume the current sprinkler schedule |
StopSchedule | stop the current sprinkler schedule |
PreviousZone | set sprinkler to the previous zone |
NextZone | set sprinkler to the next zone |
ZoneOn | turn on a single zone |
AllZonesOff | turn off all zones |
RequestStatusAll | request status of all valves |
ResetInterfacesAction
ThermostatAction
deviceId | integer | this is the ID of the thermostat |
thermostatAction | kThermostatAction | this thermostat action to execute |
actionMode | kFanMode
OR
kHvacMode | if action is SetFanMode, then a kFanMode enumeration
if action is SetHvacMode, then a kHvacMode enumeration |
actionValue | float | if action is Decrease * or Increase *, the amount to increase/decrease the setpoints
if action is Set *, the temperature to set the setpoint to |
Thermostat Action Enumeration
indigo.kThermostatAction |
DecreaseCoolSetpoint | decrease setpoint by value |
DecreaseHeatSetpoint | decrease setpoint by value |
IncreaseCoolSetpoint | increase setpoint by value |
IncreaseHeatSetpoint | increase setpoint by value |
SetCoolSetpoint | set the setpoint to value |
SetFanMode | set the fan mode to mode |
SetHeatSetpoint | set the setpoint to value |
SetHvacMode | set the hvac mode to mode |
RequestStatusAll | request all current values from the thermostat |
RequestMode | request the current mode of the thermostat |
RequestEquipmentState | request the current operational state of the compressor, furnace, etc. |
RequestTemperatures | request all current temperatures from the thermostat |
RequestHumidities | request all current humidities from the thermostat |
RequestDeadbands | request the current deadband ranges from the thermostat |
RequestSetpoints | request all current setpoints from the thermostat |
UniversalAction (API v2.0+ only)
API v2.0+ only: This class represents a univeral action that can be used with devices of different classes. Previously this class was named GeneralDeviceAction – it was renamed in API v2.0.
deviceAction | kUniversalAction | this is the command to send to the device |
indigo.kUniversalAction |
Beep | request that the device perform an audible beep or buzz |
EnergyUpdate | request that the energy meter send its most recent meter data |
EnergyReset | request that the energy meter reset its accumulative energy usage data |
RequestStatus | send a device a status request for a complete update |
